Old 04-02-2014, 08:26 AM   #4201
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Originally Posted by RSConsulting View Post
Not for nothing - but are you running FLAT FOOT SHIFTING in the RaceRom options in your tune?
Bill (Delicious) REFUSES to add this into his tunes now - as he reports belts SLIPPING AND SHREDDING when FFS-ing.
Just something to consider - don't know if this affects you in particular.
As a matter of "introduction" - I put my Innovate on, while I still had the paper tag on it. After running a 14LB Magnusson blower on my LS2 Corvette (AFR Heads, Custom Spec'd Comp Cam, Snow Progressive Methanol - 650RWHP/670RWTQ) there is NO WAY I could ever drive anything but a TwinScrew for an FI motor.
I'm running a Raceseng 70mm, Perrin Crank Pulley, "regular" Gates Belt (have blue one - just haven't gotten around to installing), Delicious Tune.
Rick
nope, no FFS anymore. though it does seem that belts pop when i do a burn out, which makes sense. SC spinning at max RPM = unhappy belts and apparently tensioners.
wrxgoose is offline   Reply With Quote
Old 04-02-2014, 08:35 AM   #4202
swift996
swift996's Avatar
@calispec you might be able to cobble together a customer heat exchanger if you want more capacity.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 04-02-2014, 02:21 PM   #4203
TemeCal
Drives: 86
Originally Posted by TemeCal View Post
I'll reproduce it tomorrow, and upload the logs for you to review.
Bill @DeliciousTuning ,
I just opened a ticket (#287), and uploaded a few logs. I noticed in the logs, my Advance Multiplier seems to hover around 0.47 and 0.52 now (used to be solid at 1.0). I also noticed (in my cold log), that knock correction seems to drop to -0.7 right around the time it stumbles.
Hopefully the logs will provide some useful info.
Thanks!
TemeCal is offline   Reply With Quote
Old 04-02-2014, 06:17 PM   #4204
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Is there a single place to review dyno sheets for Innovate S/C builds? I ask because I queried Innovate for HP/torque data for a Stage 2 build, and they directed me to this thread; I think I found 5 dyno sheets here - was hoping to find more, ideally with build specs (which are probably in everybody's build threads :pain: ).
Thanks.
dradernh is offline   Reply With Quote
Old 04-02-2014, 06:21 PM   #4205
KSpider
KSpider's Avatar
Drives: '14 S4
What is on the first page of this thread is prob best you will get without querying each person individually etc.
2014 Audi S4 · 2010 xTerra Off-Road · 2014 Fiat 500e
KSpider is offline   Reply With Quote
Old 04-02-2014, 06:26 PM   #4206
dradernh
You know, I didn't catch them there; saw the S/Ns and the user names, and didn't keep looking right. Thanks!
I'm probably going to have more success posting up a possible build, and then asking owners if they've got something similar (with numbers) or want to make a scientific wild ass guess as what it would produce on a given dyno model with a specific fuel octane.
Old 04-02-2014, 07:17 PM   #4207
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Innovate (Sprintex) Supercharger Owners Topic
@DeliciousTuning, I just sent you a bunch of logs Bill, via email.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 04-02-2014, 08:49 PM   #4208
Calum
That Guy
Drives: 2013 asphalt FRS MT
Thanks.
first post.
Old 04-02-2014, 10:23 PM   #4209
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Apparently I did a bad thing. Not trying to get banned.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 04-02-2014, 10:34 PM   #4210
xjohnx
Grip>Slip
xjohnx's Avatar
Ordered one. Thanks!
Also going to try and get some dyno time Friday or Saturday to see how she's doing with the intercooler, 70mm, Flexfuel and nameless header. We'll see if the dyno has any availability.
Old 04-03-2014, 09:13 PM   #4211
CK_Bladesmith
Drives: Raven FR-S
Anyone heard from Bill about the issues regarding 8.51?
Old 04-03-2014, 09:32 PM   #4212
TemeCal
Drives: 86
Nope, but it usually takes quite a few days to hear back after I submit logs. I'm concerned about the advance multiplier being under 0.5 though. How does yours look, just driving around town?
Old 04-03-2014, 09:35 PM   #4213
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
What fuel are you seeing it drop on? I've been using his 8.52 flex fuel tune and noticing anytime I change the e content in the tank the multiplier freaks out for a day, but then stabilizes back at 1.(going from e70 to e10 at least, haven't tested going back the other way yet).
mikalem is offline   Reply With Quote
Old 04-03-2014, 09:41 PM   #4214
wrxgoose
WUB WUB
my dyno sheets are in the first post of my build thread, others may have it the same.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
