Old 09-12-2012, 05:09 PM   #421
mact
Drives: 13 GTI
Originally Posted by wootwoot View Post
yup. The 18's will mess up your gearing and slow you down. Keep the stock diameter.
As long as you pair the 18's with proper tires and achieve the same overall diameter as factory, it will not mess with gearing.
mact is offline   Reply With Quote
Old 09-12-2012, 05:20 PM   #422
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
17x9 and a 245 is the optimum setup for lightweightness and grip.
VSGTS14 is offline   Reply With Quote
Old 09-12-2012, 05:21 PM   #423
subatoy
subatoy's Avatar
Drives: subatoy
lets keep this thread Turbo oriented.
subatoy is offline   Reply With Quote
Old 09-12-2012, 05:39 PM   #424
gmookher
you will generally be faster on a 8" rim with a 235/40R17...back to turbines
gmookher is offline   Reply With Quote
Old 09-13-2012, 12:42 PM   #425
Alienate
Drives: 2013 Scion FRS
Maybe a dumb question, but will this turbo kit in any way make it even more difficult to change the spark plugs?
Alienate is offline   Reply With Quote
Old 09-13-2012, 12:47 PM   #426
xxscaxx
Drives: 2013 SWP BRZ
I believe I read that the spark plugs could be changed through the wheel wells, so I can't see this causing an issue. I don't think any of the FMIC piping and whatnot runs close to that area. I'll let AVO confirm that though.
xxscaxx is offline   Reply With Quote
Old 09-13-2012, 01:34 PM   #427
camelflage
Drives: pinto power
Originally Posted by AVOturboworld View Post
Still squarely aimed at the 3600-3800 price point.
Boost for the price of a nice set of wheels and tires..
camelflage is offline   Reply With Quote
Old 09-13-2012, 01:37 PM   #428
mact
Drives: 13 GTI
I wish this were the case. If I read correctly in the service manual, changing the spark plugs requires you to unbolt the motor mounts and lift the engine several inches with a cherry picker to make room for the plugs. I am sure someone will come up with an easier way.
Old 09-13-2012, 01:58 PM   #429
xxscaxx
I had initially saw that but believe someone did it successfully without it. I'll try to find the link/post.
Old 09-13-2012, 02:28 PM   #430
gmookher
why is everyone acting like SUCH a fairy? I'm LOOKING forward to PLUGS!!! (fairy comment not meant personally at anyone, if you relate to this no offense!)
You bought a sports car, now go buy tools and gloves and get under this thing already, if you wanted something hard to work on go buy a porsche, drop the motor and talk about the grief of tight spaces and not owning a lift. or try working on a v8 in a s4. thats tight. I dont see the same amount of waaa waaa on the audi and 911 forums I hang out in
plug swaps on 911s are not fun either
on subarus
accessing the plugs is NOT hard, just a challenge
lifting the motor is NOT hard, its SO light
its scary if you have not done it, but if you can change your oil, and get the car on stands, you can change plugs, and then some, its a very easy engine to access and get to
the problem most will run into is not having the correct tools, hoists, jacks etc
yes there are easy ways an hard way to do things
Old 09-13-2012, 03:06 PM   #431
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
on subarus
you know lifting a motor is impossible if you dont have a motor lift like me. I live in a apartment and its impossible to store it without a garage. The only thing i was feeling bad when i bought this car was having to change the plugs one day because i know it will be a dam impossible task for me. When i owned my evo it took 2 mins to change the plugs.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 09-13-2012, 03:09 PM   #432
gmookher
Originally Posted by WolfsFang View Post
you know lifting a motor is impossible if you dont have a motor lift like me. I live in a apartment and its impossible to store it.
yes indeed
I hear ya, its not like most other scions where you can do plugs at the expense of a little back pain
I did many years as a renter and I totally understand-you just gotta find a guy with a garage and buy him beer!
I'm originally from NJ btw, good to see y'all representing the FRS/BRZ!
Old 09-13-2012, 03:10 PM   #433
WolfsFang
Scrape Master
WolfsFang's Avatar
yes indeed
that would work if i was 21 :| one more year to go.
Old 09-13-2012, 03:12 PM   #434
cnk
Drives: '13 DGM BRZ Limited
I'm sure you could jack up the engine from the bottom. That's how I did my STi motor mounts on my WRX. Just a couple blocks of wood and a jack. Or even better, someone will figure out an easier way to do it when folks start to change out plugs. I'm always up for buying new tools. lol
cnk is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
