Old 10-11-2015, 01:38 PM   #29
DeaconRoc
Drives: GT86
Originally Posted by Trettiosjuan View Post
Cross posting a bit http://www.ft86club.com/forums/showp...&postcount=301 even though I'm most interested in the A's, discussion is in the Z.
TL; DR: Would love to see factory recommendations from the installation manual for preload. Thanks.
I don't think there is any information on preload given.
DeaconRoc is offline   Reply With Quote
The Following User Says Thank You to DeaconRoc For This Useful Post:
Trettiosjuan (10-11-2015)
Old 10-11-2015, 10:54 PM   #30
Shady195
Drives: '13 10 Series FRS #1203
The Flex Z manual does have recommendations for preload however I would not use them. My coilovers seemed to bottom out quite easy with tein's specs. I took everyone elses recomendation and just got the spring snug in the perch with 0 preload and locked them in their place. Car doesn't feel any different handling wise but it no longer bottoms out.
Shady195 is offline   Reply With Quote
Old 10-12-2015, 03:14 AM   #31
Trettiosjuan
Drives: GT86
Bottom out as in the tires hitting the arches? How much is your car lowered? That would make sense as more preload gives more bump travel, and is actually good news for me. Please share the preload specs, thanks
Trettiosjuan is offline   Reply With Quote
Old 10-12-2015, 10:52 AM   #32
bfrank1972
Drives: 2013 FR-S Argento
That's weird, I would think you'd have less bottoming out with more preload (it raises the car and also increases bump travel).
bfrank1972 is offline   Reply With Quote
The Following User Says Thank You to bfrank1972 For This Useful Post:
Trettiosjuan (10-12-2015)
Old 10-12-2015, 11:15 AM   #33
Trettiosjuan
Drives: GT86
But it would make sense if he lowered the car again by reducing the length of the shock body, and the added bump travel caused interference of the tyres with the liners....
Old 10-12-2015, 11:23 AM   #34
bfrank1972
Well maybe the tires are hitting the fenders/liners, but lowering on these coilovers doesn't otherwise change the shock body length.
Old 10-12-2015, 11:48 AM   #35
DeaconRoc
Drives: GT86
Even when mine was lowered 60mm and I was driving a very bumpy B road I never had the wheels hitting the arches
Old 10-12-2015, 11:51 AM   #36
Trettiosjuan
Drives: GT86
Perhaps we're talking about different things, I mean "Case length" as described here: http://www.tein.com/products/flex_z.html#p03
The Following User Says Thank You to Trettiosjuan For This Useful Post:
bfrank1972 (10-12-2015)
Old 10-12-2015, 11:56 AM   #37
Trettiosjuan
Drives: GT86
Which means that at stock height, I could have had 60mm more suspension travel? Perhaps not, because on my bumpy roads, with a 60mm lower car you would be craping the bottom of you car everywhere instead... Love your input DeaconRoc, just a bit apprehensive on how applicable your experiences are to mine as you are the only reference right now...
Old 10-12-2015, 12:24 PM   #38
Shady195
Adding preload will "shorten" the amount of travel in the shock body. When I had teins recommended pre-load I was hitting the bump stops regularly over larger bumps.
Old 10-12-2015, 12:31 PM   #39
bfrank1972
Hmm that's now how I understand it, looking at the coilover assembly itself, nothing changes when adding preload except you're winding up the preload collar and compressing the spring above.
It *does* shorten the spring, so in theory if you add a lot of preload you could run into coil bind - but the basic recipe if you're hitting your bump stops is to add pre-load, not take it away. Doing so will increase your bump travel (wheel moving upward toward your fender) and decrease your droop travel (wheel extending downward away from your fender).
That's why I was confused - buy maybe I'm misunderstanding what you're experiencing.
Old 10-12-2015, 12:36 PM   #40
Shady195
its very plausible i am explaining myself wrong or totally have it wrong all together. Carry on without me.
Old 10-12-2015, 12:53 PM   #41
bfrank1972
Hah, no sweat - I'm not a suspension expert by any means, just trying to help if I can - I'm planning to install a set of Street Flex's in a couple weekends, so I did do some study to understand how preload works though, made a post not long ago about how it works if you're interested in reading it:
http://www.ft86club.com/forums/showp...&postcount=254
Old 10-12-2015, 05:47 PM   #42
Trettiosjuan
Drives: GT86
When I had teins recommended pre-load...
... Which is?? Please tell me, it's like a public secret with only me not knowing :/
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 04:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 04:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 04:12 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 02:10 PM
FS: Tein Flex Coilover Jade 86 Brakes, Suspension, Chassis 43 06-15-2013 10:35 PM
