Old 01-13-2014, 12:32 AM   #435
Skorov
Skorov's Avatar
Drives: 86 GTS White
Originally Posted by gdrider77 View Post
Prayed.... But seriously probably won't fit right ever again. I have seen stock on the lot twins with the loose bumpers. Such a shitty design.
I mean I physically cannot insert the top and bottom clips. The FMIC sits too low. I'm thinking of drilling new holes into the mounting brackets. =\
Skorov is offline   Reply With Quote
Old 01-13-2014, 12:33 AM   #436
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
I think I read somewhere the clips aren't intended to be reused. Each time the front bumper comes off you need a new set. I could be wrong though.
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
Old 01-13-2014, 12:51 AM   #437
protpibe
protpibe's Avatar
I think if you stuff something small between the fender and bumper by the marker lights, the pressure will force the bumper to stay in place. One guy on here used a small length of speaker wire stuffed in there and it worked like a charm
Old 01-13-2014, 12:57 AM   #438
Skorov
Skorov's Avatar
That's not the problem (not yet anyway). The problem is that the FMIC is too low and I can't even align the bumper properly making it impossible to insert the pop-clips at the top and bottom.
Old 01-13-2014, 01:01 AM   #439
RAN94A
Grand PooBah
RAN94A's Avatar
Drives: Toyota 86 GT MT
Originally Posted by Draco_PR23 View Post
I didn't used the included rivets, I got a longer screw and installed the IC using the existing holes in the crash beam
did the same
RAN94A is offline   Reply With Quote
Old 01-13-2014, 09:36 AM   #440
protpibe
protpibe's Avatar
I guess I'll find out for myself later this week, but I'm having a hard time visualizing how a bumper won't align properly with an intercooler that mounts inboard in an enclosed space? Unless you mean the piping is in the way.
Is the bumper cover shifted to the left or right excessively so that you can't install the popits?
Old 01-13-2014, 09:49 AM   #441
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That is what I would recommend. The other option would be to trim the outline of the intercooler into the panel that sits under the intercooler so that the panel tucks up around the intercooler. You are definitely not the only one to have issues trying to get the bumper back on with an intercooler mounted too low. My other advice would be put a jack on the intercooler and insure it is pushed up as high as it can go while you tighten down the mounting bolts.
Old 01-13-2014, 11:17 AM   #442
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
the routing of the intake pipes close to the headlights is the problem.
Also, how low/high the I/C ends up will mess with the bottom tray that is held by the bumper cover and thus can shift it to be out of place.
Old 01-13-2014, 02:25 PM   #443
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
I was surprised that I didnt have a problem when reinstalling the bumper, but I will need to remove it again once I get the new IC (I installed the bent IC).
Agree!!! That happened to me, the bottom tray didnt fit because of the IC was lower .. I fixed it by trimming the tray.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 01-13-2014, 07:42 PM   #444
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Finished my install last night. It's with the tuner today. Can't wait to finally test her out.
I had a ton of trouble getting the front bumper to clip back on. I've read other have had this issue. What's the trick? What has everyone else done to make it fit like it's supposed to?
This should help, the instructions say to lift the beam up as high as possible when up bolt is down. We found that by taking a drill/die grinder bit to the 8 mounting holes and oblong them. This will allow the beam to lift higher and the bumper to fit.
DAMotorsports is offline   Reply With Quote
Old 01-14-2014, 10:06 AM   #445
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yep. That is what the Full Blown turbo instructions say to do.
Old 01-14-2014, 06:12 PM   #446
Bigmaxy
Drives: Pegasus GTS86
Having a few issues with this kit. The latest is installing the heat shield.
The instructions call for installing a right angle bracket. I found a location with a spare bolt hole that looked the same as the instructions. The problem seems to be that this puts the bracket on a different plane to the bolt that is used for the grounding strap.
result is the heat shield is not flat and the edge touches the turbine housing.
In addition to this is seems that the turbine housing is barely covered by the shield and only covers the head/cam area.
Is this correct to proceed?
Bigmaxy is offline   Reply With Quote
Old 01-14-2014, 08:01 PM   #447
DAMotorsports
That is correct there should be an allen bolt with a small spacer with the kit. There have been a few kits where the spacer is missing. We make a spacer out of a metal tube form the hardware store.
Old 01-14-2014, 08:58 PM   #448
protpibe
protpibe's Avatar
Has anyone added a turbo blanket onto the AVO turbo? If so, which one fits?
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
