Old 01-23-2020, 08:36 AM   #435
Originally Posted by Th3rdSun View Post
The problem,for me at least,is that after years and years of making the car work hard,it can't be good for longevity. It's like making a 70 year old run,instead of walking,every where he goes.
Actually no, isn't an issue. Subaru boxer engines are often used in applications where they are run at 80% to 90% of power most of their lives. For example, many experimental aircraft use Subaru auto engine conversions with no issues where they run wide open constantly. This is usually after having seen life in a car first, then being rebuilt.
Even if used for pure track use, you are not likely to stress the engine that much.
Honda and GM Corvair engines are also often used for this purpose.
Last edited by Dadhawk; 01-23-2020 at 09:01 AM. Reason: spelling...words a hard...
new2subaru (01-23-2020), soundman98 (01-24-2020), Tcoat (01-23-2020)
Old 01-23-2020, 10:43 AM   #436
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I have a Honda v6 outboard motor on my boat that will just hum at 6k rpm all day long.
I take my twin up to redline all the time. It just gets there a bit faster now than when I first bought it.
Dadhawk (01-23-2020), soundman98 (01-24-2020)
Old 01-23-2020, 10:52 AM   #437
There's also a marine version of the GM Vortec V6 used for an outboard motor. This is basically a slightly modified version of the engine that was used in the Chevy Astro and some of GM's small trucks.
Old 01-23-2020, 11:12 AM   #438
This is a rehash of the whole "don't drive around at 4.000 rpms you will wear your engine out faster" thread.
Most gas engines are designed to operate at high RPMs. Their oiling and cooling can deal with it with no issue. Any "increase" in wear by running consistently at high RPMs over the life of any engine is so small that it is meaningless.
What engines don't deal well with is frequent extreme and abrupt changes in RPMs especially if you go into a sudden over/max rev situation. An engine can go forever at redline but one sudden change from 1,000 RPM to 7,500 RPM could cause irreversible damage.
I find it fun that on a forum where people love to boost their engines, change tunes, run high grade fuels, etc there are so many that are worried about the "damage" driving at high RPMs will cause.
Old 01-23-2020, 11:42 AM   #439
Most gas engines are designed to operate at high RPMs. Their oiling and cooling can deal with it with no issue. Any "increase" in wear by running consistently at high RPMs over the life of any engine is so small that it is meaningless..
Exactly, the worst thing you can do for an engine is NOT run it. That's where the "old people" analogy that @Th3rdSun uses comes into play. If you leave your car parked in the garage, or just idle it around town that is the equivalent of me never getting up and moving. Do that long enough I WON'T be able to get up and move.
Old 01-23-2020, 12:58 PM   #440
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
So you are saying you ruined it then? You have less time to enjoy the acceleration and therefore it is less fun.
The Following User Says Thank You to Spuds For This Useful Post:
Will BRZ (01-24-2020)
Old 01-23-2020, 01:03 PM   #441
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
More power is never less fun. Not needed, but less fun? Nah. Not very usable on the street maybe, but since I'm more track focused more power will never be bad. Just have to keep the brakes and handling balanced with the additional power.
But low power is fun too. Hell I still track the BRZ and it's definitely the slowest car I own. Well the truck is probably slower on track I guess.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Tcoat (01-23-2020)
Old 01-23-2020, 03:56 PM   #442
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Yea, that's it.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
Dave-ROR (01-23-2020), Spuds (01-23-2020), Tcoat (01-23-2020)
Old 01-24-2020, 12:00 PM   #443
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
That's a interesting way of putting it.Never thought of it that way. I will say though that metal doesn't atrophy like muscles,so I don't know if that comparison is accurate,but I understand your point.I'll give you plastics and rubber though.
I'll also say that from a value standpoint though,many more times than not,you are way better off with a car with low mileage and usage than the opposite.
Th3rdSun is offline   Reply With Quote
The Following User Says Thank You to Th3rdSun For This Useful Post:
Dadhawk (01-24-2020)
Old 01-24-2020, 12:20 PM   #444
No you are better off with a maintained car with low mileage and usage. One that has just sat untouched in a field or even garage will lose value greater than one that was driven.
Metal most certainly does suffer from atrophy if not maintained or used!
Old 01-24-2020, 12:41 PM   #445
As @Tcoat says it does in a sense. If the parts of the engine sit, and is not lubricated, it will corrode. It will also be more likely to damage itself when it starts up. This goes for other parts of the car as well.
Tcoat (01-24-2020)
Old 01-24-2020, 02:51 PM   #446
Th3rdSun
But wouldn't that depend on where the cars are? Metal take much longer to rust in the desert than say near coastlines. Maybe that's why some of those filthy rich Arab dudes have multi million dollar car collections in climate controlled garages,that they never drive,and they stay in mint condition.
Old 01-24-2020, 03:19 PM   #447
It doesn't have to rust to seize up solid. If we are talking climate controlled environments for cars then we need to apply advanced medical attention, fitness programs, perfect diet, etc to the people we are comparing it to.
The statement was that people sitting around doing nothing can not all of a sudden become active but cars can. Even those perfectly maintained, climate controlled collector cars that are never run would be a serious risk if you just hauled it out of it's showroom and ran the crap out of it right away. Hell, half this forum had a hissy fit when some shop revved a car twice after running for 10 minutes so how can it now be OK for a car to sit for long periods and be perfect as soon as you start it again?
Hoahao (01-24-2020)
Old 01-24-2020, 03:39 PM   #448
..Maybe that's why some of those filthy rich Arab dudes have multi million dollar car collections in climate controlled garages,that they never drive,and they stay in mint condition.
It's because they have a squad of mechanics that make sure they are maintained, but yes the condition would vary depending on the storage mechanisms. Even just starting up a car that has been sitting with fuel in it's tank (which spoils) for a few years will cause havoc if not treated or maintained properly before the car is started up.
It doesn't have to rust to seize up solid. ....
Yep, pretty much what I was saying.
Tcoat (01-24-2020)
CNET on 86: More power would ruin it Guru Woodman FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 52 03-04-2017 06:19 PM
I don't want to ruin my dream car. TruthfulDeception Engine, Exhaust, Transmission 28 03-23-2016 11:40 PM
Wheels that won't ruin the ride Rudiger Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-21-2012 04:40 AM
Will FI Ruin the Balance of FRS/BRZ? ZmZMWagon Other Vehicles & General Automotive Discussions 8 04-13-2012 12:19 AM
Why govt ruin everything 1660 Off-Topic Lounge [WARNING: NO POLITICS] 11 12-27-2009 04:52 PM
