View Poll Results: Do you have the described AT issues?
Yes, but I've ignored them 41 34.17%
Yes, TSB fixed it 14 11.67%
Yes, dealer fix did not help 12 10.00%
No everything is fine 53 44.17%
Voters: 120. You may not vote on this poll
Old 11-17-2015, 10:44 AM   #29
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Originally Posted by Cole View Post
You could just plug your OFT in and check...
probably a dumb question but which part are your referring to? I had my OFT plugged in as soon as I left the dealership to make sure nothing was too out of line. Obviously the car still shows the same CAL ID but what other info could I pull to see if they flashed it?
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 11-17-2015, 10:49 AM   #30
Cole
Not a troll
Cole's Avatar
I mean try to flash a tune and see what happens.
Old 11-17-2015, 11:09 AM   #31
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Yep, i'm going to flash stage 1 back in a day or two just to make sure. I am just leaving it for a few days to make sure nothing else pops up.
Old 11-17-2015, 03:54 PM   #32
MechEGR
Drives: 2015 Scion FR-S AT
I'm bringing mine in tomorrow for them to re-try the TSB. I'll know within a day or two if it's gone, it happens to me literally every day on my commute.
MechEGR is offline   Reply With Quote
Old 11-17-2015, 04:04 PM   #33
DashRipRock
DashRipRock's Avatar
Drives: 2015 Scion FR-S-6AT
Is there a TSB Number for this? Thanks.
DashRipRock is offline   Reply With Quote
The Following User Says Thank You to DashRipRock For This Useful Post:
Cedars (11-28-2015)
Old 11-17-2015, 04:40 PM   #34
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Click on the link in the original post to pull up the TSB itself, all the numbers and descriptions are there
Old 11-17-2015, 04:57 PM   #35
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
I highly recommend the TSB. It's made such a difference to the everyday driving experience (in a sad way, because now it operates like it should have).
V_86 is offline   Reply With Quote
The Following User Says Thank You to V_86 For This Useful Post:
MechEGR (11-18-2015)
Old 11-20-2015, 09:26 AM   #36
MechEGR
So I did the TSB at the dealer on Wednesday night and so far no hard shifting or rev hunting! I tried everything I could to get it to happen on my commutes the last two days. I want to give it at least a full week before I say this is solved but i'm feeling extremely optimistic. My next question is, will this issue cause any long term transmission problems or did it cause excessive wear.
The Following User Says Thank You to MechEGR For This Useful Post:
V_86 (11-21-2015)
Old 11-21-2015, 12:34 PM   #37
V_86
V_86's Avatar
Two weeks post TSB for me and ZERO issues. I'm actually floored.
The Following 2 Users Say Thank You to V_86 For This Useful Post:
Borrowed Time (08-14-2016), MechEGR (11-22-2015)
Old 11-21-2015, 12:36 PM   #38
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Thanks dude I'll be getting it done then, were you in the VIN range for the TSB?
Old 11-21-2015, 12:36 PM   #39
FRSBRZGT86FAN
I have a feeling it caused excessive wear but not to a danger point
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Old 11-21-2015, 01:03 PM   #40
V_86
V_86's Avatar
I was. But if you are having the idle hunt issue, I don't see why they wouldn't try to address it with a factory approved fix.
Old 11-28-2015, 12:45 PM   #41
MechEGR
Alright so it's been a week and a half since I had the TSB done and no hard shifting or idle hunting! So relieved this is finally solved. Can I change my vote on the poll so people know there is a fix for this??
Old 12-03-2015, 07:22 AM   #42
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
My issues come and go.
SUB-FT86 is offline   Reply With Quote
AT Transmission Hard Shifting MechEGR Issues | Warranty | Recalls / TSB 95 05-21-2017 11:54 AM
AT transmission hard shifting issues calic Issues | Warranty | Recalls / TSB 44 11-09-2015 06:17 PM
3 min fix for 2nd gear hard shifting Black Tire Engine, Exhaust, Transmission 22 03-23-2014 12:13 PM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 03:22 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 02:22 PM
