Old 06-23-2015, 11:21 AM   #29
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
10k and cording all 4 corners.
Old 07-26-2015, 01:24 PM   #30
Dino451
Dino451's Avatar
Drives: Scion FRS/Whiteout/OEM spoiler
31k Miles....but not by choice. I had two punctures within two months, the last puncture was not fixable. Michelin PSS's were on within 12 hours
But had lots of tread left over though
Whiteout 2013 FRS/ OEM Spoiler/ Clear side markers/TRD Intake/ Shark fin antenna/Rex speed blue wide mirrors/DD fog lights/Grimmspeed Strut bar/
Dino451 is offline   Reply With Quote
Old 07-26-2015, 08:48 PM   #31
EAGLE5
Dismember
EAGLE5's Avatar
My second set, PSS, lasted about 9k. Thank you, chip seal.
Old 07-26-2015, 09:33 PM   #32
computeruser
Drives: 2015 BRZ
I've never owned a set of car tires that still rode worth a damn after 20k miles, even with regular rotation.
computeruser is offline   Reply With Quote
The Following User Says Thank You to computeruser For This Useful Post:
ntron1 (07-27-2015)
Old 07-27-2015, 12:51 AM   #33
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Hahaha, I'm at 30k mi too... I'm on my third set of tyres, and that's without doing any kind of track or autox work :P
Seriously though I wouldn't try to hold onto those stock tyres for too long. IIRC when I retired mine they still had some tread depth left, but they were starting to feel like drift trike wheels-- no grip at all, and not a progressive break-away either.
Ganthrithor is offline   Reply With Quote
Old 07-27-2015, 02:26 PM   #34
Kwisak
Kwisak's Avatar
Drives: 2013 BRZ GBS
I was at 45k when I changed.
Kwisak is offline   Reply With Quote
The Following User Says Thank You to Kwisak For This Useful Post:
ntron1 (07-28-2015)
Old 07-28-2015, 01:49 AM   #35
Mx5racer
Drives: 97 Miata / 15 BRZ limited 6MT WRB
Hopefully I can get new rims and tires before 1K so I will never know
Mx5racer is offline   Reply With Quote
Old 08-21-2015, 05:58 PM   #36
mixedjuice
Drives: 2015 BRZ - sold & 2014 Legacy Sport
Michelin Super Sport Tires or the Michelin Super Sport A/S version.?
which is recommended best?
I read that the MSS handle better in the wet.
mixedjuice is offline   Reply With Quote
Old 08-21-2015, 06:35 PM   #37
EAGLE5
Dismember
EAGLE5's Avatar
You ever going to be in light snow? A/S. Otherwise, regular.
The Following User Says Thank You to EAGLE5 For This Useful Post:
mixedjuice (08-21-2015)
Old 08-21-2015, 07:18 PM   #38
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
I got 4k miles out of mine before replacing them with MPSS. That said they're continuing life on my WRX - which at 500lbs heavier and AWD, I don't expect to see 45k miles out of them - but we'll see.
ashtray is offline   Reply With Quote
Old 08-21-2015, 07:58 PM   #39
mixedjuice
Thanks - I think i am leaning towards MSS and will just run my wife's legacy sport once the first snow hits the ground.
I'm still on m stock wheel set up for now (1,005 miles) and will see if i can let the tires loose a little before going for a 18" set up.
I'm going for the ASA GT10 Hyper Silver Wheels with the Super Sport Tires on 92Y
Old 08-21-2015, 08:01 PM   #40
ashtray
Its not just snow - temps drop in to the 30's, even in the dry, and your tires will lose grip. Just fyi.
The Following User Says Thank You to ashtray For This Useful Post:
Old 08-21-2015, 08:23 PM   #41
mixedjuice
Well i live in a rain forest if that helps my situation at all. It rains a lot, but I would never drive my BRZ in any snow fall weather.
But in the rain on an average temperature of 40 degrees from Sept to Nov i was hoping the Super Sports would get me a couple good runs in the dry and wet conditions.
FS - Stock Rims / Tires / TPMS 25k miles AtlasMick Wheels and Tires 3 03-28-2015 05:49 PM
FS: Stock FRS wheels/tires less than 1k miles Reno Kuros Wheels and Tires 0 06-17-2014 11:03 PM
Stock wheels & tires...used only maybe 500 miles. Only $500 bucks dOMEmE Wheels and Tires 1 12-12-2013 05:24 AM
Less then 200 Miles on Stock Wheels and Tires SuperKazRacing Wheels and Tires 0 11-21-2013 01:39 AM
