#4453 |
Drives: 2013 Firestorm FR-S
Ah, oh well. That's what I get for half-assed playing around in STX.
Btw, anyone looking for a header? haha :P
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#4454 | |
Drives: Raven 6 speed Manual FRS
That's about what I'm at, but last year I was able to get -2.0 without the inserts :'(. So much understeer...
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel. |
#4455 | |
Drives: 2015 FR-S
| The Following User Says Thank You to 86_Freak For This Useful Post: | Shark_Bait88 (09-30-2016) |
#4456 |
| The Following User Says Thank You to ModBargains.com For This Useful Post: | Shark_Bait88 (10-04-2016) |
#4457 |
Drives: 15 Impreza
Had the last event for the season here in upstate NY on Sunday on a set of RE71R's. Settled on 34psi front and 31psi rear hot after a few runs. Does the wear look alright? From what I've read the recommendation was lower the the tire pressure until the roll over was at the triangles. Does the wear on the face of the tread look normal, there seems to be a lot of rubber? Hopefully I wasn't over driving! I don't remember my original set of falken rt615's wearing like this, though they were a much harder compound.
Does anyone have recommendations on a set of street/autox pads? The grip on these tires is insane, the brake pads could use some more bite! Front ![]() Rear
#4458 | |
btr.life
Drives: 2022 GR86
![]() I like Ferodo DS2500 or Hawk HPS/HP+ for brake pads. Used them in both street and ST class cars.
#4459 |
The triangles really aren't useful for that on most tires, I'd really only do that on a street tire that doesn't belong on autox/track, a tire temp gauge works wonders at reducing the guesswork on pressures, hell it'll probably pay for itself in a year or two as you don't spend all day guessing and potentially making the wrong call, scheduling a T&T and burning up the tires just to figure them out by trial and error.
I've used 4 sets now in 3 different sizes, from 205 to 245, 26-29 psi cold/ambient, 28-34 psi hot is in the ballpark depending on the conditions and specifics of the car. On brake pads the oft repeated options are Carbotech AX6, Project Mu HC800, and Ferodo DS2500. I'm sure there are other options out there that people like (Hawk, Winmax), but stay away from 'sporty' street pads imo, Carbotech 1521, Project Mu NS400, TRD, and probably Stoptech just aren't much up to the task imo. I'm probably going to pick up a set of AX6 or HC800 for my STX car when I burn up my current pads (NS400). My only worry is how loud they'll be but hopefully I'll be autoxing enough to keep them bedded in. |
| The Following User Says Thank You to strat61caster For This Useful Post: | TMF (10-20-2016) |
#4460 |
Drives: 2014 Subaru BRZ
No autox course is going to generate enough brake heat to worry about, so pad choice is down to brake feel and preference.
If you are doing track work, you need to get a track pad and either a second set of street pads or live with pads that don't really work right off the track (loud, dusty, and accelerated rotor wear). |
#4461 |
Drives: 15 Impreza
Thanks for the insight guys! The triangles aren't useful, but my pressures are in the ballpark.
I was thinking along the lines of ds2500's or porterfield r4s pads. I've had stoptech pads and I couldn't keep them bedded on the rotors, bad brake pedal shake. As long as the pads are quite, have more bite and are easy to modulate I'll be happy. |
#4462 | |
Drives: '14 FRS TT5
Follow my NASA TT5 build here: JHill Motorsports
#4463 |
Drives: '22 BRZ
Looks like big changes coming for the twins... http://cdn.growassets.net/user_files...pdf?1477062058
#4464 |
Drives: 2015 FR-S
And off comes the TRD suspension.
| The Following User Says Thank You to 86_Freak For This Useful Post: | DocWalt (10-21-2016) |
#4465 |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I JUST got my TRD setup where I want it....
I may go to Dixie with the TRD stuff anyway. |
#4466 |
Custom User Title
Well it looks like my RS1.0 under this wording can move to DS. This is the part that worries me though...
[IMG]https://lh3.googleusercontent.com/i_4-64w59opOiqLnvQ7XS6LZ59C2KZNM3GI7pdpEPkebgXP8ZRbNAZ arFX8F9Opyj9vws26ql9_D2pf7gUCEEbjY5VS6IP_BU9uUQcha Ap_wBmeaamet954S3SWL4xl5cPZ7THr8Czgdc1tBoC3t8zNR_z 05DzipPMecU2BQpaUz4irgzEV4EUN7TpUmXEH8hfhaJ8duwEBG BQl8BqXZHSqIkc6vplvFtlgmlv55SK_ssxHMGn9p37eaBihHGe biWvTdN3GKWnHvD6FZ2Xyj0a4fP1PaSkENiYLsfvdKqr8ga0_d 5FnZ_ay1DuEchp4MwVxLRCzAkZPRi1KuqfRrtevhNWElON8jx8 Ovq4dEwTxK4i3bAP2Lusbqak6AeffZZBLbctbL3c5h77aOFbVs IPgMa3fzflE8uuG_T0SuO19D_i_gtTYpMVscI-H_L80XGCECOWslqrYXN2-isjgayIn_hoOzrbhWVHM5N-vuMkI1EAh9xsYxlQjtYDMZouMsZgPvxT3Jw3W5kUjfoG***MjK U62FBIN759ZaIO7hjuNlEZOnVzzPLJ0QU9dcXQwUdyl6Xq9uma YRw_zPs9ElTsPAOLs8B0zEyibZaorjmc6Nsiaj=w592-h463-no[/IMG]
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
| The Following User Says Thank You to Locust For This Useful Post: | strat61caster (10-21-2016) |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
