go_a_way1
Old 09-22-2015, 06:58 PM   #29
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Originally Posted by MokSpeed View Post
You must try box car racers! It's a race my friends and I created on Fujimi Kaido. You must have your assist set to manual with clutch. What you do is you all line up at the first hill on the full track of Fujimi Kaido. Everybody gives enough gas to get the car to roll forward just a little bit. Afterwards nobody is allowed to put the car into gear and must race this way. The momentum of the course gets the car eventually to speeds of ~60-70 mph. Obviously this tests your braking and cornering capabilities. If you brake too late you'll probably spin out disqualifying you from the race. If you brake too early and too much you'll start to lose all your momentum eventually slowing your car to a stand still!
Only one problem with this good sir... How are you getting the car in neutral? Or are all the cars in their highest gear?
Instagram: trevor.parque
Old 09-22-2015, 06:59 PM   #30
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Good to know, No fujimi would kill it for me. Use to spend so much time editing photos of me & my friend duking it out on fujimi. =/
The Following 2 Users Say Thank You to chaoskaze For This Useful Post:
MisterSheep (09-22-2015), Special_K (09-22-2015)
Old 09-22-2015, 07:04 PM   #31
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
The Manual w/ clutch option in Forza. Essentially you have to hold the LB down the whole race. You can actually let go after a while and the car won't go in gear, but we prefer to hold it down just to prevent any cheating. I'm surprised everybody doesn't play with this setting. Clutch kicking makes drifting easier too with this control setup.
MokSpeed is offline   Reply With Quote
Old 09-22-2015, 07:17 PM   #32
Special_K
Bannéd
Special_K's Avatar
Drives: 2013 DGM BRZ
I like that! May have to pull out the 'ol 360 to give it a shot!
My buddy and I would play split screen on the mountain every day only going to full screen when we'd try to set new records... And we'd do pretty much the exact opposite of you guys where, instead of coasting, you have to race the whole time down the mountain with the throttle pinned and so the only way to keep a modicum of control was to figure out some combination of shift-locking and e-braking while the whole time you're bouncing off the rev limiter.
My personal favorite hijink was whenever we'd tandem and you get the perfect drift in which only throttle input is needed, you show off by taking your left hand off the controller and imitate holding your hand out a car window like those crazy real life drifters do.
Special_K is offline   Reply With Quote
The Following User Says Thank You to Special_K For This Useful Post:
Old 09-22-2015, 07:22 PM   #33
MisterSheep
Killed Scion
I use this set up but I change the controls on the controller to setting 10. Where the right joy stick is the clutch and handbrake. Up for clutch and down for handbrake. It allows you to get just the right amount of either or
Old 09-22-2015, 07:37 PM   #34
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Ugh I'd do this if I had my 360. All I've got now is my XBone
MS, CSCS, TSAC-F, CPT
Old 09-22-2015, 07:42 PM   #35
Special_K
Bannéd
Special_K's Avatar
Yea, I just remembered mine is broken . Shit, if Xbone backwards compatibility comes soon enough though, I'll just skip Forza 6 all together and just revert to Forza 4!
Old 09-27-2015, 06:45 PM   #36
weederr33
weederr33's Avatar
Build a high revving V8 BRZ with the SpeedFactory paint design. It's a pretty sweet A-Class/ S-Class (if supercharged) fighter. I'll post some pics later tonight or tomorrow.
Old 09-28-2015, 03:06 AM   #37
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
As soon as I pick up FM6 ill transfer my S class tune onto my brz, ill tweak it as needed from FH2.
The Following User Says Thank You to cdrazic93 For This Useful Post:
weederr33 (09-28-2015)
Old 09-28-2015, 11:06 AM   #38
weederr33
weederr33's Avatar
Do it man! Get FM6!
Old 10-12-2015, 11:13 AM   #39
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Just got the game yesterday. I had played a bit at my buddies house but I am still very new to simulation racing. My friends were pissed when on my level 1 prize spin after the tutorial I got the veyron super sport. My level 2 prize spin I got 1 mil credits. Needless to say I have had no problem wasting a ton of money on my 86.
I spent almost all my time after the tutorial working on an 86 drift build. I think I dialed in a really nice setup on the V8 swap and it sounds alot better too . I messed around with turboing the stock block and then tried the flat 6 in NA, supercharged and twin turbo before settling on the NA V8 as it is so much more controllable.
If any of you enjoy drifting in the game take a look at my tune and let me know what you think. It should be listed under something along the lines of "Drift V8 NA" with Tectoniic as the creator. It does cost ~85k on a stock 86 and has a rating ~716.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
The Following User Says Thank You to Tectoniic For This Useful Post:
MisterSheep (10-12-2015)
Old 11-03-2015, 03:34 AM   #40
M.I.A
M.I.A's Avatar
Drives: N/a
my gt86
my recent forza 6 photo
M.I.A is offline   Reply With Quote
The Following 3 Users Say Thank You to M.I.A For This Useful Post:
MisterSheep (11-03-2015), Ramster (11-03-2015), tennisfreak (11-03-2015)
Old 11-03-2015, 01:05 PM   #41
MisterSheep
Killed Scion
Forza 5 Picture Thread - Post up your shots! GuerillaRacing Other Vehicles & General Automotive Discussions 32 01-15-2015 05:48 PM
Forza 5 JDM FRS Off-Topic Lounge [WARNING: NO POLITICS] 17 11-26-2013 02:34 AM
Forza 4 WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 142 10-21-2012 10:45 PM
GT5 vs Forza 4 Dragonitti Other Vehicles & General Automotive Discussions 600 03-14-2012 04:11 PM
Forza 3 vs. GT5 Discussion Thread Snaps Off-Topic Lounge [WARNING: NO POLITICS] 386 03-06-2011 01:10 AM
