Old 01-04-2016, 05:54 PM   #29
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
Originally Posted by celek View Post
Head is not the limiting factor it flows around 270CFM at .470 Lift in stock form the head flows fine and with minor work it can make 700+ WHP with a turbo. Bigger valves are a waste in an NA platform. The limiting factors are cams, springs retainers, rockers and the factory intake manifold.
Celek
I follow your build thread , can't wait to see your dyno ?
Toyota86.ir is offline   Reply With Quote
The Following User Says Thank You to Toyota86.ir For This Useful Post:
celek (01-12-2016)
Old 09-09-2016, 03:57 AM   #30
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Originally Posted by jsimon7777 View Post
Most people will do just great in 25 minute sessions with just a big oil cooler and maybe a radiator. You, however, are some other kind of beast. On a 100+ degree day, all bets are off. I've seen a well-prepped Jackson SC overheat on a 115 degree day.
I've seen a turbo car overheat in 1 lap and Jackson SC cars overheat in 85 degree weather. The blessings of racing at 4000+ feet elevation. The air is so thin it has near zero cooling capacity.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 01-18-2017, 09:08 PM   #31
JustAnEngineer
Drives: Nissan Versa
How much more power would a built engine with a 9000 rpm redline like this make with a centrifugal supercharger (like JRSC) over a stock engine redline (also with JRSC)?
Ignoring all the peripheral mods required to get this all running. My understanding is that higher rpm would allow you to hit more boost but would it just be marginal? Just curious from a theoretical point.
I know a few things about a couple things
JustAnEngineer is offline   Reply With Quote
Old 01-20-2017, 09:20 PM   #32
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
The problem is the mods aren't peripheral. The stock engine can go a bit more without mods but I believe I've read the highest is 8200 or 8300 rpm's before the oil system cannot keep up any more.
If you check out the link to element tuning, they dress up all sorts of fancy parts and the like but then admit they made wholesale changes to the engine to get enough oil into the engine.
A fully built engine is really the only way to hit 9k without the engine being a time bomb, and when you see the prices on that link aka $7400 to really get the power from the revs, is it really worth it to you?
Element Tuning's Time Attack Roll Cage. MA-Motorsports Review Element Tuning Tracking / Autocross / HPDE / Drifting 21 04-25-2017 01:51 PM
Element Tuning Raven Black FRS Track Build Element Tuning Member's Car Journals 130 04-04-2016 03:13 AM
Element tuning Hydra EMS mike the snake Software Tuning 29 03-29-2016 10:08 PM
Element Tuning FRS/BRZ Hydra EMS Stand-Alone Turbo 400 whp Injector Limited Element Tuning Engine, Exhaust, Transmission 40 12-17-2013 02:12 AM
Element Tuning FRS Battling the Corvettes at VIR Element Tuning FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 28 07-27-2013 04:02 PM
