Old 06-03-2016, 01:36 PM   #4201
Biggins
Drives: Yes
Originally Posted by SeanRTR View Post
New tires didn't seem to have the same grip as my 'worn-in' 225-47-17's, but that was to be expected.
How many runs do you have on yours? I flipped mine after 75 runs since they were near cording on the shoulder and have ~95 on them now and are still fast. My Kumhos have over 50 runs on them now and look brand new.
Grease them every 20-30k miles at least. Turn in response seems improved in the round-abouts with the 21mm front bar, and balance seems much better. Hopefully I'm not giving up too much in the slaloms. We'll see how Sunday goes.
Thanks for the heads up on the bushings. Is the Perrin 22 you have adjustable?
Biggins is offline   Reply With Quote
Old 06-03-2016, 02:28 PM   #4202
SeanRTR
C-Street AutoX
SeanRTR's Avatar
I don't really count, but I assume 60-80 runs on my 225 45 17's....I've not yet needed to flip tires on this car for any set of tires I've gone through yet. Very minimal sidewall wear if you rotate tires front to rear often enough, and they always wear flat across the tread for me.
The 22mm Perrin is adjustable, and I ran mine on soft.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 06-03-2016, 04:50 PM   #4203
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
After reading someone else's post about what pressures they run on their Bridgestones I'm curious now what are you guys running? Someone said they tried running higher at 35/32 and it worked well for them but I've found that 29/27 gives me the best results. Am I way off from what everyone else is doing? A bit hesitant to test it right now since I don't have any non-comptition runs in the next three events.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 06-04-2016, 03:28 PM   #4204
86_Freak
86_Freak's Avatar
Drives: 2015 FR-S
Here are my videos from Spring Nationals. Like I said, I had low air pressures on day 1 and it felt like crap, raised them up for day 2 and felt much better.
86_Freak is offline   Reply With Quote
Old 06-14-2016, 11:39 AM   #4205
klittl06
Drives: FRS?
What's everyone's thoughts on 2017 changes in regards to c street? This includes a tad more hp/torque, bbk, gearing changes, and damper (and spring?) changes.
Sent from my SM-N920V using Tapatalk
klittl06 is offline   Reply With Quote
Old 06-14-2016, 12:21 PM   #4206
strat61caster
strat61caster's Avatar
I'd say both those numbers are spot on for the Bridgestones I've been running (and coincidentally my old ZIISS), although not directly comparable as they're not 215/45/17. I set them ~30 psi in the morning and they end up around 34 hot, bleed off as necessary to keep the tire from ballooning depending on what tire gets worked the hardest.
A pyrometer has been well worth the money to take the guesswork out of tire pressures.
ineedyourdiddly
Old 06-14-2016, 01:11 PM   #4207
AlanLGuy
Drives: Raven 6 speed Manual FRS
Not worried about 5 hp/tq peak, more interested to see a dyno to see if they worked on that torque dip.
The bbk is just extra weight with no real benefit for autocross imo.
Gearing is going to be... interesting... Not sure how I feel about it. We have options to tweak with wheel diameter and tire height, so it might not matter much
Damper changes.. Who cares
Spring changes... good for BRZ, irrelevant for FRS unless they move the non-TRD to DS.
More worried about how the CS/DS thing shakes out. If given the option I'll take off the TRD parts and go to DS... I think the ND is an overdog, like my chances against the WRX better
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel.
AlanLGuy is offline   Reply With Quote
Old 06-14-2016, 01:57 PM   #4208
86_Freak
86_Freak's Avatar
Drives: 2015 FR-S
Agreed about the CS/DS. If the non-TRD is moved to DS, I'll be taking my springs off to go against the WRX.
Old 06-15-2016, 02:59 AM   #4209
Locust
Custom User Title
Locust's Avatar
Ya I used a pyrometer to get to 29/27. Checked for tire temps on all 4 corners for 6 events to confirm.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 06-15-2016, 05:06 AM   #4210
TEAMETR
TEAMETR's Avatar
Drives: 2016 FRS
Reclass and Move FRS
The stock FRS can not compete with the so called PORT installed TRD springs and sway bar cars in autocross. Some claim they were PORT installed but were self installed parts. I have sent in my letter to SEB to change the rules like many have done already. To move NON TRD cars to DS. Send in your request SEB for rule change at https://www.crbscca.com/index.php?page=submitLetter
TEAMETR is offline   Reply With Quote
Old 06-15-2016, 07:06 AM   #4211
AlanLGuy
SCCA Solo C Street Discussion
Originally Posted by TEAMETR View Post
The bone stock FRS can not compete with the so called PORT installed TRD springs and sway bar cars in autocross. I have sent in my letter to SEB to change the rules like many have done already. If you support this rule then send in your request for rule change at https://www.crbscca.com/index.php?page=submitLetter
The SEB did receive many letters and already responded that the TRD springs and swaybars are legal for Street class. They aren't going to change their mind about that. The best thing you can do is write a letter in support of the move of the non-TRD cars to DS.
The parts are legal, there is no question about that as far as the SEB is concerned. The options are to move TRD or non TRD cars to a different class or somehow convince the SEB to re-write the rules to allow the BRZ to equip the TRD parts.
It's a raw deal for the BRZ, but we are talking a tenth or two of a second, which by no means puts them out of contention for a win with a good driver.
Old 06-15-2016, 08:36 AM   #4212
NJ10
Stiggasaurus Rex
NJ10's Avatar
Drives: '14 WRB Subaru BRZ 6MT
I think someone mentioned this at Toledo too, I'm really looking forward to see a twin compete in both CS/DS if that happens. It is totally plausible to switch out the strut assemblies and swaybar between CS and DS with a good pit crew.
meh.
NJ10 is offline   Reply With Quote
Old 06-15-2016, 09:06 AM   #4213
JimR
JimR's Avatar
Drives: '15 FR-S, '92 Sentra SE-R
The BRZ, FR-S, ND MX-5, and RX-8 have all gotten it done in CS National Solo...in the last four months.
The perception that there is a grand gulf of performance between a BRZ and TRD FR-S - laughably, coming mainly from the fan club for the two cars - doesn't match the reality. In the grand scheme of the Street category, both cars fit very neatly within the noise range of what constitutes CS class. And at the moment, CS is a popular and diverse class.
The ND MX-5 could and will likely build an edge in the CS trophy case over time. It's lighter, has better suspension geometry, and accelerates better. You still have to make the case that the twins, RX-8, NC MX-5, etc., have enough of a performance disadvantage to break the CS mold and not totally upset their destination class. Good luck.
For fun, let's say you convince the Solo board to cherry-pick the '13-16 BRZ and non-TRD FR-S for DS even though, honestly, we're mainly getting beaten by better drivers. Then I'm going to write the letter that all '13+ FR-S/86/BRZ go to DS because the ND MX-5 "beats" the whole lot. See how the deck chairs get rearranged?
JimR is offline   Reply With Quote
Old 06-15-2016, 09:16 AM   #4214
AlanLGuy
Who needs to convince them? It's already been proposed and is out for member comment... YOU(or anyone else who doesn't want it to happen) need to convince them that the BRZ/non-TRD FR-S should NOT be moved.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
