Old 03-16-2018, 05:25 AM   #29
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I have gotten this CEL before too. But it was caused by a cheap OBD2 port reader. I'd get communication error CEL sometimes too.
Old 04-02-2018, 09:45 PM   #30
classybum
classybum's Avatar
Drives: 2013 Asphalt FR-S
Originally Posted by coldstart View Post
Same thing happened to me, same code. Driving hard one day, home, parked overnight, commute to work in the morning, gas light comes on, CEL comes on with same code. BTW, I have slight scratches on my driver side window as well and it looks like the track or 'grabber' inside the door is making them.. 2013 FRS, 38k miles.
I just got this cel tonight for the first time. Also a 2013 frs, but about 60k miles. Been running ofh3, oft, e85,drop in filter since Nov 2016. Cel came on shortly after the fuel light this morning. Filled up and cleared the code. No drivability issues.
I now understand to keep the tank full, given the explanation above that makes sense, but it still feels a little bit like a bullshit dealer excuse. Never had this issue with the six beaters I've driven into the ground the past 20 years.
Really wanted to make some lame jokes about keeping the tank low for weight reduction to max my 1/4 Mile times, but I'm a day late.
Anybody have a conclusive solve for this issue yet?
Sent from my SM-G920V using Tapatalk
classybum is offline   Reply With Quote
Old 05-30-2018, 05:05 AM   #31
easterbrz
easterbrz's Avatar
Drives: Silver Subaru BRZ
Hello, had same issue.
The readings on fuel gauge are off and when the check engine light comes on, car starts kinda weird. It feels like the batter is not charged fully, but that is not the case.
Still looking for the solution.
easterbrz is offline   Reply With Quote
Old 05-30-2018, 05:18 AM   #32
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Trap63 is offline   Reply With Quote
Old 06-04-2018, 07:11 AM   #33
easterbrz
easterbrz's Avatar
Originally Posted by Trap63 View Post
So there is 2 ways to solve this problem?
1. Change those sensors
2. Don't let fuel in the tank to drop below 50%
Or maybe there is more solutions?
Old 06-05-2018, 03:43 AM   #34
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I've had this code using OFT before as well, but it seems your issue might actually be the sensors. You not only have a fuel issue on startup but also a gauge issue, for people with OFT its mostly been just the CEL
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Trap63 (06-05-2018)
Old 06-18-2018, 05:45 AM   #35
easterbrz
easterbrz's Avatar
Any idea how much the sensors could cost and if it is possible to change them myself?
Old 06-18-2018, 02:14 PM   #36
FRSBRZGT86FAN
I'm not really sure as there could be extraneous gaskets and other stuff but I know the fuel gauge sending unit itself is $80:
https://parts.conicellitoyotaofconsh...nit-su00301105
Old 06-27-2018, 10:24 AM   #37
easterbrz
easterbrz's Avatar
Thank you for the info, will try to solve the problem somehow...
Old 07-18-2018, 09:54 AM   #38
easterbrz
easterbrz's Avatar
Ok so yesterday was the day that I had enough of Check Engine light bullshit, so I took both fuel senders out and find that there is a fuel line that connects both of them. That line was trapped below one of the fuel level sensors blocking it to drop all the way down. After I untangled them and assembled everything back it works perfectly. No Check Engine light, no wrong readings in the fuel gauge.
For information how to take fuel senders out I used this YouTube video (there is actually two senders, one under each back seat, the removing process is the same as in video)
The guy in video shows how to remove fuel pump, you don't need to do it, just to take all that white thing out and check if nothing is trapped under / above fuel level sensor:
[ame]https://www.youtube.com/watch?v=ELq72XVlJrY[/ame]
PRO TIP: If you will try this method, make sure you are almost empty on fuel, because there is 99% chance that it will spill out when you will try to remove the fuel sender from fuel tank.
How those two senders looks like and how they are connected:
https://pasteboard.co/HvaTiug.png
The Following User Says Thank You to easterbrz For This Useful Post:
humfrz (07-18-2018)
Old 07-18-2018, 09:32 PM   #39
humfrz
Good informative post -
humfrz
Old 07-19-2018, 07:09 AM   #40
BRZnut
Drives: BRZ DGM Limited
How did the lines get tangled? Just by chance?
Old 07-19-2018, 08:03 AM   #41
easterbrz
easterbrz's Avatar
I'm from Lithuania and I bought my car from USA, so maybe somewhere in transportation process something happened (car got tilted too much, etc.), after I got everything to place test drove it really hard, but still no issues occurred (also gauge works properly), probably it's just by chance and really slim one.
Old 08-24-2019, 05:08 PM   #42
Jameson86
Jameson86's Avatar
Drives: Black Toyota 86
I have the same fuel issue and also the same freaking issue with my drivers window. also 2013 model
Jameson86 is offline   Reply With Quote
p0463,P013f and c1237 codes? feldy Engine, Exhaust, Transmission 28 12-14-2015 11:02 PM
Unichip throwing p0102 code ?? jdubz13frs Software Tuning 3 07-10-2014 03:27 PM
OBDII Bluetooth and Torque app, throwing CEL BRZPDX Issues | Warranty | Recalls / TSB 11 03-03-2014 02:03 PM
Throwing the gauntlet down. Gran Turismo or Forza? Sully Off-Topic Lounge [WARNING: NO POLITICS] 153 01-03-2014 01:27 PM
Throwing around an idea DrDuquette BRZ First-Gen (2012+) — General Topics 18 08-04-2012 08:27 AM
