Old 07-16-2015, 01:02 PM   #29
DJCarbine
Thupercharged
DJCarbine's Avatar
Just for shits and giggles, I recommend you go test drive a 2015/2016 WRX. You'd be impressed with the new engine.
I really should, the Ej205 is an archaic pig compared to modern engines
2013 FRS
Vortech V3 11psi
The Following User Says Thank You to DJCarbine For This Useful Post:
wparsons (07-16-2015)
Old 07-16-2015, 01:20 PM   #30
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
2015/2016 wrx is an fa20di-t. Unless you already knew that and were making a remark about how the new wrx engine is better then the ej205, in wich case disregard my post.
WHITE is offline   Reply With Quote
The Following User Says Thank You to WHITE For This Useful Post:
DJCarbine (07-16-2015)
Old 07-16-2015, 01:37 PM   #31
wbradley
Sarcastic SOB
wbradley's Avatar
For aftermarket:
Simplicity.
Less potential for failure with less parts.
Less potential heat issues.
Centrifugal system, a good design has very low parisitic loss.
" " , gentler onset of extra torque easier on driveline
" " , doesnt drastically change the personality of the engine
On the other hand, I prefer turbo if it is factory equipped as the details are most likely ironed out for dependability, eg: I have a 2015 WRX
The Following 2 Users Say Thank You to wbradley For This Useful Post:
CSG Mike (07-16-2015), raven1231 (07-16-2015)
Old 07-16-2015, 01:38 PM   #32
DJCarbine
Thupercharged
DJCarbine's Avatar
I was referring to the engine in my 2005 wagon, it's all good
2013 FRS
Vortech V3 11psi
Old 07-16-2015, 01:45 PM   #33
Jonsey
Jonsey's Avatar
Originally Posted by LucidMomentum View Post
Well it recharges the battery after every pull, so you get 90 seconds of 5 PSi of boost and then 20-30 seconds of recharge time.
If you use the Procede controller, it's always on. More like having a beefier engine.
It is not intended to be run on a track. It is not designed to handle the duty cycles it would see on a track and you are typically on gas too often on the track for it to recharge. I was on the waiting list and spoke to Rob and Fenton both about tracking it, as that was the primary use of the car by the time I had the opportunity to buy. After speaking with them, I passed and will go the JRSC route in time.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
The Following User Says Thank You to Jonsey For This Useful Post:
Old 07-16-2015, 01:48 PM   #34
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Originally Posted by wparsons View Post
What turbo were you running, and how much boost? What I don't like about a turbo mid corner is that at part throttle power delivery isn't always predictable depending on load, etc.
That usually happens when too large of a turbo is run. We've done extensive tracking (in several countries!), and mid-corner control is not an issue, because the turbo is spooling from 2000rpm onwards, not 4000+ onwards.
A proper turbo setup works great at the track, just as a proper sc setup would. But it's always easy to pick out examples of each that don't.
AVOturboworld is offline   Reply With Quote
The Following User Says Thank You to AVOturboworld For This Useful Post:
NLS8520 (07-17-2015)
Old 07-16-2015, 02:04 PM   #35
wparsons
wparsons's Avatar
I wish someone made a GT25x based kit (or similar sized EFR turbo). I don't want 350+whp, and don't want that much headroom just adding lag. No e85 up here, and no interest in a lower compression block. A solid 260-270whp would be perfect, and for off the shelf solutions the supercharger kits are the best option.
flickr
Old 07-16-2015, 02:09 PM   #36
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I'm running a GTX3076R on my S2000. Boost was as high as 10 psi during the weekend.
The Following User Says Thank You to King Tut For This Useful Post:
Old 07-16-2015, 02:25 PM   #37
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I'm pretty sure you can get full blown or any of the reputable shops to make you a kit based on it even a local good reputable shop.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 07-16-2015, 02:27 PM   #38
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
like others mentioned transient response (this may be very critical at the track and mimic lift-off oversteer) ..also there are so many different variations of each options (turbo vs SC), positive displacement, centrifugal type, journal bearing, ball bearing, single vs twin scroll ..list goes on.. each has their pros and cons so one size doesn't fit all
if you're ultimate goal is to make big hp then turbo it is, never really understood why people choose this platform to begin with, if that's what they're after though
glamcem is offline   Reply With Quote
The Following 2 Users Say Thank You to glamcem For This Useful Post:
CSG Mike (07-16-2015), wparsons (07-16-2015)
Old 07-16-2015, 03:44 PM   #39
wparsons
wparsons's Avatar
I also want uber short charge pipes, and an IC core sized to my hp goals.
Basically all custom minus maybe the manifold if the flange is compatible with the turbo I would end up picking.
In all honesty, if the Greddy kit was available with a more modern (and smaller) turbo it would be pretty damn close.
flickr
Old 07-16-2015, 04:16 PM   #40
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It sounds like you have a great plan. As long as those lower HP numbers meet your goal, then I would just buy a Greddy kit. I am sure there is a way to get a GT25 on that kit. The only reason I didn't go with the Greddy kit on my S2k is that I knew I would want more HP on the street than it could provide, but it would have supplied the perfect setup for the track.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Old 07-16-2015, 04:23 PM   #41
Yoda
Drives: Crystal Black BRZ(Sophia)
Why not just go custom? Have a good local shop build the kit to your specifications. I have put together my own custom kit before and its not really that hard and lots of fun to do.
Yoda is offline   Reply With Quote
The Following 2 Users Say Thank You to Yoda For This Useful Post:
CSG Mike (07-16-2015), Sportsguy83 (07-16-2015)
Old 07-16-2015, 04:36 PM   #42
wparsons
wparsons's Avatar
Cost, plain and simple. It'll be way more expensive to get a custom kit fabbed up than to just buy the JRSC kit that gives me the same hp I want.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
D_Thissen (07-16-2015)
charged86 supercharged to build motor turbo charged86 Member's Car Journals 9 07-24-2015 11:48 PM
turbo/supercharged FRS ride along? dgerny Northwest 26 05-15-2015 11:43 PM
wtb Turbo or Supercharged auto FR-S/BRZ TurboCarder Want-To-Buy Requests 1 01-27-2015 07:10 PM
wtb Turbo or Supercharged auto FR-S/BRZ TurboCarder Cars for Sale/Trade 0 01-27-2015 09:31 AM
Turbo BRZ smashes a Supercharged v8 in a drag CSI:86 Forced Induction 41 05-14-2013 09:12 PM
