Old 03-17-2015, 01:23 AM   #29
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Phantobe View Post
Is there an updated template file for this yet? I'm able to save multiple files, but the save prompts don't come up as text just as #s.
Ex: Instead of saying "Would you like to save this datalog?" It would just come up as "6034".
You shouldn't need an updated template. At least I didn't when I was beta testing the new update. But I'll know for sure once I get back to the mainland tomorrow night. I'll update this thread accordingly.
Old 03-17-2015, 03:12 PM   #30
trdric
Drives: fr-s
same here its says 6034 and 6033 if im not wrong when I am saving. Still works when i download the files tough.
trdric is offline   Reply With Quote
Old 03-17-2015, 03:40 PM   #31
Shiv@Openflash
Drives: 2013 FRS
Looks like a new template file is required after all. I'll be posted it online shortly. All it does is replace those numerical messages with actual English. I'll also go ahead and put the new user software online as well. Looks like I won't be back in CA until Wed night so I don't want to keep you guys waiting that long
Old 03-17-2015, 04:11 PM   #32
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Hell yeeeaah!
Great past couple updates, can't wait to see what else you guys have up your sleeves O.o
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 03-17-2015, 04:13 PM   #33
Shiv@Openflash
Drives: 2013 FRS
New OpenFlash Manager (v1.18) and new Template File (FRS Template File 6) are now available for download: http://openflashtablet.com/Automotiv...ads/index.html
The new version of OFM will now allow you to manage (delete and export) multiple data log files. The new Template file will give you new never-seen-before messages like:
"Do you want to save this new Data Log file?"
"Saving Data Log file. Please do not interrupt this process"
"File storage limit reached. Please delete at least one file using OpenFlash Manager"
Old 03-17-2015, 08:28 PM   #34
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
YAY!
Old 03-17-2015, 08:52 PM   #35
sstfnv
sstfnv's Avatar
I'm having some problems with the new update. When I click on the logs I get an error message. See the screenshot. I have updated the template as well. Any suggestions?
sstfnv is offline   Reply With Quote
Old 03-17-2015, 08:57 PM   #36
trdric
Drives: fr-s
same here
Old 03-17-2015, 09:42 PM   #37
Shiv@Openflash
Drives: 2013 FRS
Unfortunately I won't be able to do anything until I get back to the mainland tomorrow night. I have no access to an OFT or a FRS here in Hawaii
What happens when you select continue? Does it crash?
One thing I recommend doing is deleting your entire Openflash folder and running the new installer from scratch. Some have had problem with updating old files to new files. So a fresh install usually solves most problems.
Old 03-17-2015, 09:53 PM   #38
zc06_kisstherain
Drives: SWP BRZ
I havent used multiple log saving functions yet
but mine works fine
Old 03-17-2015, 10:08 PM   #39
sstfnv
sstfnv's Avatar
When I click continue nothing happens and I'm able to export the log but the CSV file is pretty much empty. I will try to install it on a different PC tomorrow and will post my findings.
but mine works fine
It worked with the old log but once I added a new one then it started crashing.
Old 03-17-2015, 10:20 PM   #40
Shiv@Openflash
Drives: 2013 FRS
If you could, go to debugging and create a debugging file. Do this right after you run into this error message. And email it to me at shiv@openflashperformance.com. I can look at it and should be able to see what is going on.
Old 03-17-2015, 10:31 PM   #41
trdric
Drives: fr-s
just sent you !
Old 03-17-2015, 10:52 PM   #42
sstfnv
sstfnv's Avatar
Done. I sent you my debug file as well.
OpenFlash Tablet will not connect to OpenFlash Manager rever5e Software Tuning 10 03-12-2022 10:17 AM
FS: Brand New Openflash Header AND Openflash Tablet combo FT86POWER Engine, Exhaust, Bolt-Ons 6 02-11-2015 02:56 PM
Openflash Tablet + Openflash Header smellslikecurry Engine, Exhaust, Bolt-Ons 9 12-01-2014 06:20 PM
OpenFlash Tablet: Enhanced Data Logging (Sneak Peek) Shiv@Openflash Software Tuning 51 06-03-2014 07:09 AM
OpenFlash Tablet v1.55b: BIN files added! Shiv@Openflash Software Tuning 525 04-09-2014 09:42 PM
