#4243 | ||
Undisputed El Presidente
Drives: Zenki 37J ZN6
I always find it hard to try and judge a new Bond in advance since we have no idea what direction they will take the film. It's like listening to the movie's theme song without the intro. Hopefully it's just like a reboot with the next Bond and they make those films like it's own mini universe. |
#4244 | |
Drives: 2018 Subaru BRZ
"How to build a computer" JayzTwoCents Very straight forward guy and no nonsense. I watched that video as I was building mine. A few additional tips. -Fan Cabling orientation makes a difference when dealing with cable management. Chances are that you will place it in the wrong orientation and realize only after once you begin to tuck stuff in. What I recommend is just to experience that because it builds that extra knowledge. -BIOS updates, some MOBOs do not come updated, so if your computer does not post, chances are you need to update the MOBO. Look for a USB port that says "BIOS FLSHBCK", if available, and use that, follow instructions on your MOBO user guide. Only after that you can move on to a possible issue with RAM, CPU, Battery. -If you haven't done so, get a fully modular PSU, you'll thank me later. -CPU will only go in one way, if it doesn't, don't force it. It should slide right into the socket. -Only a small drop of thermal paste is needed. -RAM should be the same brand and specs if using multiple slots. -Patience is key There's a lot more I could say but I don't know the extend of your PC building knowledge. But have fun!
| The Following 4 Users Say Thank You to spcmafia For This Useful Post: |
#4245 | |
#4246 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
NVIDIA announced the 4070 ti at CES as if we didn't expect it. But still!
#4247 | |
I have a bunch of fans and other parts I can send you if you want them. Better thermal paste, AIO pump, etc.
| The Following User Says Thank You to spcmafia For This Useful Post: | soundman98 (01-03-2023) |
#4248 |
Pavement Grey
semi modular is fine, it'll still help considerably with cable management, especially if your case is on the smaller size.
RAM used to be super sensitive to brands and timings but not so much nowadays. However when using multiple sticks, (and you should, when using at least 2 sticks the computer runs in dual channel mode which has something like 30% more performance over a single stick in single channel mode) they should to be paired appropriately (same speed, same timings, same brand), and placed in the slots appropriately as well. You'll notice that most RAM kits come like this. If the motherboard has 2 RAM slots, thats a no brainer. If it has 4, they're usually labelled A1/A2, and B1/B2, and the slots are usually colour matched. You want to pair them as A1/B1 (A2/B2), which would also be the colour match. I think you can pair them as A1/A2 if you want but its supposed to be better when they're colour matched (i stopped reading/caring about the intricacies about why things are the way they are....so i just set it up the way the manual would tell me is the ideal way) I think you can still pair 2 random sticks together, but in the computer world everything will run at the level of the weakest link (so if there are 2 speeds of ram, it'll run using the specs of the slower one). And having 2 completely different sticks may not efficiently. |
| The Following User Says Thank You to Sasquachulator For This Useful Post: | finch1750 (01-04-2023) |
#4249 | |
The Dictater
Drives: '13 Red Scion FRS
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
#4250 |
Pavement Grey
| The Following User Says Thank You to Sasquachulator For This Useful Post: | Spuds (01-04-2023) |
#4251 |
But the age old question, is 16GB enough RAM or is 32 the new standard?!
#4252 | |
Pavement Grey
![]() I'd also say that if your system RAM is equal to the amount of GPU RAM you have, its time to upgrade that system RAM ![]() My main Rig is a Ryzen 5 2600X @ 3.6ghz, 16GB DDR4 RAM and a Radeon RX6600 8gb. And I have another retired work PC that I inherited and will use that as a living room "console" PC. It was equipped with an intel i7 3770, 16GB DDR3, Nvidia Geforce 440 GT, 1TB HD and a generic 350watt PSU which seems underspecced but somehow didnt burn out. I have replaced the PSU with a 750 watt unit, the HD with a 980gb SSD, and the GPU with a 4GB Radeon 290 I had a 1TB nvme SSD i had lying around that i wanted to use for this but the PC is so old it doesn't even have an NVME slot. So now i'll put it in my main rig. Last edited by Sasquachulator; 01-04-2023 at 12:14 PM. |
#4253 |
Oh I just like joking about the RAM thing since it’s always that controversial subject. Like thermal paste amount lol
#4254 |
Pavement Grey
| The Following 3 Users Say Thank You to Sasquachulator For This Useful Post: |
#4255 | ||
Here's what my build is looking like so far.
Ryzen 5600x MSI B550-A Pro mobo Nvidia 3060ti Corsair Vengeance LPX DDR4 (2x8Gb 3600mhz) Cooler Master Hyper212 Evo cpu cooler Corsair CX750-M psu Corsair 220t case Gonna keep whatever SSD/HDD I have for now, but need to upgrade as their fairly small. I think the SDD is 256 or 512 and the HDD is 1TB. Quote:
#4256 | |
No problem. I'd say that is a very fair build. That CPU and GPU will offer plenty of performance. As for SDD, Samsung 970\980 Pros should be fairly cheap now and allow for faster load times and bigger storage. ADATA XPG PRO is also a very solid one too. Do keep in mind that newer games nowadays, at minimum, take up to 50GB, so you can run out space fairly quick. 16GB of RAM is pretty good, I have the same one as you. Other than that, I like the build. Post some pictures once you're done!
| The Following 2 Users Say Thank You to spcmafia For This Useful Post: | finch1750 (01-05-2023), soundman98 (01-04-2023) |
| Tags |
| pc master race, u no have 3080 |
| gamers lounge | Touge_ninja | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 01-21-2014 05:32 PM |
| GT Acadamy Gamers Banned from Britsh GT Pro-Am | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 02-11-2013 07:37 PM |
