Old 06-25-2012, 05:06 PM   #29
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Originally Posted by Metabrz View Post
So, there is a lot of talk about staggered set ups creating understeer.
There are a lot of cars that are sold new with a staggered set up so surely this can tuned out with appropriate suspension work?
I really like the staggered look but my brz will be used on track quite a lot so its definititely function > form for me.
Any peeps got some guidance in this area? Thanks
Get 2 sets of rims, one for track, one for swag
Originally Posted by Coastermikey View Post
It doesn't look like +38 all around, the rears look to be less with its concavity
Work offers the CR Kiwami in +38 for both semi concave and deep concave.
It's on their website:
http://www.workwheelsusa.com/media/w...Kai%20Spec.pdf
however the bolt pattern is custom. but I suspect with the popularity of the twins it will be stardard
dori. is offline   Reply With Quote
Old 06-25-2012, 09:40 PM   #30
Coastermikey
Drives: BRZ DGM
Ah. Thanks for the info, I wonder how it would look w a deep concave face all around and same width.
Coastermikey is offline   Reply With Quote
Old 06-27-2012, 02:13 PM   #31
SpeedR
First86 / boat thief
Drives: MKIV Supra
Originally Posted by ultra View Post
Bit of an oversimplification there. The OP's question was whether a staggered setup would induce additional understeer. The clear answer would be yes, due to the higher amount of grip at the rear of the car.
Could you tune the chassis to re-balance the car after adding wider rear tires? Using a combination of springs/dampers, sway bars and aggressive alignment settings you probably could, but that would involve a whole lot of work just to fix something that was intentionally 'broken' in the name of aesthetics.
If you have an abundance of power to break the rears loose and need wide rubber to contain them that's one thing but there's a reason that the hardcore track S2K and Miata guys tend to favour square setups.
Having said that, nobody's proven things one way or another through actual testing on these cars yet.
Just my 2c.
well said
SpeedR is offline   Reply With Quote
Old 06-28-2012, 06:31 PM   #32
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Wasn't staggered a bad choice to do, unless you sacrifice handling?
Legit question
Snoopyalien24 is offline   Reply With Quote
Old 06-28-2012, 06:43 PM   #33
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Different widths.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 06-28-2012, 10:27 PM   #34
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
I have 9.5 +38 all round on order so i can let you know in a few months! The blue 86 has 9.5 +30 all round and there are photos floating around here somewhere...
spiller is offline   Reply With Quote
Old 06-29-2012, 01:16 PM   #35
RavSpec
Drives: Rx7
18x9.5 +38 all around are easier fits in the front. The only concern are the wheels hitting the coil over system.
Thus some people go with 18x9.5 +30, which stick out 8mm more than the 38mm but has much more clearance for coil over system.
RavSpec is offline   Reply With Quote
Old 06-29-2012, 02:10 PM   #36
poormans_LFA
FT86Club.com O.G.
poormans_LFA's Avatar
Drives: Gunmetal Gundam Wing Zero Custom
can the deep concave CR Ultimate's be ordered in a 5X100 PCD??
poormans_LFA is offline   Reply With Quote
Old 06-29-2012, 02:18 PM   #37
RavSpec
Drives: Rx7
yes, 18x9.5 +38 or 18x9.5 +30
Old 06-29-2012, 04:11 PM   #38
kidgogeta
Drives: FRS
How much do these rims weigh in at compared to the stock?
kidgogeta is offline   Reply With Quote
Old 06-29-2012, 04:20 PM   #39
RavSpec
Drives: Rx7
22.8 lbs for the 18x9.5 spec
21.9 Lbs for the 18x8.5 spec
Old 06-30-2012, 08:50 PM   #40
jskurucz
Yep!
jskurucz's Avatar
Drives: 2015 WRX Sti
Anyone know if there was any fender rolling for this setup??
jskurucz is offline   Reply With Quote
Old 07-26-2012, 04:45 PM   #41
RavSpec
Drives: Rx7
No fender rolling, but need coil over.
Old 07-30-2012, 12:54 PM   #42
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Another member with this same wheel setup:
http://www.ft86club.com/forums/showthread.php?t=13133
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +30 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 179 11-20-2015 12:12 AM
Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +18 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 103 11-21-2013 03:28 AM
Work CR Kiwami/Ultimate danscar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 09-11-2012 12:24 AM
WORK Emotion Kiwami - 18x8.5/9.5. Staggered For FRS/BRZ *** Available Now *** RavSpec Wheels and Tires 59 07-24-2012 12:07 PM
WORK Emotion Kiwami - 17x9.0 +38mm 5x100 *** BRZ/FRS Spec *** RavSpec Wheels and Tires 5 07-19-2012 06:44 PM
