Old 08-13-2015, 10:39 PM   #435
jainish007
Drives: 2014 Monogram Scion FRS Whiteout
What's the difference between getting premium kit vs base kit?
Originally Posted by FullBlown View Post
We Just got done with our stage 1 FRS/BRZ Turbo kit. We are happy with the results considering all the OEM parts we still have on the car.
The car still has the stock exhaust and cat. We also have the stock clutch on it for now.
This kit is now available for sale.
FBM BRZ/FRS Stage 1 Premium kit
- FBM EL Turbo manifold
- Garrett GTX2867 with Tial V-band housing
- FBM Aluminum intercooler Piping with couplers
- FBM 3" V-band Downpipe
- FBM 550hp Intercooler
- FBM Intake Pipe
- FBM Dump tube
- Tial 50mm BOV
- Tial 44mm Wastegate
- FBM 550cc injectors
- FBM 270LPH Pump
- FBM Dual slim fans
- All Hardware/oil lines and gaskets
- FBM 7psi Basemap Tuned with Ecutek
List Price $6295
(Kits comes with a overnight label for both ways) When you receive the kit, you will ship us the ecu and we will flash it with our 7psi tune and overnight it back. **No additional cost cost for license or tune.
We are constantly trying to improve our quality and efficiency for our customers. So, we will be including one of these usb sticks with every kit to ensure that every customer has an install guide and basemap easily accessible.
These will be available in a week and a half. For anyone who has already purchased our turbo kit, we will be sending these out to you as well.
On top of that, we will also include a dyno charts of our tunes on the different types of gas.
Here is the dyno @ 7psi on 91 octane pump gas vs the stock baseline. The E85 tune and 3" exhaust with higher boost tune is coming.
E85 11.5 psi
Here are some Dyno Vids
Jainish
jainish007 is offline   Reply With Quote
Old 08-14-2015, 08:34 AM   #436
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by jainish007 View Post
Jainish
The difference is:
GT2871R vs GTX2867R
4 bolt mounting vs V band mounting
Upgraded intercooler
Mass produced intercooler piping versus hand built intercooler piping
I believe those are the major differences.
Old 08-14-2015, 08:43 AM   #437
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Is there a trick to get the inner header bolt on the driver side tight without destroying your nuckles?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 08-14-2015, 08:10 PM   #438
GsxrMe
GsxrMe's Avatar
I ended up cutting and welding a wrench in the shape of a boomerang. Problem solved!
2014 Subaru BRZ
Old 08-16-2015, 07:03 PM   #439
HaloFRS
Drives: 2020 Subaru BRZ Limited
How does this kit handle the heat? I'm really stuck with this one or going sc Innovate or kraftwerks.
HaloFRS is offline   Reply With Quote
Old 08-16-2015, 07:40 PM   #440
Griever423
Drives: 2020 BRZ PP
A turbo compared to a supercharger (at least those you just mentioned) is going to run a lot cooler and be a lot more efficient. Heat soak is a big issue with supercharging.
Griever423 is offline   Reply With Quote
Old 08-17-2015, 05:50 PM   #441
ben15r
ben15r's Avatar
Drives: FBM stage 1 rebadged FRS
My only argument is that the way the down pipe routes the intake is pretty close and the heat transfer is a problem we think, I just got a blanket and wrap for the down pipe, I only have these problems at autox and drift and traffic on hot days (low speed, very little air flow) I may also have a fan issue. Because freeway, drag, roll race no overheat issues what so ever.
That being said, I love it and so does everyone who sees it I'm only at 280 whp on 93 and ready to go to e85
ben15r is offline   Reply With Quote
Old 08-18-2015, 10:16 PM   #442
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
I'm having trouble agreeing with this. Are you saying a supercharger pumps in bigger air than a turbo or a supercharger runs hotter than a turbo? Surely a turbo runs hotter due to recirculating hot ass exhaust funds through the engine bay, spinning the big side of a turbo and significantly raising temps under the hood more than a belt driven SC. Granted I'm describing a front mounted turbo setup. Compare to rotrex not twinscrew.
Why is it a twin screw has higher IAT? Is that core intercooler just not sufficient enough ?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 08-18-2015, 10:48 PM   #443
Griever423
Drives: 2020 BRZ PP
Given the same volume of air and pressure the air in a turbo system is going to be cooler and denser than that of a roots type supercharger. Roots type superchargers in particular are not nearly as efficient at compressing air without adding heat, hence the temp differences. It's just a limitation in the design. I'm pointing this out because the post I quoted was considering a screw or roots type.
There will be differences with a rotrex but they're still not as efficient as a turbo because of the belt. Less efficiency = more heat to produce the same pressure and move the same volume. I'm speaking very generally here and I'm sure someone with a better grasp of the physics can correct me if I'm wrong.
Old 11-24-2015, 10:34 PM   #444
poolboy54
Drives: Scion FRS. Silver with black badges
Do you have to send in your ECU or can you download the map if you already have ecutek?
poolboy54 is offline   Reply With Quote
Old 11-25-2015, 10:49 AM   #445
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You don't have to send in your ECU. You flash it with EcuTek and an EcuTek cable through the OBDII port.
Old 11-26-2015, 02:53 AM   #446
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
what boost controller are you guys running? I purchased a prodrive boost controller, but not sure if its compatible with our kit
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 11-27-2015, 09:46 AM   #447
King Tut
NASA SpecE30 Racer
King Tut's Avatar
All external wastegate boost controllers are compatible. They are simple devices. All they do is manipulate the vacuum/boost on top of or below the diaphragm in the wastegate. Now how you adjust or control that boost controller is up to you.
Old 11-28-2015, 01:30 AM   #448
FRS Johnny
FRS Johnny's Avatar
Where would I hook up the ports? Because on the picture it looks like the turbo has a fitting, but our turbo set up doesn't..
700 Miles Blown Clutch Bonburner Issues | Warranty | Recalls / TSB 76 09-23-2012 09:32 PM
Exhaust Stage enkubus Engine, Exhaust, Transmission 3 08-14-2012 09:31 PM
Initial D stage 5 86boyAF1 Off-Topic Lounge [WARNING: NO POLITICS] 7 08-08-2012 10:00 AM
Battle Stage 2 trueno86power Other Vehicles & General Automotive Discussions 2 09-26-2011 03:04 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
