#29 |
Drives: 2013 Black FR-S
your making too much power with that JRSC lol
#30 |
What's the reasoning? Over spinning the SC with the high boost pulley?
#31 | |
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
Did you drived hard with no problem? |
#32 | |
2. What do you think shock loads like that do at 100,000 RPMs? That's how fast the Supercharger is spinning (technically about 95,000-96,000 at redline...) |
#33 |
Oh no doubt, just based on your post that specifically mentioned the HBP I was curious if it was more about over spinning it, or the bouncing off the limiter part.
#34 |
#35 | |
Fast enough
Drives: 2013 Subaru BRZ AT
I still am having trouble seeing how this is happening due to how you claim it is happening. Jerk is the derivative of acceleration. However (under a non-changing moment of inertia system) acceleration once a force is removed is zero. That seems to pose an issue. The link you provide here says exactly that.... I also understand math and am actually a mechanical engineer as well. What you are essentially saying is that if I have an electric motor with flywheel on the end and I spin up that motor such that it's velocity is exponentially increasing...(think constant jerk, linearly increasing acceleration) and then I turn that motor off.....you are saying that motor will continue to spin faster AFTER that torque is removed for a short while. This is not possible. I see that data and postulate that something is going on with an inertia change of the rotating assembly being decoupled from the transmission. I don't see how Jerk can have anything to do with it since the force torque is zero. What would be interesting is to see what would happen if you left the car in gear whilst hitting the rev limiter. Your RPM doesn't increase until you clutch in. My guess is RPM would NOT increase past the rev limiter in that scenario. Also what mods are on this car you've presented?...just curious
| The Following User Says Thank You to xsnapshot For This Useful Post: | Ultramaroon (01-10-2016) |
#36 |
Fast enough
So then what is one to do? No one addressed my initial question of whether or not the AT can be programmed to start it's shift sooner.
I had this same problem in my 2004 WRX AT, and the only solution I had for that vehicle was to raise redline from 6900 to 7050 (I think...it's been a while. I remember I had to raise it a small amount). That gave the AT enough time to complete it's shift before I hit the rev limiter. In this vehicle however, I don't want to increase my redline past 7400 RPM. |
#37 | |
Fast enough
Plenty of people are running much more than 300 bhp through their AT's. I guess only time will tell how they hold up. So far mine has been fine but I don't have many miles on it yet. |
#38 | |
not playing cards
1. The clutch switch recorded is the starter interlock, not the cruise cancel. 2. The sample rate for all but the tach is 10 Hz. 3. We acknowledge the latency between throttle command and servo response is a factor. I regularly hear a little extra "vroom" when I disengage the clutch and attribute this to DBW latency. If the above are true, it appears that we are looking at a single bounce off of the rev limiter because the engine is unloaded while still on the throttle. I see the loss of gear indication before clutch disengagement. The only way to explain the below sequence of events is if the wrong clutch switch is being recorded. ![]() Comments?
#39 | |
- Result in zero acceleration - Result in negative acceleration - What would the net result be in angular velocity on the flywheel itself? The car from which this data is presented, is from a JRSC, in CARB trim ![]() Some anecdotal data: With a (hard) redline of 8400 on my Honda, this is what happens when approaching it at WOT: - Hitting the redline in 1st gear, results in an overrev of approximately 8800 - Hitting the redline in 2nd gear, results in an overrev of of approximately 8750. - Hitting the redline in 3rd gear, results in an overrev of about 8600 - Hitting the redline in 4th gear, results in ~8530. - Hitting the redline, in 3rd gear, on a downhill grade of about 18 degrees, results in an overrev of 8700+ - All of these are with the assumption that the car is kept in gear, throttle pinned, and effectively "riding the limiter". - Data is all taken from my personal S2000; this type of "abuse" is something I can't, in good conscience, do to someone else's car, unless specifically asked to (which is why I don't have this type of data with a FA20). - Tune is Speed Density (as are all S2000) - Testing was performed to determine what redline I actually wanted, so that I see the max rpm that I want to see, as there are places where I will actually want to ride the limiter, and will hit the limiter hard. - Approaching the redline softly (part throttle, but open loop), results in it never going over 8430. Other food for thought. Engine output is not a constant, but a very rapid series of torques. Can the torque of an individual combustion cycle actually cause RPMs to rise that much? This isn't math I've actually done; just theory, as I have no idea how to compute the losses, but a quick google would indicate about 75% of the energy would be lost. |
#40 | |
![]() The hard pivots are from the data being recorded at a slower rate; you're correct in that many channels are 10 and 5 hz. They're the ones I usually don't really need to worry about, so are polled lower. The data here is mostly at a higher poll rate, but unfortunately it's super old before I started logging everything at 50+ hz. It's from the same data set, but zoomed in more.
#41 | ||
Fast enough
1.) the throttle plate closing causing motor to quickly see a vacuum thus causing a change in the inertia of the system. (doesn't seem like a strong enough effect). 2.) something happening with the decoupling of the drivetrain from the motor I don't really have a good answer for this. Quote:
I can't see any single combustion event raising RPM's as much as you are seeing. That's quite a rise...400 RPM. According to your data it's happening for 1/10th of a second. At ~7000 RPM that means the motor is accelerating for 11 revolutions beyond the limiter. What kind of rev limiter do you have in the S2000? A hard rev limit? Ignition cut? Fuel cut? Soft rev limit? Would you happen to know if a soft rev limiter would fix this problem? I had that NA and on the rare occasion I hit the limiter, it sure seemed a lot "nicer" on everything than the hard limiter. Last edited by xsnapshot; 01-11-2016 at 01:11 PM. |
#42 | |
not playing cards
| Where Do You Set Your Rev Limiter? | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 06-10-2014 05:48 AM |
| Wheel hitting tie rod? | OakmanSmalls | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 07-16-2013 06:17 AM |
| BRZs hitting Tampa, FL! | FLHC | BRZ First-Gen (2012+) — General Topics | 63 | 07-24-2012 11:20 PM |
| Rev limiter? | feldy | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-03-2012 11:47 PM |
| <3 my rev limiter | NESW20 | Other Vehicles & General Automotive Discussions | 1 | 05-03-2010 12:05 AM |
