#4229 |
94... RON? (MON+RON)/2?
Seriously, I have ZERO clue how your engine is being built. You need to ask your tuner and/or engine builder to advise you. Do you want to be knock limited or at MBT? Garbage in, garbage out. Without knowing everything, I cannot make a recommendation for you. |
#4230 | |
Drives: FRS
#4232 |
Drives: 2013 WRB BRZ 6MT
He's in Canada so I'm sure he's referring to PetroCanada Ultra94. I've seen several reports that it tests similar to American 92-93.
| The Following User Says Thank You to Lynxis For This Useful Post: | CSG Mike (10-27-2017) |
#4233 |
#4234 |
Drives: frs
Bypass valve update. Today I had to replace that valve again. I had the warranty part fail today while I was on track. Thankfully I was able to source a replacement after a 115 mile round trip. Theres either something faulty in the material or design OR Im installing it wrong but I dont think its a faulty install as it follows the same routing and positionin the manual.
Whats up with that? Last edited by amcp1; 10-28-2017 at 07:17 PM. Reason: Speelling |
#4235 |
Do you have a pic of your failed parts?
#4236 |
Drives: frs
I can snap a pic of the bypass valve but Im not sure it would help. Looks just fine but the inner diaphram is broke.
#4237 |
pessimistic skeptic
#4238 |
Drives: FRS
#4239 |
Famous Potatoes
Drives: '15 ultramarine
My C30 has suddenly got REALLY loud at idle. This means it's defective? I have an email to tech@jacksonracing, waiting for a response.
#4240 | |
Got a video? Alternatively, release the tension on your belt, and try turning the SC pulley by hand. It should turn readily. (Just push the tensioner down, and slide the belt off to release tension; leave everything else in place.) |
#4241 |
#4242 | |
Famous Potatoes
Won't let me upload an mp4 file. |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
