#407 |
Fucks sake, this shit doesn't fit the Australian bracket.
So much for universal, not even worldwide... |
#408 | |
Drives: Scion FR-S
I would be shocked if it is different for you AU guys. Post a pic of the issue you're having!
Andrew
2013 Scion FR-S MT (Silver) 2011 Toyota Rav4 Sport V6 4wd (Silver) |
#409 | |
Drives: Scion FR-S
Also go into settings under car settings and make sure your reverse camera is set correctly. As to the aux port, I had fuzzy sound when my pins where not fully seating. Check to make sure they are getting good contact. Otherwise i'll double check the exact wiring for the Aux jack in the next day or so when I get a chance to yank my unit. Its literally been a year since i wired my aux jack in for a aftermarket unit
Andrew
#410 | |
Drives: 2013 WR Blue Limited Manual BRZ
#411 | |
what was that "amp-on" wire for, and the "back" wire I'm assuming is necessary for a reverse camera? |
#412 | |
As for the Back wire, that's for a reverse camera but I'm trying to figure out where that goes... |
#413 |
Because Racecar
Drives: 2013 Lightning Red Subaru BRZ
Same problem for me. Wired the reverse out from the HU to the Rydeen Duo wire, but no luck on the reverse camera. If you figure it out, please post.
#414 | |
Looks like that's where we put the "Back" wire? As for the Rydeen duo power cable, I'm not sure where I'll plug that into. I'm assuming there's no power source coming from this HU that only supplies power when in reverse like the stock HU, so I guess it's find a 12v pin I can tap. |
#415 |
How do you install navigation on this, tried sygic, Map factor , navfree all of them unable to work..
Edit: got navfree working, any got sygic going, crashes on start for me Last edited by eliminist; 05-06-2014 at 03:17 AM. |
#416 |
Drives: 2014 Scion FR-S
Cant wait. Radio now in Cincinnati. Damn weekend/Chinese holiday
Sent from my GT-N5110 using Tapatalk |
#417 | |
#418 |
Delivered to office just now! Install tonight!
Sent from my SM-N900T using Tapatalk |
#419 |
More research done and found this: http://i.imgur.com/hKFSVgy.jpg
So not only telling us where the reverse trigger wire is, but if you look at the bottom left 3 pins, you have the AUX left, ground, and Right pins, I think my right or left is in the ground position, so that should fix my audio problem as well. Another thing about the reverse trigger wire, it's 12v, so I'm thinking I can use that for not just the "Back" wire going into the Ca-Fi, but also the power wire going to the camera. I will try this and let you know how it goes! Edit: I just remembered my Rydeen Duo only requires 6v, so I guess can tap into the CA+ pin to on the 16-pin harness in that picture. If anyone else has any suggestions feel free to chime in, I'm just wingin' it right now :P Last edited by Deathalo; 05-06-2014 at 01:51 PM. |
#420 | |
Because Racecar
Does this mean the Orange/White wire connects just to the HU, or to the HU and lead from the Rydeen Duo? Any idea? |
| REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo | SHIFTER | Electronics | Audio | NAV | Infotainment | 16 | 06-13-2017 07:23 PM |
| Android, bluetooth, Music, and the FR-S stock pioneer stereo | JayNutter | Electronics | Audio | NAV | Infotainment | 27 | 12-18-2014 04:54 AM |
| How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 | SHIFTER | Electronics | Audio | NAV | Infotainment | 29 | 04-07-2014 05:58 AM |
