#29 |
#30 | |
Drives: 2017 BRZ
#31 | |
Huge E85 fan!
Drives: 2016 Scion FRS
Read the article, they are pretty clear that they are not allowed to use an aftermarket header. Gutted OEM header, OP and FP with an aftermarket catback
#32 |
Drives: 2017 BRZ
#33 |
Huge E85 fan!
Because they made 201 WHP by gutting alone. This is the first real evidence of what gutting and a tune can do that I have seen.
#34 | |
Drives: Track preped NA FRS
Dont get hung up on the numbers guys. This is a dyno that is more generous than jesus himself. Quoting the article:
#35 | ||
- CEL is a given regardless of what direction you go, for most people this doesn't matter because your tune will cancel the CEL from suboptimal/nonexistent cats - high flow cats vs. catless is a BIG difference in day to day livability and a small difference in horsepower. Between the greatly increased sound (which IMO gets very raspy and harsh as well) catless headers are also going to give you that nasty catless exhaust smell, especially so if you are gutting the front pipe as well and going fully catless. High flow cats greatly reduce the smell and take the edge off the noise without changing the basic exhaust character, which is nice if you already have a catback sound that you like. the difference in horses in an aftermarket high flow catted header vs a catless header of the same design is negligible. you're talking maybe 2-3 whp. makes sense for a dedicated track day car, but maybe not for a DD for most of us - to my knowledge it isn't really feasible to add a high flow cat to the existing header, or replace the existing cat with a high flow. First, its going to cost money for the cat and the welding if you don't DIY (money comparable to a full aftermarket manifold). Second, going with a cat that was not designed for the specific header configuration is kind of dicey. It could end up more turbulent or effectively more restrictive than the stock design - since no header is going to pass emissions, it is better in my opinion to hold on to the OEM header so that the car can be brought back to stock spec every 2 years for emissions testing. can't do this if you modify the original header |
#36 |
The Fail Boat
Drives: CWP S.B.
#37 |
Drives: 2017 BRZ
It's nice that they made 201 whp, but they should be after every last hp that is available within the rules since they are racing. I'm not aware of any headers available for any car that incorporate a hollow expansion chamber near the header collector because it makes more power. That is why I question whether it's actually a gutted cat or a test pipe. I'm aware it's a small detail, but to me the numbers make more sense with a test pipe, and since they're in a racing series it makes more sense that they would have a test pipe since that is allowed and it's cheap to do.
#38 |
Huge E85 fan!
none of you read the article. They don't tune for max power and the article covers that. It also talks about comparisons to other high end headers.
RTFA |
#39 |
Drives: Stock
I'm running e85 and was thinking of doing this. The oft tune for el e85 should work with no problem, but I'm just curious if the second o2 needs to be disabled or if it's already in the tune
#40 |
Drives: 2017 BRZ
Again, I've read the article. They don't tune the ecu for max power for durability reasons. That has nothing to do with the header. Try to think critically for a minute.
#41 | |
Drives: 2014 Subaru BRZ Limited 6MT SSM
I plan on running this same setup with my muffler delete. Got a Tactrix cable now. Sounds good! How loud is the exhaust in person? Does it drone like hell on the highway? I find that the drone is easily manageable on my car with just the muffler delete, but deleting both cats changes things. |
#42 |
Drives: 2013 frs red
Notwithstanding competition rules and so forth, why would you go through the bullshit of ruining a stock header when you can buy a used aftermarket one and get better performance?
| Best Catback/Front Pipe/Over Pipe/Header Combo for the BRZ? | O.Z. BRZ | Engine, Exhaust, Transmission | 22 | 04-17-2019 09:44 AM |
| Ceramic coating header only vs header/over pipe/front pipe | pixel67 | Forced Induction | 8 | 08-18-2015 02:39 PM |
| FS: OEM FRS/BRZ Header w/ Gutted Cat | malubawla | Engine, Exhaust, Bolt-Ons | 10 | 06-06-2014 11:29 AM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
