Old 09-10-2015, 03:19 PM   #29
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Originally Posted by weederr33 View Post
Just to add to that I didn't run the thermostat till I put the supercharger on. So I ran for a good... 4 months without it. Maybe more.
And obviously no problems? I thought that the thermostat simply allowed coolant to begin flowing earlier and was in terms of na purposes, a bit overkill.
kuczynskika is offline   Reply With Quote
Old 09-10-2015, 04:37 PM   #30
350matt
Drives: toyota mr2/ Toyota GT86
by lowering the coolant temp from the 92 deg C to the 82 deg C with this thermostat, you gain power by having a slightly cooler cylinder head and so better volumetric efficency
you also gain more headroom for spark, so the cooler temperature is well worth having
its probably not much but I bet its about the 3-4bhp mark
350matt is offline   Reply With Quote
Old 09-10-2015, 04:39 PM   #31
kuczynskika
Gottcha, thanks for explaining!
Old 09-10-2015, 05:19 PM   #32
ajc209
Drives: GT86 Cosworth
The thermostat lowers the engine temp from about 92C to 82C and I believe the spark timing is adjusted based on this. I don't know the specifics but the calibrations are designed around the engine running at 82C not 92C. Is your fan running often by any chance? I wonder if they lowered the fan activation temp too.
Edit: Matt beat me to it.
ajc209 is offline   Reply With Quote
Old 09-10-2015, 05:28 PM   #33
kuczynskika
The fan cycles normally in summer heat when the ac compressor is on and when at idle.
I did notice last week that my coolant level was super low. After doing reading apparently this is normal and experienced by many 86ers? Where did the coolant go? I have no idea. No leaks on the ground where I park, no leaks around the head gasket, engine bay etc.
Could the absence of the thermostat have anything to do with this? Thoughts?
I topped off my coolant and have been keeping an eye on it and no change as of yet.
Old 09-10-2015, 06:34 PM   #34
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
The coolant levels tend to fluctuate. It's still the normal level. Once the engine runs for a bit the levels will appear normal. But I wouldn't worry about it. We're supposed to have that Super Ultra-mega Blue Ice Omega Coolant or whatever Subaru calls it.
MS, CSCS, TSAC-F, CPT
Old 09-10-2015, 06:39 PM   #35
kuczynskika
That was my conclusion too. Still odd because it make you wonder where the coolant goes? I understand that due to heat it expands and contracts, changing the level (normal obviously) but the level was downright low!
Yeah I didn't bother with subaru's bullshit special coolant.
Old 09-10-2015, 06:51 PM   #36
weederr33
weederr33's Avatar
I didn't either. I just tossed some normal green in my car. I use it for my supercharger too. And I'm not big on fluid dynamics and physics. Unless it involved biomechanics, which then I'm cool haha
Old 09-11-2015, 04:30 AM   #37
ajc209
Just make sure the coolant you use is Silicate free guys!
Old 09-11-2015, 05:07 AM   #38
ajc209
Guys quick question. I have an oil pressure sensor fitted in the top oil gallery next to the A/C compressor. I assume the SC will foul on it? How much clearence is there underneath the SC and the engine?
Old 09-11-2015, 08:17 AM   #39
ajc209
Looks like I will have to move it to the stock pressure switch location.
Old 09-11-2015, 01:41 PM   #40
weederr33
weederr33's Avatar
Let me go take a look.
Old 09-11-2015, 01:58 PM   #41
weederr33
weederr33's Avatar
The fit might be tight...
Old 09-24-2015, 12:16 AM   #42
TxFrs10
TxFrs10's Avatar
Drives: 10 series fr-s
killboydotcom on the tube recently released a Cosworth Fr-s Tail of the Dragons video. Slowmo drifts, not too shabby.
TxFrs10 is offline   Reply With Quote
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
