#421 | |
Drives: '22 BRZ
My instructor pretty much insisted that I get better brakes before doing another event as it's becoming a safety concern and also affecting my ability to modulate as I've had to step up to such aggressive pads. I can't argue that, I noticed the XP12s were noticeably more difficult to release smoothly into the loop curve. It's only money, right? ![]() I do wish I had found you to chat about the brakes in person or get a ride along. Next time...
#422 | |
2022 BRZ Build 2013 FR-S Build |
#423 | |
Drives: '22 BRZ
![]() Sorry for the OT On topic, my brakes were literally my only real issue all weekend. Sounds like the RR brakes fix that
#424 |
Drives: FRS
total noob question here, but when it comes time to replace my pads, how do i figure out what other pads will fit my brakes? i have the sport performance kit which uses the wilwood 4pots up front and have the 0.8" thick version of bp10 pads which i do like, but wondering what my other options are out there and how to figure it out when the time comes...
thanks!
#425 | |
Drives: '22 BRZ
However, you can always use thinner pads like Wilwood's 7416, but you lose some of the pad's "meat" obviously. This pad shape is the same one used for the AP Sprint kit, also used for certain Stoptech BBKs, etc. Do some searching around on the forums and on google for alternatives to wilwood's 7420 pads ![]() Plenty of pad choices out there
| The Following User Says Thank You to DocWalt For This Useful Post: | 8R6 (05-24-2016) |
#426 | |
Drives: FRS
how do you (me in this case i guess) know the pad shape? they all more or less look the same to me lol. basically what made me wonder and start digging around was if the winmax w2 pads will work. i consider myself pretty good at googling info and searching thru forum posts, but man i guess my lack of brake knowledge is worse than i thought LOL
#427 | |
Drives: 2013 WRB BRZ 6MT
#428 |
Drives: '22 BRZ
There are pad cross reference sites out there, just gotta look
Just knowing that the same pad fits the AP kit should tell you a lot ![]() CSG sells the W2, BTW. Not sure if the RR kit uses D50 radial depth or D41 though. D50: http://counterspacegarage.com/winmax...p8350-d50.html D41: http://counterspacegarage.com/winmax...p8350-d41.html
#429 |
Drives: brz
Anyone know that if wed sport tc105n 17x9 35 will fit stage 2 front??thank you
#430 | |
Drives: FRS
that said, tc105 in those specs should fit
#431 | |
Source: http://www.ft86club.com/forums/showthread.php?t=19756. I will also mention that I'm using a 17x8 +35 TC105N replica with the sport performance kit and I have plenty of clearance with this wheel. The real things 17x9 +35 should have even better clearance. |
#432 |
Drives: brz
Thank for the quick reply. . Yes i had the wheel already. will down load the temple and check.. I saw on page 8 there is someone running stage 4 with 17x9 35 tc105n. . Is stage 4 and 2 the same??thank again for all the help ��.last newbie questionis stage 2 better on the track then stage 1??
#433 |
Drives: '22 BRZ
Stage 2 and 4 have the same dimensions that affect wheel fitment, just swaps the rotors for two piece for better cooling.
Stage 2 should be a bit better than Stage 1 on track as it has thicker pads that allow for more wear as well as better insulating the caliper due to the extra pad material. Probably not a noticeable difference other than in pad life.
| The Following User Says Thank You to DocWalt For This Useful Post: | 8R6 (05-25-2016) |
#434 |
Drives: brz
Thank you for all the reply
| Tags |
| big brake kit, competition, track |
| AP Racing brake systems in development | track_warrior | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 872 | 09-17-2017 08:43 PM |
| Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped | GuerillaRacing | Brakes, Suspension, Chassis | 149 | 05-12-2015 06:53 PM |
| AP Racing Factory Big Brake Kit, NOT Competition | Lonergt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-25-2013 05:51 PM |
| Official street racing thread. All street racing goes here! | bkblitzed | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 07-19-2013 12:31 PM |
| Essex/AP Racing Competition Brake System in Development | JRitt | Brakes, Suspension, Chassis | 1 | 06-14-2012 02:32 PM |
