Old 04-22-2015, 07:20 PM   #29
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
So if I already have a coil setup with spring rates favouring the rear by only 18% would a slightly larger rear sway bar compensate for the mild spring rate difference? I currently have an OEM WRX STI rear sway bar on the car for winter mode and DD but if it helps the balance of the car and overall grip as you've shown through fast corners should I dust off the 21mm?
Canehda is offline   Reply With Quote
Old 04-22-2015, 07:24 PM   #30
you're probably already okay as-is
Old 04-22-2015, 07:38 PM   #31
djliquidsteele
Drives: Scion FR-S
Not sure if I missed it, but I am curious if either car had a staggered wheel/tire setup.
djliquidsteele is offline   Reply With Quote
Old 04-22-2015, 09:23 PM   #32
Both cars have square wheels/tires.
Old 04-23-2015, 06:24 AM   #33
puma
crew chief
puma's Avatar
Drives: Race car FR-S
how about gps trace, it might just be that the green car overshot the corner so needed more steering input? How come is the blue car losing all that time on the acceleration?
puma is offline   Reply With Quote
Old 04-23-2015, 12:05 PM   #34
If that were the case, more steering input certainly didn't increase the lateral G, which demonstrates understeer.
The particular lap in the blue car wasn't meant to be a hot lap. This is strictly to demonstrate the effect of static understeer setup versus balanced setup.
Old 04-23-2015, 04:33 PM   #35
misooscar
misooscar's Avatar
Drives:
Do you think the stock set up is neutral at 2.0 front camber and 1.5 neg camber with RS3s 225, 17s, on rpf1s at 7.5 in width at 250whp? (Vortech stock 9psi tune)
misooscar is offline   Reply With Quote
Old 04-23-2015, 04:49 PM   #36
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Does this confirm the reason behind the Fortune Auto 500 v5 being 6k/7k being a decent starting setup? Although the rates are not as high it should still provide a nice balance for the non-frequent trackster?
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 04-23-2015, 06:49 PM   #37
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I'm interested in the above post as well. I have rce tarmac2s en route to me with both 400 and 500 lb spring sets. This makes me want to put a set of 500's on the rear and leave 400's on the front. I'm on stock sways and 450whp.
Old 04-23-2015, 07:03 PM   #38
wparsons
wparsons's Avatar
T2's with 400F/500R is similar balance to the CSG Tein SRC's in terms of front to rear spring rates, I've actually been looking at buying that setup myself.
flickr
Old 04-28-2015, 05:04 PM   #39
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
The Green car is representative of coilovers that utilize the same spring rates front and rear, or have a small stagger with the rear being larger.
The Blue car is representative of cars that utilize coilovers that have a 20-25% higher spring rate in the rear.
Hmmmm. I have Tein MonoSports, which are 8k front and 9k rear. That's less than a 20% difference. Would that put them in the green car camp?
sittinSideways is offline   Reply With Quote
Old 04-28-2015, 10:22 PM   #40
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
This is a snapshot of data being taken from two different cars at the "Sweeper" at Buttonwillow Raceway Park, which is a flat, 180 degree turn. The lines are as follows:
- GPS Speed (Speed as determined by GPS, not by the car's ECU)
- Steering angle in degrees
- Gas pedal input (in percent from none to WOT)
- Lateral acceleration as determined by GPS (Lateral G's)
- Rate of yaw, as determined by GPS (yaw rate in degrees per second)
- Lap time differential between the green and blue traces
The first thing to note, is that the green car is slower through the entire corner (graph 1); the corner is identified by the red line at the top of the graph labeled "16".
The second thing to note, is that the green car reaches peak cornering grip (graphs 4 and 5) at about 80 degrees of steering input (graph 3), whereas the blue car only requires about 60 degrees of steering input. Even with less steering input, the blue car actually maintains higher cornering grip (compare the green and blue lines on graphs 4 and 5)!! The time gained by the blue car is shown by the differential dropping in graph 6. Even though the Green car is on the throttle more through the second half of the corner, it actually makes the understeer worse, and the blue car is able to go faster!
Why is it that at the exit the green car is carrying a little more speed out starting from the 12500 mark? Everywhere else on that chart the green was slower or at most same speed as the blue line.
Old 04-28-2015, 10:29 PM   #41
Because the green car had a much more aggressive corner exit (look at the throttle position). Too much throttle actually resulted in needing to countersteer when going over a bump!
Old 04-28-2015, 10:44 PM   #42
solidONE
solidONE's Avatar
I can see where he lifted then stabbed the steering a few degrees then lost that extra speed he had.
You should do more of these, Mike. Even better with corresponding video showing what happened.
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 06:36 AM
FS: Michelin X-Ice and Sport Design 17" Winter Setup Jay H Wheels and Tires 5 10-31-2014 12:08 PM
(Back up!) FS in FL: Drag DR-31 17x9" Square setup 5x100 (or 5x114.3) +38 Kido1986 Wheels and Tires 5 01-10-2013 03:21 PM
FS in FL: Drag DR-31 17x9" Square setup 5x100 (or 5x114.3) +38 GTB/ZR-1 Wheels and Tires 1 12-06-2012 07:22 AM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
