#29 |
Drives: Harrop TVS86 STi BRZ tS
And obviously no problems? I thought that the thermostat simply allowed coolant to begin flowing earlier and was in terms of na purposes, a bit overkill.
#30 |
Drives: toyota mr2/ Toyota GT86
by lowering the coolant temp from the 92 deg C to the 82 deg C with this thermostat, you gain power by having a slightly cooler cylinder head and so better volumetric efficency
you also gain more headroom for spark, so the cooler temperature is well worth having its probably not much but I bet its about the 3-4bhp mark |
#31 | |
#32 |
Drives: GT86 Cosworth
The thermostat lowers the engine temp from about 92C to 82C and I believe the spark timing is adjusted based on this. I don't know the specifics but the calibrations are designed around the engine running at 82C not 92C. Is your fan running often by any chance? I wonder if they lowered the fan activation temp too.
Edit: Matt beat me to it. |
#33 | |
I did notice last week that my coolant level was super low. After doing reading apparently this is normal and experienced by many 86ers? Where did the coolant go? I have no idea. No leaks on the ground where I park, no leaks around the head gasket, engine bay etc. Could the absence of the thermostat have anything to do with this? Thoughts? I topped off my coolant and have been keeping an eye on it and no change as of yet.
#34 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
The coolant levels tend to fluctuate. It's still the normal level. Once the engine runs for a bit the levels will appear normal. But I wouldn't worry about it. We're supposed to have that Super Ultra-mega Blue Ice Omega Coolant or whatever Subaru calls it.
#35 | |
Yeah I didn't bother with subaru's bullshit special coolant.
#36 | |
#37 |
Just make sure the coolant you use is Silicate free guys!
#38 |
Guys quick question. I have an oil pressure sensor fitted in the top oil gallery next to the A/C compressor. I assume the SC will foul on it? How much clearence is there underneath the SC and the engine?
#39 |
Looks like I will have to move it to the stock pressure switch location.
#40 |
Let me go take a look.
#41 |
The fit might be tight...
#42 |
Drives: 10 series fr-s
killboydotcom on the tube recently released a Cosworth Fr-s Tail of the Dragons video. Slowmo drifts, not too shabby.
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6049 | 06-25-2026 10:40 PM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 01:18 PM |
| Phantom FTS Electric Supercharger Owners Thread | TM | Forced Induction | 1206 | 12-15-2019 02:33 PM |
| Supercharger Kits! Vortech/Cosworth | RallySport Direct | Forced Induction | 61 | 06-29-2015 11:26 AM |
