#29 |
Drives: 2005 Toyota Camry
#30 |
PROUD OF BOXER
Drives: Raven FR-S
right, but what im asking is whether or not the tech's statement is in-line with other spc arm user's experiences. ive been led to believe that at my current ride height, i should have been able to hit factory rear alignment specs with only rear control arms.
#31 | ||
#32 | |
Custom User Title
Drives: Asphalt FR-S MT
#33 | |
PROUD OF BOXER
Drives: Raven FR-S
i should have them installed and my toe corrected in a few days.
#34 | |
Drives: Toyota GT86
Thanks (I know it's an old thread, but if you are still there) |
#35 | |
Drives: '22 BRZ
About the original post. No issues setting my SPCs and no issues with slipping even after hitting lots of potholes and dirt road silliness.
It's also pretty annoying to have to swap out a pressed in bushing.
| The Following User Says Thank You to DocWalt For This Useful Post: | Tor (01-05-2016) |
#36 | ||
Drives: Toyota GT86
Most people who lower and don't install LCA at all, don't have toe issues with stock arm and bushing. They usually come out with about -2 deg camber. Is it correct to assume the problem is more likely to occur if you try to stand the wheel back up to e.g. -1 deg? My desired rear camber adjustment range would be around -1.7 to -2.3 deg (with corresponding increase in front camber as well). Am I likely to face problems with that? Quote:
#37 | |
Drives: '22 BRZ
I went to -1.9 in the rear, toe adjustment is slightly off center as expected. Absolutely no issues with a performance alignment. I also tried to stand the rear camber up to -1.0 and I maxed out the toe adjustment correcting, so I can see how people have run into issues with getting factory tame street alignment. |
#38 |
Drives: Toyota GT86
Sounds good.
![]() How much camber do you run the front, -2.5? -2.7? |
| Sold: SPC Rear LCAs | vanetix | Brakes, Suspension, Chassis | 3 | 10-23-2014 12:51 AM |
| For Sale SPC LCAs | Tylub | Brakes, Suspension, Chassis | 2 | 08-12-2014 05:57 PM |
| Rubber bushing LCAs | unsurety | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 06-15-2014 03:19 PM |
| AP Rear LCAs | JDLAutoDesign | Brakes, Suspension, Chassis | 2 | 04-17-2014 03:43 PM |
| Racer X LCAs | bakerr6 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 08-18-2013 03:46 AM |
