Old 04-14-2014, 05:58 PM   #4299
Moletheus
Moletheus's Avatar
Drives: Raven 2014 FR-S
Originally Posted by Gary in NJ View Post
You might be a good candidate for a battery relocation to the trunk. This would allow you to maintain the stock (or larger) battery. The added benefit is this configuration will also allow you to run two dump packs
I was thinking the same thing. More power the better. Im not scared of relocation. I just really want to know if the alternator could keep up with all of it.
Moletheus is offline   Reply With Quote
Old 04-14-2014, 06:00 PM   #4300
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Originally Posted by Jac View Post
Will that surge eventually wear it out? 4 PSI flowing back into the compressor doesn't sound like a good thing.
You got a lot of good answers on this point but I'd like to also mention that as soon as you begin to close the throttle, the compressor begins to shut down. By the time the throttle is closed the compressor is stopped or producing so little pressure that it is insignificant.
With that said, I would not employ launch control or flat foot shifting in your tune because of the potential for excess pressure with a closed throttle. .
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 04-14-2014, 06:00 PM   #4301
fenton
It will be fine as long as you don't run full ac + rear defrost + dual recharge + your stereo at max volume lol
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 04-14-2014, 06:05 PM   #4302
Jac
Drives: Fiat Abarth
Originally Posted by Robftss View Post
Instead of dumping excess pressure the energy is stored in a set of caps by a controlled regen.
Interesting! Thanks for the detail. Why did you choose to do that, verses e.g. venting to atmosphere?
Jac is offline   Reply With Quote
Old 04-14-2014, 06:06 PM   #4303
Moletheus
Moletheus's Avatar
Ill be fine with the single starter batt or the relocation? I had to get a more powerful alternator in my maxima when I relocated.
Last edited by Moletheus; 04-14-2014 at 06:07 PM. Reason: then again that stereo was complete and utter overkill..
Old 04-14-2014, 06:08 PM   #4304
fenton
The only thing that might limit you is the size of the starter battery. There isn't a while lot of capacity there.
The stock alternator is actually quite good in the frs though.
Old 04-14-2014, 06:15 PM   #4305
Moletheus
Moletheus's Avatar
Yea, 130 amps is pretty impressive for this car. Any recommendations for the type of relocated battery? Im also wondering if I should I power the stereo from the relocated batt or the starter battery. Hmmm configuration options...
Old 04-14-2014, 06:18 PM   #4306
fenton
The starter battery is the one you relocate. Most people just use the stock battery.
Old 04-14-2014, 06:30 PM   #4307
Moletheus
Moletheus's Avatar
Cool, so let me get this straight before I spend money. In my proposed instance the entire car will be running off of the starter battery in the trunk except the esc. The esc is run solely off of the two smaller batts in the front. Can I use the extra space in the front for more power to the esc?
Last edited by Moletheus; 04-14-2014 at 06:32 PM. Reason: sorry if this has been mentioned earlier but im only 1/2 through the thread
Old 04-14-2014, 06:39 PM   #4308
fenton
Yes you can run twice as much lead if you relocate the battery to the back.
Old 04-14-2014, 08:46 PM   #4309
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
If I relocate the stock battery to the trunk, do i need to put it in a sealed box that vents to the outside, or is that not necessary anymore?
Old 04-14-2014, 08:57 PM   #4310
Gary in NJ
Gary in NJ's Avatar
If it's a sealed battery you do not need to vent. A battery box is always a good idea.
Old 04-14-2014, 09:00 PM   #4311
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
This is where AGM batteries shine... and what they were really developed for.
Luckrider is offline   Reply With Quote
Old 04-14-2014, 09:05 PM   #4312
Moletheus
Moletheus's Avatar
Has anyone experimented at all powering the esc with lithium batteries?
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
