#407 | |
Drives: DMG Subaru BRZ
I'll start with the stock tunes, then try wayno's mods when I figure out how to do it. Thanks again! |
#408 |
#409 |
Drives: 2014 86 GTS
So I drove a completely stock blackline edition 86 and noticed that it was much smoother on the transition from on-off and off to on throttle, is there anything in terms of software tuning that can be done to add this to the e85 tune (even if it means some extra fuel consumption) ?
#410 | |
Drives: Toyota 86 GTS
For AT use MT throttle map (on E85 only). When you add 20-30% more power over stock, try using 30% less throttle. |
| The Following User Says Thank You to Wayno For This Useful Post: | 504 (03-20-2016) |
#411 |
New screens
#412 |
Drives: UK GT86
@Wayno, what's the reasoning behind the 25% PI at 2400-2800? If the thresholds are still OEM then this will result in 0% being output as you're below both the load and RPM thresholds.
.: Stealth 86 :.
#413 | |
#414 |
Update for 98RON.
| The Following User Says Thank You to Wayno For This Useful Post: | ollie (04-13-2016) |
#415 |
I'm sorry if this a stupid question or it has already been answered but I did search the thread. It looks like all of your tables are related to US E85 and Australian 98 RON fuel. Is there any information for someone like me who has to run US 91 octane because of availability, would the 98RON tables be similar? Thanks.
#416 | |
#417 |
Updated today.
- A new, smoothed throttle map for AT which I've put off doing for about a year. - Minor timing and fuel changes. - 98 and E85 now have the same knock correction advance so base timing is directly comparable. - 98 and E85 now have the same closed loop fuel maps, in preparation for open source flex fuel. - 98 and E85 now have more comparable open loop fuel maps. |
#418 |
Super curious to see what you've been able to do. I've messed with my throttle maps a few times now to try to adjust it for the tweaked power band, but have always ended up reverting.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#419 |
Why don't you just use your eyes then. There's a screenshot under what you just quoted.
#420 |
As in its effectiveness, not the tables :P
| Help uploading 2.06 tunes to OFT | Jimmy817 | Software Tuning | 3 | 12-28-2014 10:06 PM |
| Custom Az Tunes | Juggles | Arizona | 13 | 11-08-2014 11:15 AM |
| EcuTek Tunes | Rio | Engine, Exhaust, Transmission | 1 | 04-29-2014 01:10 AM |
| How long until *other tunes? | ScionFrsFan | Engine, Exhaust, Transmission | 61 | 12-07-2012 06:34 PM |
| Speedhunters - TRD TUNES THE 86 | quik1987 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 69 | 05-22-2012 05:26 PM |
