#29 |
Drives: 2013 FR-S Series 10
This definitely COULD be user error but I think it is a combination of drivetrain lash and factory tune. I can be absolutely certain i am not pulsing the throttle myself and it will still do it at times.
When i had my OFT i dont remember it happening. The car is far more likely to do it when its cold than warm. It can even do it slightly in 2nd gear at times. Again right after its been started. So until everything warms up and tolerances get to where they were designed to be, it'll happen at some point no matter how gentle you are being on the throttle. This is "one of those things" this car does. |
#30 | |
Drives: 2014 BRZ Limited
I have had mine buck at that RPM. But I recognize that it's my inputs causing it and drive through it. Most people will hit the clutch instead. That's certainly a valid response but then the driver never realizes he was the one in control of the car and not the other way around. |
#31 | |
It's funny that you mention the tune. Some modern fighter aircraft are tuned to dampen the controls in slow flight to make them less responsive, effectively tuning out the danger zone for crashing the plane. Seems like you could do something similar with a tune on our cars. Maybe the tune you had from your OFT had a little bit of dampening tuned in. |
#32 |
Definitely could be, but again it only happens right after i start the engine. Leaving for work it happens almost every day. Coming home from work with warm engine, nada.
#33 |
Drives: 2017 Toyota 860 in Supernova
Doesn't this sort of thing happen with increasing pulsations with a lighter flywheel?
I know that in our Civic Si, which must have a lead based flywheel, we get very little of this compared to the 86. |
| Pulsing when Accelerating | carma143 | Issues | Warranty | Recalls / TSB | 41 | 02-27-2015 08:29 PM |
| Aside from 2015 Acura NSX and Toyota Supra, what else in 2015? | stockysnail | Northwest | 7 | 01-13-2015 02:30 AM |
| 2015 Series.Blue Engine "Chirp"and 2nd Gear Grind | s30series | Issues | Warranty | Recalls / TSB | 33 | 09-07-2014 01:26 AM |
| Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC | mav1178 | Other Vehicles & General Automotive Discussions | 1 | 05-23-2014 10:47 PM |
| weird pulsing while stopped | neil125 | Issues | Warranty | Recalls / TSB | 2 | 05-14-2013 11:04 PM |
