Old 05-18-2015, 07:46 AM   #421
DarkSunrise
DarkSunrise's Avatar
Originally Posted by DarkSunrise View Post
If anyone is wondering about engine logs with OFT stage 2 at the track, here's mine.
http://datazap.me/u/darksunrise/trac...og=0&data=1-14
You can see a fair amount of knock in the form of FLKC, although IAM was solidly 1.0 and didn't drop.
In terms of fuel I was running:
- 2/3 of my tank was a bad batch of 93 octane (I filled up the day before my track event and was suddenly seeing knock on the street)
- 1/3 of my tank was 100 octane from the track
Call it 94 octane maybe. Definitely a good idea to add 100 octane or use e85 at the track. Later in the day, I later added another 1/3 tank of 100 octane and the engine was happier - I had much less knock and gained a couple of mph at the end of the straight. It's nice being able to pull on those pesky S2000's!
I had also installed a Perrin oil cooler. Looks pretty effective from the log. Even during the later hotter sessions, I don't think I saw anything north of 235 F. The only downside is I think the oil cooler lines are heating up my stock airbox and increasing IATs by 10 F, maybe more. I'm constantly seeing IATs 20 F above ambient now at speed.
I'll see if I can take some logs with higher mix of 100 octane later today.
Following up on my earlier post, here is a track log with a higher mix of 100 octane, roughly 97 octane:
http://datazap.me/u/darksunrise/data...og=0&data=1-14
You can see FLKC is much reduced. Oddly though, I started seeing progressively more FLKC in later sessions, even running the higher octane. Here's a log from my 4th (and fastest) session:
Even though IAM's remained solidly at 1.0, I might start running the OFT 91 octane map at the track to be safe.
The Perrin oil cooler was great at the track though. Peak oil temps were around 235 F, exactly what I was expecting.
2022 BRZ Build
2013 FR-S Build
Old 05-18-2015, 08:57 AM   #422
steve99
The 91 tune only pulls a bit of timing over 6000 rpm compared to 93 tune.
looks like your getting knock when intake ait temps IAT are higher.
Knock seem ok when IAT below 85 or so but when its 100 your getting a bit of knock
you might try adjusting the IAT vs ignition retard tables below
Try putting -2.11 in the 104F cell and -1.7 in the 86 cell in the Timing compensation IAT table. The current values are zero. That way you don't have to switch tunes and when IAT is below 86F you run full timing. Make sure you put the "-" minus sign in else it will add timing :-)
You might also consider adding some ignition retard to the Engine Coolant Temp (ECT) vs Ignition retard Table.A & B the two tables below the IAT tables shown below
Suggest -2 degrees retard at 212F and -3 degrees at 230 (this is what WRX ECU runs), stock/OFT tune ECT/retard tables A & B have no retard at high coolant temperatures
Old 05-18-2015, 09:14 AM   #423
DarkSunrise
Thanks so much! Will try these changes before my next track weekend.
2022 BRZ Build
2013 FR-S Build
Old 05-21-2015, 01:00 PM   #424
Sleepless
Drives: 2016 FR-S
These logs are running the OTS OFT Stage 2 UEL 91 octane tune at the track.
I'm a noob at looking at the data so am looking for feedback on whether or not I should have the car tuned and why. I run it at the track often and the local gas is 92 and when I go to Calif it is 91, both 10% Ethanol. Sometimes I have access to 100 to mix or I can bring Torco Octane Accelerant.
Goal is to have a safe tune that takes advantage of my mods (K&N, OFH, Perrin 2.5" resonated with their over pipe; stock front pipe with cat).
This log is on 92 gas:
http://www.datazap.me/u/pstoppani/92...0&data=1-11-14
This one is 92/100 mixed 50/50:
This one is 92/100 mixed 75/25:
Sleepless is offline   Reply With Quote
Old 05-21-2015, 02:37 PM   #425
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I just installed a new JDL UEL header. Can someone who knows what they're looking at tell me if everything is running okay?
File titled "RUN1" was a 4th gear pull from ~3k to redline.
File titled "CRUISE1" was a 6th gear cruise at 65-70 mph.
Thanks so much!
Mod list:
K&N drop in filter
Blitz intake tube
OFT Stage 2 91 octane (I run 93 in the car)
JDL UEL header (ceramic coated)
Top Speed Pro-1 Axleback exhaust
Bobblehead is offline   Reply With Quote
Old 05-21-2015, 04:49 PM   #426
steve99
Thanks so much!
Mod list:
K&N drop in filter
Blitz intake tube
Nothing out of the ordinary in their
IAM=1
Bit of very minor knock occasionally -0.6 arround 3000 pretty normal
fuel trims ok
AFR high rpm is normal for oft tune, they are generally on rich side
its easier to see whats going on if you post up your logs to www.datazap.me its free and then you can see graphical log and just post link just dont tick private if you want to share
Old 05-21-2015, 08:06 PM   #427
Bobblehead
Bobblehead's Avatar
IAM=1
fuel trims ok
Thank you, thank you, thank you!
Am I logging enough parameters or should I have more things chosen?
Is there a way to get rid of that little bit of knock?
Should I venture to a 93 octane tune or would I be pushing my luck?
Thanks again!
Old 05-21-2015, 08:21 PM   #428
steve99
Thanks again!
The 93 tune should be fine with 93 fuel.
your minor knock is 3000-4800
the difference between 91/93 tunes is extra ignition timing over 6000 and your not getting any knock in that area.
you could try different brands of 93 fuel that might get rid of the lower rpm knock
or just pull (ie decrease) 0.7 degrees out of the BASE TIMING B table at
loads 0.8 through to 1.1, rpm 2800 to 3200
loads 1.0 to 1.2 , rpm 4000 to 5000
its rearly very minor knock not anything to be concerned about
see here
http://www.ft86club.com/forums/showthread.php?t=61820
Old 05-21-2015, 09:06 PM   #429
P5yk0t1c
Drives: 2014 FR-S
Hey guys,
I am trying to learn here, but I think I am off to a bad start already. I think I may have logged the wrong thing. I am trying to look to see if I need knock correction. I logged the following...can you have a look at it and let me know what I am missing? or explain if I should stop driving my car until I have fixed something.
I think I grabbed the wrong file for IAM....I have "ignition advance"
http://www.datazap.me/u/p5yk0t1c/log...data=1-3-4-5-6
Mod list:
Tomei UEL Header
EVO 3 catback
Ingen CAI
P5yk0t1c is offline   Reply With Quote
Old 05-21-2015, 09:22 PM   #430
steve99
Originally Posted by P5yk0t1c View Post
Hey guys,
Mod list:
Tomei UEL Header
EVO 3 catback
Ingen CAI
Yes be nice to see IAM
It does not look too bad bit of minor knock at lower rpm generally expected on 91 fuel , but rearly need to see if IAM=1
with injen intake you might want to look at LTFT long term fuel trims and AFR and commanded afr, those intakes can throw off fuel trims and afr. see maf scalng links.
see links below on logging knock correction and tune tweaks
Old 05-22-2015, 10:45 AM   #431
P5yk0t1c
Drives: 2014 FR-S
ok, I think I have the correct settings now. Can you tell me if I have anything that I should be looking into?
http://www.datazap.me/u/p5yk0t1c/kno...log=0&data=1-7
Mod list:
Tomei UEL Header
EVO 3 catback
Ingen CAI
Stage 2 UEL 91 octane V2.067
3,500 ft above sea level
Old 05-22-2015, 02:05 PM   #432
Sleepless
Drives: 2016 FR-S
To me it looks like the OTS tune is a bit too aggressive for track use. Anyone agree or disagree?
I think I'll have it custom tuned...
Old 05-22-2015, 03:22 PM   #433
JB86'd
JB86'd's Avatar
Drives: JAWS
Just looking at your straight 92 oct. log, your knock is super minor and it looks fine to me. On 91 oct. I get more knock than you just driving aggresively on the street, and I have base timing pulled, and IAT timing compensation. During autox my IAM dropped to around .8 I think. I'd say you're looking pretty good for track use. (Just my opinion, I am not an expert).
Old 05-22-2015, 03:47 PM   #434
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
would someone mind taking a look at my log from a few minutes of driving with some decent acceleration.
Only thing i've done to the car is OFT stage 1 for 93. Been using shell 93 since day one.
http://www.datazap.me/u/tectoniic/lo...og=0&data=1-13
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
