#421 | |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
#422 | |
Drives: 86
THX ^^
I update my rom ja01j Code:
</table>
<table name="Base Timing Idle (In-Gear)(Above Speed Threshold)" storageaddress="1159F8">
<table type="X Axis" storageaddress="1159C8" />
<table type="Y Axis" storageaddress="1159F0" />
</table>
#423 |
Drives: 86
#424 |
ZA1JF10G is up: http://www.romraider.com/forum/viewt...p?f=34&t=12178
#425 |
I've also ported the LC/FFS code across for the OFT
#426 |
Hi @Td-d noticed the new F01C def on github has LC/FFS tables if someone tries to edit those parameters (insert values) a stock non patched rom its probably bricked ecu .
Would it be better if standard defs had those tables removed from def ? ![]() thanks Last edited by steve99; 10-04-2015 at 12:12 PM. |
#427 |
Yeah, ideally they should not be in there for a stock rom - but no, it won't do anything even if you do edit it erroneously - the code is in empty space in the rom, so all you would be doing is changing a couple of long words, which are not referenced, from 0xFFFFFFFF to whatever the float value is.
| The Following User Says Thank You to Td-d For This Useful Post: | steve99 (10-04-2015) |
#428 |
Drives: Bolt ons
Is there a DI injector scalar somewhere in the ROM? The "GDI Flow Rate" table appears to be a correction factor? Surely the injector rate is no 1cc/sec @ 20MPa, 1.2V
#429 |
gdi pressure multiplier check our the differences between an oft petrol and e85 rom is the easiest way thier is also a injector scalar to the pi
#430 | |
Drives: Bolt ons
Sorry what I meant was has anyone discovered the DI injector Scalar, I can see the GDI Pressure Multiplier tables, but surely they multiply a scalar that's yet to be mapped? Anyone got a disassembly handy? |
#431 | |
Drives: UK GT86
GDI Flow rate (Probably the one you want) GDI Pressure Targets A & B GDI Pressure Multipliers A & B
.: Stealth 86 :.
#432 | |
Drives: Toyota 86
There is also another scalar which is used to multiply with the result of GDI Multipliers A and B before the value is passed to the GDI flow table: Code:
<table name="GDI Pressure Multiplier C" storageaddress="10C614">
</table>
<table type="2D" name="GDI Pressure Multiplier C" category="Fueling - GDI" storagetype="float" endian="little" sizey="1" userlevel="4">
<scaling units="" expression="x" to_byte="x" format="0.0000" fineincrement=".0001" coarseincrement="0.01" />
<table type="Static Y Axis" name="GDI Pressure Multiplier C" sizey="1">
<data>Value</data>
</table>
<description>Multiplies GDI Pressure Multipliers A and B before passing value to GDI Flow Table.</description>
</table>
| The Following 2 Users Say Thank You to ztan For This Useful Post: | Kodename47 (10-05-2015), steve99 (10-05-2015) |
#433 |
Drives: Bolt ons
has anyone had issues logging a ZA1JD00G with Tactrix and the G-series logcfg.txt from the first post? I have it logging data (LED's flash differently from the first post, just fast flashing all colours) but the data is wrong. Could the RAM address be different for late 2014/2015 ROM or perhaps I just have it setup wrong...
EDIT: found it here http://www.ft86club.com/forums/showp...&postcount=178 Last edited by benk; 10-17-2015 at 02:52 AM. |
#434 | |
their is a dump of doog ram addresses in the first post you will need to substitute in the appropiate addresses into the old logcfg.txt files. thge tactrix should recognise that old file it will just log incorrect, if its just doing the rainbow colours and not producing a log file or the error file its not connecting to ecu of your logcfg.txt is wrong the file must be called logcfg.txt not logcfg.txt.txt or something and it must be in root directory. dont edit it with a fancy text editor like word, just use notepad so no extra characters are added like formatting stuff. |
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
