Old 07-22-2015, 11:00 AM   #29
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
Cant wait to see updates!
Just a side question - I thought the BRZ tS came with the rear STI spats? or no?
AG3NT_5CARFAC3 is offline   Reply With Quote
The Following User Says Thank You to AG3NT_5CARFAC3 For This Useful Post:
kuczynskika (07-22-2015)
Old 07-22-2015, 01:40 PM   #30
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
It does. They're on my list for install in the near future. One bit at a time haha
kuczynskika is offline   Reply With Quote
The Following User Says Thank You to kuczynskika For This Useful Post:
AG3NT_5CARFAC3 (07-22-2015)
Old 07-22-2015, 04:23 PM   #31
AG3NT_5CARFAC3
Drives: Toyota GT86
haha yes yes one piece at a time
Very nice! Keep up the good work!
Old 07-22-2015, 04:25 PM   #32
kuczynskika
Thanks! Ill have some new goodies up tomorrow too... plenty of pics as well!
Old 07-24-2015, 03:28 PM   #33
kuczynskika
Originally Posted by weederr33 View Post
Yes! I have been wondering. I know there's lots of speculation, but I'd really like to know what it is. Cosworth hasn't released any info on stage 3 which is a bummer
Oh for the FP/OP, are you going to get it directly from Cosworth, or from Nameless? Since it's the same piece and all....
Nameless seems to be the most cost-effective route. I can do the FP/OP and headers for a little over 2K. Literally it is the exact same design too.
Old 07-24-2015, 04:03 PM   #34
kuczynskika
Yesterday was a big day. Finally installed the front and rear brembos. Most of the install was smooth this time around, largely due to the fact that I was using brand-new front calipers.
Flashback: On the original calipers I bought (already had trackdays on them) I had to drill out and rethread each of the allen screws as they were fused inside the caliper. While I am lucky to have access to a proper machine shop, it wasn't until after I had done the install on the original calipers that I realized each bleeder was not sealing properly (result of rethreading a thousandth too big).
Fast forward, with brand-new unused calipers the bleeder flip was a breeze. I was able to unscrew 3 of the 4 allen plugs by hand (still kinda hard) but not anywhere as bad as having to drill. The final allen plug was more difficult as I had to torch it and use a grab-it bit. The final plug was then easy to remove.
My advice on the bleeder flip: don't do it unless you have new/unused calipers. Otherwise you have to drill and rethread and you run the risk, like me, of screwing it up.
The rear brembo installation was pretty easy as well. There are not any bleeders to flip, so that makes life easier. The only problem I encountered was with my DBA Rotor. From my reading of other brembo install threads the only trimming to the dust shield was for the caliper. In my case the diameter of the dust shield was interfering with the rotor, so I had to cut the lip of the shield all the way around (see pic). Other than that the install was no problem.
Brembo Impressions: The added braking power up front is noticeable. You can certainly feel the front of the car dive under hard braking. The feel is excellent. I certainly feel confident braking later. With more brake upgrades (master cylinder brace, stainless lines, etc.) I'm sure the feel would be improved further. Overall, great performance and aesthetic upgrade. See for yourself!
Old 07-24-2015, 04:53 PM   #35
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
DO IT!!
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
kuczynskika (07-24-2015)
Old 07-30-2015, 02:02 PM   #36
mixedjuice
Drives: 2015 BRZ - sold & 2014 Legacy Sport
Are you liking the 18" rim setup? I am looking into the STI look for my 2015 BRZ.
But can't seem to find myself locked in on a tire & wheel package.
The 2015 Series Blue BRZ came with 17" STI Wheels right? But how do yours fit? and do you have any advise on if i went 18" with stock suspension?
mixedjuice is offline   Reply With Quote
Old 07-30-2015, 03:44 PM   #37
kuczynskika
The 18s are excellent. They fill the wheel well nicely and are just gorgeous. My only complaint is the offset. You don't need much, but a small spacer on the rears helps to make things look more flush. Still very good all the way around however.
Correct, the Series.Blue does come with 17" wheels standard.
I'm running stock suspension with TRD lowering springs and I don't have any complaints. I would suggest a drop of 1" - 15mm with these wheels however. I'd like to cash in on an STI suspension, but that's for later.
The Following 2 Users Say Thank You to kuczynskika For This Useful Post:
blues15dp (06-26-2017), mixedjuice (07-30-2015)
Old 07-30-2015, 05:05 PM   #38
enigma
Drives: Asphalt 86
Build looks great man! I'm digging your brakes for sure!
When you're ready to make the plunge for the Stage 2... do it. I can't recommend it enough.
There's just so much more power... everywhere.
enigma is offline   Reply With Quote
Old 07-30-2015, 05:09 PM   #39
kuczynskika
Thanks!
I feel you on that. Looking at your numbers I don't doubt it. Cosworth components are excellent. Can't wait till I can put up some dyno numbers like yourself!
What's next for your build?
Old 07-30-2015, 05:14 PM   #40
enigma
Drives: Asphalt 86
Thanks!
Perrin Oil Cooler goes on this weekend before the first track day with the supercharger. After that, I'm leaning towards doing some functional exterior stuff... Considering the Driveway labs front 3" splitter and a rear diffuser, but I'm undecided on how aggressive (read: ridiculous) I want to go out back.
Old 07-30-2015, 06:04 PM   #41
mixedjuice
Thanks!
I am on Tire Rack dot com right now,
looking at a set of 18" Rims to go with 225/40/48 Michelin Pilot Sport Tires.
Do you think this would require the spacers ?
Old 07-30-2015, 06:09 PM   #42
weederr33
weederr33's Avatar
I can vouch for Enigma, the Stage 2 is so awesome in terms of power delivery being all over
kuczynskika (07-30-2015)
Cosworth SC build... Ernie L Member's Car Journals 184 09-10-2015 05:25 PM
What did YOU do with your Cosworth plaque? weederr33 Engine, Exhaust, Transmission 31 02-24-2015 05:23 PM
Cosworth worth the $$$$? EAGLE5 Off-Topic Lounge [WARNING: NO POLITICS] 28 02-24-2015 02:12 AM
Stage 1.1 Cosworth FRS FR-S89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 12-22-2014 02:23 PM
