#29 | |
Turbo E85
Drives: 13 wrb brz
Flex Fuel Turbo BRZ
#30 | |
PhoneFlash by EcuTeK
Sincerely, Zach Delicious Tuning |
#31 |
Turbo E85
Drives: 13 wrb brz
*UPDATE*
i correctly my rough starting issue. it took multiple cranks to start the car then it acted normal. LJ recommended me to remove my fuel pump and add more o-rings to the pump to seat better. i took his advise and added 2 more even though he said 3 and the car started! with no issues..
Flex Fuel Turbo BRZ
#32 | |
Drives: Late 2014 Subaru BRZ
#33 |
Turbo E85
Drives: 13 wrb brz
I transfered oved the factory o-ring and nylon washer on like what the instructions showed.. And had the cranking rough start but added two more for a total of 3 o rings now and the car does start normally now.
Flex Fuel Turbo BRZ
#34 | |
Drives: 2014 BRZ Limited [6MT/SWP]
Did this also fix your rough low end issue? As far as the RPM's jumping around when taking off or holding them at around 2000
#35 |
Turbo E85
Drives: 13 wrb brz
that was corrected via a revised tune that LJ sent me.
Flex Fuel Turbo BRZ
#36 | |
Turbo E85
Drives: 13 wrb brz
they have sent me a tune to determine if my 4 bar from fb was causing the idle flucuation and it was determined to be correct but i am still currently driving with LJ tune which has not given me any issues.. crossing fingers that my flash and go kit from delicious will work with the new map sensor.
Flex Fuel Turbo BRZ
#37 |
Oh alright well I am kind of in the same boat as you were, after 3 months of headaches I finally have my car running without leaks, but the car is idling a little off and is VERY jumpy on the low end, plus it leans out when hitting boost and feels very dangerous to drive, with the base map installed. And I seen you chose to go with Delicious Tuning's flash and go tune and were working with them to fix the issue... is there a reason your not using their tune anymore and are back with FBM's tune??
#38 | ||
Turbo E85
Drives: 13 wrb brz
Flex Fuel Turbo BRZ
#39 | |
Ahhhh gotcha, ignore my last post then lol That's funny because I am also using the 4 bar map sensor purchased from full blown, will have to see if it is also the reason for my issues
#40 |
Drives: 2013 Scion FR-S in White
Any updates to these issues?
#41 |
I've been using FBM ecutek tune and 4bar for almost a year now personally. I've had no issues with idle and my failsafe has been spot on with a/f.
I'm saving for a engine build and tune at the same time. I haven't had 1 knock since install either I do understand I'm not getting the most out of my kit but I rather not bend a rod
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
| Need Advice on Chirps and rough idle | Jake_86 | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 01-30-2015 02:32 PM |
| '14 BRZ Ltd. - Rough Idle | leicaboss | BRZ First-Gen (2012+) — General Topics | 20 | 05-22-2014 06:40 PM |
| CEL, Skid Light, Rough Idle ... | SherbFrs | Issues | Warranty | Recalls / TSB | 8 | 07-18-2013 06:43 PM |
| Looks like CEL/Rough Idle is getting a lot more attention. | wawro569 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 10-06-2012 12:24 AM |
| Rough Idle & CEL *video | JiB | Issues | Warranty | Recalls / TSB | 5 | 10-04-2012 10:28 PM |
