Old 04-14-2014, 01:16 AM   #4271
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
I sent a question thing on the phantom site but didn't get any response... What is pricing like on this? Can someone pm me? I already have oft for tuning as well.
jebuwh is offline   Reply With Quote
Old 04-14-2014, 01:57 AM   #4272
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Price and how to get in contact with rob are on the first post of this thread .
Installed Mods:
Old 04-14-2014, 02:07 AM   #4273
jebuwh
Village Idiot
jebuwh's Avatar
Wow I'm blind. Hahaha. I've been reading this thread for forever it feels like too. Thanks!
Old 04-14-2014, 09:01 AM   #4274
Jac
Drives: Fiat Abarth
Managed to log a couple of pulls yesterday:
http://datazap.me/u/jac/brz-oft-phantom-sc-za1ja01c
Looks like AFR generally stays between 12-11 which I think is good. Is there anything else i should be monitoring/looking out for?
AFR will sometimes jump to 14/13 early in the pull, normal?
http://datazap.me/u/jac/brz-oft-phan...om=11915-12015
Jac is offline   Reply With Quote
Old 04-14-2014, 09:34 AM   #4275
shif7i7down
Erected Member
Drives: frs
Afr should get better once ltft stabilized. With that said, it's running a bit lean for my taste.
shif7i7down is offline   Reply With Quote
Old 04-14-2014, 10:35 AM   #4276
fenton
I wouldn't say it is lean at all. It is running rich enough to bottom out the sensor at 11.x for almost the entire rev range.
It is normal to see 13 to 14 at the extreme bottom end of the RPM range.
fenton is offline   Reply With Quote
Old 04-14-2014, 11:43 AM   #4277
shif7i7down
Erected Member
Drives: frs
The afr is rich yes. but it's because the tune is running lean and the stft is adding a boat load of fuel. His ltft is considerably lean at 3%, a good percentage to shoot for would be a bit below zero. Around -.7% Sounds good
Should be easily fixed with some maf scaling
*Which should allow for the best afr vs afr command possible.
Old 04-14-2014, 11:57 AM   #4278
HRTROB
HRTROB's Avatar
Drives: Toyota 86
The afr is rich yes. but it's because the tune is running lean and the stft is adding a boat load of fuel. His ltft is considerably lean at 3%, a good percentage to shoot for would be -.78%
Doesn't LTFT and STFT only affect closed loop?
HRTROB is offline   Reply With Quote
Old 04-14-2014, 12:06 PM   #4279
shif7i7down
Erected Member
Drives: frs
Yes you are correct. Look at his log, it's mainly cruising data, which is why i said he's running lean, which is in closed loop as you've suspected. During closed loop, the o2 sensor is utilized to control fuel trim to achieve a theoretical afr of 14.7. which it will use to scale the stft which in turn modifies the ltft to adjust for incorrect maf scalling. But to answer your question, LTFT is used in both closed and open loop, So a better LTFT in closed loop from proper maf scaling will produce a better AFR : AFR command during WOT open loop.
Last edited by shif7i7down; 04-15-2014 at 12:25 AM. Reason: dam i hate auto correct
Old 04-14-2014, 01:06 PM   #4280
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Has anyone done an autox with one of these installed?
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 04-14-2014, 01:51 PM   #4281
Jac
Drives: Fiat Abarth
What happens when I lift off throttle at say 5-6K RPM and my intake butterfly closes? I don't see a recirc/bov on the compressor, does it need one?
Old 04-14-2014, 01:55 PM   #4282
fenton
What happens when I lift off throttle at say 5-6K RPM and my intake butterfly closes? I don't see a recirc/bov value on the compressor, does it need one?
Not much honestly. There isn't that much boost that that rpm. The extra pressure will surge past the compressor when throttle closes.
This is completely safe at this boost pressure.
Sent from my HTC One using Tapatalk
Old 04-14-2014, 02:16 PM   #4283
Jac
Drives: Fiat Abarth
Will that surge eventually wear it out? 4 PSI flowing back into the compressor doesn't sound like a good thing.
Old 04-14-2014, 02:19 PM   #4284
fenton
No it won't hurt this compressor to my knowledge.
I know that Rob has tested this extensively.
@Robftss do you want to comment on this?
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
