Old 06-21-2012, 05:19 PM   #29
mike2100
mike2100's Avatar
Drives: 23 BRZ
Love it, can't wait to hear how it sounds
mike2100 is offline   Reply With Quote
Old 06-21-2012, 05:54 PM   #30
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
I love the look of the system, and am really looking forward to seeing numbers and vids on it.
I'm really looking for something that can pass emissions in California, as well, however. Is this system 50 state street legal, or is it primarily designed for track events/states with less stringent requirements?
Symbiont is offline   Reply With Quote
Old 06-21-2012, 06:33 PM   #31
catharsis
Drives: honda civic si 08
So far this looks like the best designed and most thought out exhaust yet. Very minimal bend angles.
catharsis is offline   Reply With Quote
Old 06-21-2012, 06:41 PM   #32
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
To be "officially legal" you cannot touch anything from the air filter to the last cat.
You can get away with aftermarket cats, if they are covered by a heat shield, or it's a place they cannot see too easily.
You can away with just the primary cat, since there is no O2 sensor checking for the 2nd one. If the smog guys don't peak under and look for the 2nd one.
My plan is to run a header that retains the primary cat with a metal heat shield (I will make one if I have too). Then run a cat'd DP. I may try and fab up mounting for the 2nd cat heatshields if I find it's needed for a more stock look.
uspspro is offline   Reply With Quote
Old 06-21-2012, 06:57 PM   #33
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
B E A utiful! that is a good looking design. Will wait to see numbers, and hear exhaust note!
jedibow is offline   Reply With Quote
Old 06-21-2012, 07:18 PM   #34
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Looks great. Cant wait to see dynos and videos.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 06-21-2012, 07:46 PM   #35
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Per this site, I'm not sure if that's completely accurate:
California Vehicle Code Section 27156 and the Federal Clean Air Act prohibit modifications that increase motor vehicle emissions. Since if properly designed, most performance modifications do not increase vehicle emissions, these same laws also allow the installation of parts or modifications proven by their manufacturers and the ARB not to increase vehicle emissions.
Exempted parts are add-on or modified parts that have undergone an ARB engineering evaluation. If the part or modification is shown to not increase vehicle emissions, it is granted an exemption to emission control system anti-tampering laws. This exemption is called an Executive Order (EO) and allows the modification to be installed on specific emission controlled vehicles. Every Executive Order part or modification has an assigned number that can be verified by Smog Check stations, BAR Referee stations, or by the ARB.
Old 06-21-2012, 07:55 PM   #36
uspspro
Right, if they get CARB EO.
No mfg is going to get away with getting a CARB EO for something that messes with the stock cats.
Intakes.. sure.
Ever since they came up with the revised catalytic converter laws, you pretty much need OEM on modern cars until it is 7 + years old.
New California Aftermarket Catalytic Converters
As of January 1st, 2009, What You Can and What You Cannot Sell/Required:
*Please Note - Installers may not install a new aftermarket catalytic converter in a vehicle unless all of the following conditions are met:
(A) The vehicle is specifically included in the vehicle application list for which the new aftermarket catalytic converter has been exempted;
(B) The vehicle is more than 7 years old or has more than 70,000 miles on its odometer;
(C) The vehicle is beyond the coverage of the OEM catalyst warranty period (which can vary from 7 years or 70,000 miles to as high as 15 years or 150,000 miles).2 Installers may reference the vehicle owner’s manual/warranty booklet or contact the vehicle manufacturer or its representative to verify the applicable OEM catalyst warranty;
(D) The vehicle has a legitimate need for replacement of the existing converter that has been established and documented by the installer on the repair invoice. If the OEM converter is present, the installer must make a determination that it is not functioning properly before acting to replace it;
(E) The exempted new aftermarket catalytic converter is installed in the same location as the OEM catalytic converter it is designed to replace. The front face of the installed catalytic converter shall be no more than three inches further upstream or downstream in the exhaust from where the front face of the OEM catalytic converter was located. The installation may not alter the location, position, or orientation of oxygen sensors upstream and downstream of the catalytic converter(s);
(F) The exempted new aftermarket catalytic converter is installed on a one-for one catalytic converter (not substrate) basis;
(G) The exempted new aftermarket catalytic converter is installed with all other required catalytic converters (no consolidation of catalytic converters, nor addition of extra catalytic converters is allowed); and
(H) A warranty card has been filled out by the installer, signed by the customer, attached to the repair invoice, and a copy returned to the manufacturer.
(I) Installers shall keep documentation regarding the installation of the new aftermarket catalytic converters including all of the above information. This documentation shall be made available to ARB or its representative as provided for in title 13, section 2222(b)(8). All such records shall be maintained for four years from the date of sale or installation of the catalytic converter.
Old 06-21-2012, 07:56 PM   #37
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Hey, I can dream, can't I?
Old 06-21-2012, 07:57 PM   #38
uspspro
Also, when I said "get away with" I did not mean it was exactly legal :happy0180:
Old 06-21-2012, 10:33 PM   #39
Swift Racing Technologies
Swift Racing Technologies's Avatar
Originally Posted by Shagaliscious View Post
Wow, that exhaust looks beautiful! Do you know if the car will have a problem with emissions with just the primary cat.?
It should pass emissions in all states except the "Peoples Republic of Californication"
Originally Posted by MTeator View Post
Ah bummer, thought it looked nice but can't use it :/
Of course you can, why would you not be able to?
Symbiont, uspspro unfortunately with CA 99.99 % of aftermarket parts are not legal unless they are CARB EO cert'ed.
Swift Racing Technologies is offline   Reply With Quote
Old 06-21-2012, 10:38 PM   #40
uspspro
People in CA can use it.. just swap it out for a couple of hours every 2 years
Old 06-21-2012, 10:44 PM   #41
MTeator
First 86
Since I've chosen to run SCCA C-Stock, I can't change the cats.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 06-21-2012, 10:46 PM   #42
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Subscribed to the beautiful R&D exhaust!
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
AIRAID FR-S / BRZ Cold Air Intake system Sneak Peak / Development Information AIRAID Engine, Exhaust, Transmission 396 10-04-2012 07:27 AM
Anyone going to Pike's Peak Hill Climb to see Gushi? terrypm Other Vehicles & General Automotive Discussions 3 06-21-2012 02:06 AM
Toyota TMG EV P002 to race at Pike's Peak madfast Other Vehicles & General Automotive Discussions 4 06-08-2012 09:09 PM
Exhaust system: dual or single KiingDavid Engine, Exhaust, Transmission 162 05-04-2012 01:33 AM
