Old 04-28-2015, 05:50 PM   #29
fasteddy
Sorry to hear about your troubles. I was hoping to bump into you at BIR this summer. Good luck with this, hopefully it is not too expensive!
Pat
fasteddy is offline   Reply With Quote
Old 04-28-2015, 05:58 PM   #30
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Pat
Oh, you'll still see me at BIR - this will be fixed by then. Hell, i'm still shooting for GRIDLIFE may 29th in Michigan!
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 05-02-2015, 02:05 AM   #31
Gopherboy6956
Quick Update - Motor is out and starting to tear off the accessories.
Did a leakdown test on Cyl 1 and found that the air was coming out the pcv / crank case hoses so full teardown and will likely be a burnt piston or scored wall
Taking inventory and unhooking the easy stuff
S/C Off
And out!
Removed most of the accessories
Almost ready to dig in!
The Following User Says Thank You to Gopherboy6956 For This Useful Post:
shiumai (05-02-2015)
Old 05-02-2015, 03:52 AM   #32
Stumpygt86
Drives: Toyota GT86. N/A for life
Originally Posted by Gopherboy6956 View Post
Update #2 - This is the plug from Cyl 1. Hmmmmmmm. So, now i'm pulling the engine to figure more out. Will keep things updated as i go.
Top of that spark plug has vanished. Hope you find the cause
Stumpygt86 is offline   Reply With Quote
Old 05-02-2015, 02:13 PM   #33
blown
Drives: ft86
mine popped the same way.. innovate stage2.. huge clouds of smoke at WOT.. idled fine and drove fine but it burned through 1 quart of oil on a 45min drive.. I did a leakdown which seemed to pass, but I also had tons of oil in the PCV catch can and oil all over the intercooler/manifold..
blown is offline   Reply With Quote
Old 05-02-2015, 02:19 PM   #34
blown
Drives: ft86
forgot to mention I was running the delicious tune.
Old 05-02-2015, 02:33 PM   #35
Gopherboy6956
So what was the fix for you?
Old 05-02-2015, 02:39 PM   #36
Frogamazog
Drives: Soon to be a BRZ
Really sucks about your situation man, but huge kudos to your excellent posts to keep the rest of us informed.
"My other ride is a 175mph bus"
Frogamazog is offline   Reply With Quote
Old 05-02-2015, 03:01 PM   #37
blown
Drives: ft86
still not fixed. bought a built motor and added 335 kit to it. I did not have time to tear down my old motor yet.
Old 05-02-2015, 03:03 PM   #38
aagun
Drives: 86
oh that bad >< leaning the mixture makes power but add heat on the piston
ok as my Experience on fa20 shit . that the DI loss same injection volume . so if we lean the total mixture to 12.2 . there are one of the injectors leaner then the others like 12.8 or so that's insurance the heat in the cylinder . as ur cyl1 likes overheat
aagun is offline   Reply With Quote
Old 05-02-2015, 03:13 PM   #39
Gopherboy6956
Where'd you get your motor? What was the cost. I have a race in less than a month, and pending what I find today as I get into it i might just buy another also.
Old 05-02-2015, 09:43 PM   #40
Gopherboy6956
Update - Got to the pistons. not terrible. But it looks like I will need new pistons. Wall is a little scored, but not badly.
Timing Cover off -
Cams!
Just tip it liiiiitttle bit
Valves!
Piston 1
Scoring
Will start talking to some local shops about rebuilding it for me. I was find tearing it down, but i don't want to replace pistons and rebuild it myself. OR, i still might buy a used one and put this off as a project.
Old 05-04-2015, 02:25 AM   #41
ka-t_240
I am totally photobombing your engine pics.
Motor ready to head to RS yet?
ka-t_240 is offline   Reply With Quote
Old 05-04-2015, 09:39 AM   #42
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
Crazy crazy
With the scoring, do these motors bore easily?
Whats the plan on that?
BlueSky is offline   Reply With Quote
Smoke from exhaust when warmed up after parking Elkton86er Engine, Exhaust, Transmission 1 12-03-2014 03:00 PM
White smoke coming from the exhaust. hansthegerman Engine, Exhaust, Transmission 17 10-02-2013 05:23 PM
Turbo, white smoke out the exhaust, ideas? Synack Forced Induction 44 09-09-2013 10:57 AM
Smoke coming from the Exhaust peachsnow Scion FR-S / Toyota 86 GT86 General Forum 18 12-09-2012 03:59 AM
Smoke from new USA TRD exhaust DaveFTW Engine, Exhaust, Transmission 22 10-03-2012 05:03 PM
