Old 02-27-2015, 01:31 PM   #29
PeterFRS
PeterFRS's Avatar
Drives: FRS
just use OEM filters..
Sorry, I'm just trolling..
Use whatever you like they're all reputable companies..
But I guess when time comes to get warranty claim through, might become a hassle
I just like the toyota service department coffee too much to be bothered ordering oil filters online
PeterFRS is offline   Reply With Quote
The Following User Says Thank You to PeterFRS For This Useful Post:
0351USMC (02-27-2015)
Old 02-27-2015, 10:11 PM   #30
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
Originally Posted by Koa View Post
In my haste, I now realize that you aren't the OP.
touché, good sir.
Pulled out the popcorn for that pissing contest.
That pink JDM filter though....
In all seriousness my dealership can try to pull some BS. Helps that I work with the Feds and childhood friends with several lawyers who love a challenge and can write quite the threatening document if the dealership tries to defy 15 USC § 2301
0351USMC is offline   Reply With Quote
The Following User Says Thank You to 0351USMC For This Useful Post:
Celadrielas (03-02-2015)
Old 02-27-2015, 10:25 PM   #31
0351USMC
0351USMC's Avatar
Originally Posted by adamg View Post
We're talking about oil filters right?
What about cabin filters? Is there a TRD version?
My google-fu has turned up no cool JDM or TRD cabin air filter. My inner fanboy is crying (sarcasm)
Old 03-02-2015, 01:42 PM   #32
OnkelC
OnkelC's Avatar
Drives: 2017 Fiesta ST
I want a cabin air filter by K&N.
OnkelC is offline   Reply With Quote
Old 03-02-2015, 03:42 PM   #33
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by 0351USMC View Post
"Should something go wrong, the warranty provider will need to determine the cause of the problem. The Federal Trade Commission says, “The manufacturer or dealer must show that the aftermarket or recycled part caused the need for repairs before denying warranty coverage.” That means if the dealer can prove (the burden is on the dealer) the problem was caused by the wrong viscosity or a poor quality oil filter, your warranty can be denied. Warranty protection would still be in effect for other parts of the cars"
Let them try to prove an HKS filter under performed and caused damage
If you've seen what's happened to some of the owners you'd know that statement doesn't mean much. You are at complete mercy of the dealer until things escalate to a much higher level.......
Old 03-02-2015, 05:40 PM   #34
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
Just to add a small note to this, I will be getting oil changed at the dealership until my 100,000 mile / 7 year warranty expires.
I brought my car into the dealership after I got yet another exhaust leak. They tried to tell me the vehicle hadn't been properly maintained, but lost that due to service records since ownership have all be through the same dealer, and vehicle was bought CPO.
They finally tried to tell me it was clear I "Race the car" because I have aftermarket 225/40/r17 tires wrapped on the stock rims they told me were "aftermarket" at first.
End result, They are replacing my entire exhaust -- Header to muffler -- underwarranty on thursday and gave a stern warning because they had no footing. What was wrong? Bad gaskets. But the vehicle had an aftermarket overpipe (no other exhaust parts).
It sucks, but whatever. I'm not paying a dime for it so, whateves. I know it's not oil based, but it's the sort of crap dealers pull
The Following User Says Thank You to Celadrielas For This Useful Post:
0351USMC (03-03-2015)
Old 03-03-2015, 06:31 PM   #35
Dezoris
Dezoris's Avatar
Unless you have a very specific need to switch to a higher end filter the quality of the Tokyo Roki (OEM) is very good. Most every one on here who has tracked or done UOA has had no issues with filtration using them. This same(very similar) filter element was also used in the S2000, RX8 etc.
Oil Filters, ENEOS Oil, Redline Oil, Brake Fluid and Air Filters @ OAKOS.com OAKOS Automotive Mechanical Maintenance and Tools 50 11-02-2015 10:03 AM
oil filters MonoRaven Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 06-16-2015 08:01 AM
Oil Filters, ENEOS Oil, Redline Oil, Brake Fluid and Air Filters @ OAKOS.com OAKOS Automotive Mechanical Maintenance and Tools 144 01-20-2015 11:37 AM
GTA - air filters BRZ vs FRS chenshuo CANADA 0 03-09-2014 11:39 PM
Air filters Ryan86 AFRICA 14 12-31-2012 04:35 AM
