Old 03-04-2015, 02:55 PM   #29
Racecomp Engineering
Originally Posted by bholliday View Post
Andy, have the the dyno plots for the Bilstein B14 been posted somewhere or, is that something you have done on your own equipment?
They have not been posted. I would have to ask Bilsteins permission to post and I'm not sure they want me to.
- Andy
Old 03-04-2015, 08:46 PM   #30
bholliday
Drives: 2022 BRZ Premium
Thanks. I've been thinking about shock options and was just curious if I had missed it.
bholliday is offline   Reply With Quote
The Following User Says Thank You to bholliday For This Useful Post:
BRZHarley (12-19-2015)
Old 03-07-2015, 12:23 PM   #31
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Not sure if it's 100% accurate for the 86 platform, but for the Lexus GS, some guys were able to revalve BC Racing shocks using Bilstein 46mm parts.
http://www.clublexus.com/forums/gs-f...ml#post8860594
BC Racing coilovers include top hats, come with springs, and some include external reservoirs (if that's your bag). I'm sure their build quality isn't quite Penske-level, but this could be a really interesting option for some people.
Also, got in contact with a fellow who does alot of shock tuning (with a Rhoerig) in New England. Will update as things progress.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 03-08-2015, 12:23 PM   #32
Shankenstein
Frosty Carrot
Mildly interesting finds:
- Apex'i uses 44mm pistons.
- AST uses 44.5 and 50mm bodies for their inverted applications.
- Bilstein's standard pistons are 36mm and 46mm. No combinations like Penske, though
- Fortune Auto uses 50mm pistons.
- JIC uses 40mm pistons.
- JRZ appears to use 44mm pistons.
- KW uses 33mm pistons.
- Megan uses 44mm pistons.
- Neo Motorsport uses 25 mm for twin tube pistons.
- Ohlins's standard pistons are 25, 36, 40, and 46mm. They have some interesting designs
- Penske's standard pistons are 45mm and 55mm. They're gorgeous!
- Ridetech uses 46mm pistons
- Tein uses 22mm for twin tube pistons
- XYZ Racing uses 45mm pistons
- Zeal uses 38mm for B/B2, 42mm for B6/S6, and 45mm for SF series
Not sure how interchangeable anyone's parts are... but it's good to start learning which parts are easily available (read: Penske, Ohlins, and Bilstein).
Old 03-08-2015, 04:05 PM   #33
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Quick question; what does piston size advertantly effect in the damper feel?
Old 03-08-2015, 05:19 PM   #34
Shankenstein
Frosty Carrot
Not an expert, by any means... but Pressure Difference * Area = Force.
Bigger pistons have more available area for generating the pressure differential. The pressure differential is still defined by:
Things get complicated, since area is a fuzzy concept here. It's an equivalent area, because some of it is resisting and some of it is flowing. Flow rate (Q) and density also start getting funny as you push towards higher Reynolds numbers (measure of turbulence). Shock oil is relatively incompressible, but if you crank up the pressure differential, the turbulence will cause the air suspended in your shock oil to cavitate/foam. When the fluid becomes compressible, the physics start breaking down and the shock becomes less effective.
Also, bigger piston diameters usually accompany bigger rod diameters, which can transmit the resisting force more easily.
The Following 2 Users Say Thank You to Shankenstein For This Useful Post:
cdrazic93 (03-08-2015), Createddeleted (03-21-2015)
Old 03-08-2015, 05:26 PM   #35
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Total engineers answer to that question, lol I love it
The Following User Says Thank You to cdrazic93 For This Useful Post:
Shankenstein (03-08-2015)
Old 03-08-2015, 05:32 PM   #36
Shankenstein
Frosty Carrot
The Following User Says Thank You to Shankenstein For This Useful Post:
Old 03-10-2015, 09:37 AM   #37
Shankenstein
Frosty Carrot
Quick update from the take-apart world.
Ballpark quotes for everyone!
Penskes = $7k for non-adjustable, $7.5 - 8k for double adjustable, $8.5 - 9k for triple
Bilstein MDS = $7k, bring your own springs
Old 03-21-2015, 05:22 PM   #38
Shankenstein
Frosty Carrot
Got confirmation from BC Racing about some interesting things:
- Their coilovers use 46mm pistons that can be substituted with Bilstein/Ohlins parts.
- They sell replacement parts so that your local suspension shop can revalve/rebuild using BC components.
- Their shop in Florida can build a set to spec, and service is pretty inexpensive.
- Parts are not peened or staked... just loctite on the shock nut.
It seems like the BC Racing ER series would make a fine platform for Frankendamper. The external reservoir would allow for easy depressurizing and re-pressurizing. The piston/shim options are endless, and spare parts are cheap.
With everything set to full hard, you can set the valving for autoX and track usage... then open the adjusters for street.
My main concern with BC is corrosion. Their "black chrome" coating on the threads is more likely to gum up, compared to Bilstein's 3-layer plating.
Old 03-21-2015, 09:40 PM   #39
Calum
That Guy
Drives: 2013 asphalt FRS MT
For the potential price difference, just anti seize the hell out of them every few months. Or get a can of rustcheck and spray them down.
The Following User Says Thank You to Calum For This Useful Post:
Shankenstein (03-21-2015)
Old 03-22-2015, 01:57 AM   #40
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Last time i checked the 7500 series double adjustable can be made for this platform with the addition of springs for ~$3200? Thats what i got from the Penske development thread.
Old 03-22-2015, 12:47 PM   #41
Shankenstein
Frosty Carrot
I put up the prices from my local Penske dealer. I'm guessing that includes shipping and some mark-up.
According to latest from ANZE, the prices for Penskes are: Link to PDF price sheet
- $4300 for single adjustable
- $5090 for dual adjustable (inline)
- $5905 for dual adjustable (ext res)
- $7415 for triple adjustable (ext res)
Ryan from Penske hinted that they would be based on the 7500, 8300, and 8760.
Old 03-22-2015, 02:23 PM   #42
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Thats a huge mark up! Lol i wonder if they would be able to retro fit an 8765 in there? Because racecar.
That single adjustable from ANZE with Penske internals is a huge contender for the JRZ and MCS crowd.
**NEW**Bilstein B8 HD Struts and Shocks Released FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 118 09-12-2016 02:54 PM
Bilstein B6/B8 and B14 shocks setting Mars2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-26-2014 11:24 PM
Swift Spec R with Bilstein B8 shocks? JMoore412 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-23-2014 02:52 PM
Bilstein shocks & struts Fizz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-31-2013 03:56 AM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 04:12 PM
