Old 03-13-2015, 06:20 PM   #29
ddeflyer
Originally Posted by fatalelement View Post
Best phrase of 2015.
Can we get a "stuntin and splodin" official subforum or maybe just a t shirt
Sent from my HTC One_M8 using Tapatalk
Wish I could take credit for the phrase, but it is a common term in Lemons racing. The "splodin" part is sometimes fairly literal...
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline
The Following 2 Users Say Thank You to ddeflyer For This Useful Post:
fatalelement (03-13-2015), Jive Turkey (05-02-2016)
Old 03-13-2015, 06:42 PM   #30
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Am I correct in understanding this device also still leave ABS functional?
venturaII is offline
Old 03-13-2015, 06:43 PM   #31
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Originally Posted by CSG David View Post
Or you can spend 2 seconds and do the pedal dance. Gawd...I hate moving after working out just my right leg and right arm.
My problem is waiting for the engine to warm up to do the dance. I like the idea of a device that forces the car into to no nannies mode. While this version does not suit my data logging needs, I'm guessing there are plenty of people that would be quite happy with this one.
Sleepless is offline
The Following User Says Thank You to Sleepless For This Useful Post:
chas3wba0 (03-14-2015)
Old 03-13-2015, 07:05 PM   #32
CSG David
CSG David's Avatar
If that's one of the cases, I usually go 10% on warm-up lap to make sure everything gets up to temp and pull into the hot pit. Shut off, start up, do pedal dance, and go back out. It also allows some people to get out of the way for me so I can run some cleaner laps.
Most of the time I start up the car 5 minutes early and drive around the paddock to make sure everything else is warmed up. I have a LSD too.
CSG David is offline
The Following 2 Users Say Thank You to CSG David For This Useful Post:
DAEMANO (03-13-2015), zdr93523 (03-13-2015)
Old 03-13-2015, 07:29 PM   #33
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
yes, ABS still works and is untouched(unless you pull the fuse)
continuecrushing is offline
Old 03-13-2015, 07:35 PM   #34
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Pulling into the pits is a pretty good idea. I normally start my car 15 minutes early, get it warm, get the pedal dance done, get my harness on (ish), get to grid, start my camera, get my helmet on, get the harness tight... then I'm ready. Those minutes seems to tick by pretty fast.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline
The Following 2 Users Say Thank You to zdr93523 For This Useful Post:
CSG Mike (03-13-2015), RavioliG (07-30-2017)
Old 03-14-2015, 07:48 AM   #35
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
For:
1/ Saves time doing pedal dance. Yay! I have an extra 10 seconds to play with!
2/ Reduces weight of wallet therefore increasing power to weight. (Ok, I know strictly speaking it's power to mass.)
3/ Has bragging rights before the prang on the street and automatically disappears from conversation after.
Against:
1/ Can't use Aim OBD connection.
2/ Of limited practical use to me given the expertise I have in pedal dancing. To become as proficient as me just watch some Riverdance clips. Music is optional.
3/ Device doesn't come in colour options so there is little chance of getting it to match my racing underwear. You know the ones? Its the type with the brown racing stripe down the middle at the back.
Captain Snooze is offline
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
Ultramaroon (03-30-2015), wparsons (03-14-2015)
Old 03-23-2015, 01:59 PM   #36
8686
8686's Avatar
Drives: 86
@FT-86 SpeedFactory will it work on AT transmission?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline
Old 03-23-2015, 02:05 PM   #37
simpleisbest
Senior Citizen
Drives: Scion FR-S
For:
Against:
You all know they have OBD2 splitters on the market, right?
[ame="http://www.amazon.com/OBDII-Splitter-J1962M-2-J1962F-145802/dp/B000TMCX72/ref=sr_1_1?ie=UTF8&qid=1427130290&sr=8-1&keywords=obdii+splitter"]Amazon.com: OBDII Splitter Y Cable, J1962M to 2-J1962F, 1ft (145802): Automotive[/ame]
simpleisbest is offline
Old 03-23-2015, 02:10 PM   #38
sstfnv
sstfnv's Avatar
It was already said in this thread that data loggers don't work with OBD splitters.
Most datalogging systems are not compatible with a Y splitter.
sstfnv is offline
Old 03-23-2015, 02:22 PM   #39
simpleisbest
Senior Citizen
Drives: Scion FR-S
Never heard of that. I can imagine if both accessories needed 12v, that the draw might be too much. They do have dongles with added 12v out there, though...
Old 03-23-2015, 03:20 PM   #40
sstfnv
sstfnv's Avatar
its not about voltage, its about communication protocols.
sstfnv is offline
The Following User Says Thank You to sstfnv For This Useful Post:
Old 03-24-2015, 12:12 AM   #41
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Recommendation for product update:
Same device with an output to a switch and the device itself is a pass through so there's still an OBDII port to plug into for data logging.
Car's OBDIIport->Device w/ switch and female OBDII port on it->whatever else you want to plug into the OBDII port (like data logging).
This way, you leave the device plugged in and just the act of flicking the switch turns the pedal dance function on/off but the device accepts another OBDII connector and it's data to flow through it into the computer.
Everyone wins.
SCCA T4 - FRS
rice_classic is offline
Old 03-24-2015, 08:56 AM   #42
Rickg87
Drives: 2012 Scion FRS
Everyone wins.
Sounds Good. Could you give some more detail about the switch and setup
Thx
Rickg87 is offline
The "Pedal Dance" testing CSG Mike Tracking / Autocross / HPDE / Drifting 419 08-01-2023 11:46 PM
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open romin Engine, Exhaust, Transmission 468 11-26-2021 05:05 PM
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 12:24 PM
Pedal Dance Device robot Tracking / Autocross / HPDE / Drifting 3 01-10-2014 10:26 AM
Additional "pedal dance" testing. CSG Mike Tracking / Autocross / HPDE / Drifting 55 08-27-2013 04:02 AM
