#29 |
Drives: FRS
snowman snot variation
Stationary store sticky snot is instantly removable.
There is a substandard snot that is to sticky, and will run in hot weather. If by chance you get the substandard, you will not have wasted your 99 cents, just mix some room dust in it and it will be fine. Tape leaves an area uncovered (outside top edge,) under the fender at rear, while snot can be pushed in with a credit card. I did NOT replace the gaskets, just sealed them with gasket sealer. Goin fine since I figured out the problem in June of 2012 - no wa wa !
#30 |
Drives: 2022 BRZ
| Oil Leaking?? | tonytduc | Issues | Warranty | Recalls / TSB | 371 | 11-13-2016 07:14 PM |
| Car leaking | davebrus | Issues | Warranty | Recalls / TSB | 4 | 03-21-2014 11:23 AM |
| Oil leaking? | grgonium | CANADA | 7 | 07-30-2013 04:08 AM |
| Still Leaking? | 636 | Issues | Warranty | Recalls / TSB | 15 | 01-11-2013 03:41 PM |
| Leaking Oil? | 636 | Issues | Warranty | Recalls / TSB | 11 | 01-05-2013 04:43 PM |
