Koji_Online
Old 07-05-2012, 01:06 AM   #29
Gums
Drives: SWP BRZ
Thanks Everyone
A big thank you to Koji_Online, syelenik, ducks and normancw.
Hate a clutch that engages high.
Will have to take my spanners when I pick up my BRZ
Gums is offline   Reply With Quote
Old 07-06-2012, 02:37 AM   #30
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I'll be looking into whether this affects the clutch's disengaging/engaging .. I'm still fairly concerned :/
Old 07-08-2012, 01:39 AM   #31
sastexan
Drives: '13 FR-S Ultramarine manual
Originally Posted by Koji_Online View Post
Tighten the bolt & one final thing, look at the front of your clutch pedal, the first sensor up is for your cruise control & I believe relates to your gear indicator display (if you have it enabled); basically the gear displays only with clutch out, but now that you put your pedal closer to the floor it does not engage the switch on the sensor.
Am I missing something? What gear indicator display?
'13 FR-S - Ultramarine manual
(GONE) '98.5 Contour SVT - modded (and threw rod with buyer)
'01 Camry 5S-FE (wife's old car)
'11 Odyssey EX-L - familymobile and hauler - food-encrusted carpets and other appropriate features
sastexan is offline   Reply With Quote
Old 07-08-2012, 02:10 AM   #32
simpleisbest
Senior Citizen
Drives: Scion FR-S
You can set the display to show what gear you're in when the clutch pedal is in the released position. Directions are in the manual.
simpleisbest is offline   Reply With Quote
Old 07-08-2012, 04:17 AM   #33
|-Goku-|
|-Goku-|'s Avatar
Drives: 2011 Civic Si
What is there to be concerned about?
|-Goku-| is offline   Reply With Quote
Old 07-08-2012, 04:58 PM   #34
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Killing the actual clutch :[
Anyways, talked with a friend of mine who works in toyota services - he's also a car nut and only got good results.
This adjustment doesn't affect the actual engaging and disengaging of clutch.
Excited to do this on my car, I never was a fan of how high the clutch is!
Old 07-08-2012, 11:53 PM   #35
driver01
Drives: brz 13
by changing the length of the rod, the travel of the clutch pedal is being reduced, thus going out of specification. Wouldnt there be the posibility of the clutch not fully disengaging when the clutch pedal is depress?
Or as the clutch disc wears out, the travel needed to disengage the clutch might be larger making the issue even worse?
Just thinking that there is a specification for clutch pedal travel for a reason...
driver01 is offline   Reply With Quote
Old 07-09-2012, 02:19 AM   #36
Scaldy
Scaldy's Avatar
Drives: 2013 red FR-S mt
Thanks for the idea. With a "little help from a friend" I was able to adjust the clutch to a much lower point. This has to help the life of the clutch because before I felt I was dragging on it too much out of 1st and 2nd.
As for height wise I had the clutch almost engaging fully to the floor, but I backed it off a half turn. I now have a small amount of space there. Another way to describe it is that the clutch pedal is parralel to the brake now if not slightly lower. Fantastic difference in control! Thanks again.
Scaldy is offline   Reply With Quote
Old 07-09-2012, 03:00 PM   #37
|-Goku-|
|-Goku-|'s Avatar
I did this last night. Much better. Thanks!
Old 07-22-2012, 05:56 PM   #38
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Just moved the clutch back, loving it!
Old 07-24-2012, 12:35 AM   #39
Synack
Boosted
Synack's Avatar
Drives: Sideways
YES! Thanks for this. Stock clutch lets out so high it feels like the clutch is almost completely burnt out! Personally for me, this way I can use less clutch and it'll last longer and shift smoother and more comfortably
Old 07-27-2012, 09:43 AM   #40
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Fantastic guide! Thanks for posting it and thanks for the pictures. I will adjust mine this weekend. It is definitely needed. Now I need to go find that gear indicator setting...
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 07-27-2012, 12:47 PM   #41
drei
drei's Avatar
Drives: 2013 Scion FR-S Asphalt
Originally Posted by funbeatsfast View Post
Finally got around to adjusting mine. Clutch was cake, the brake pedal was tough. Now all flush with the accelerator. Side foot heel/toe even with my little size 9's. My back is wrecked, but it's worth it. Thanks.
is the break pedal done the same way?
I want to do the same and make them flush
drei is offline   Reply With Quote
Old 07-28-2012, 05:32 PM   #42
Synack
Boosted
Synack's Avatar
Drives: Sideways
I've messed with different points all week & let me save you R&D; the most comfortable point for intuitive starts/ rolls off the clutch, & heel-toe downshifting; screw in until the clutch pedal sits ever so slightly lower than your brake pedal.
THIS. I just adjusted mine a few times. It's absolutely perfect when it sits verrrrrry slightly below brake pedal. Like 1mm below. It's amazing how much the feel changes with even the tiniest change. If you set it barely below the brake, the cruise control will still kick in easily with no problem.
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 04:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 11:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 03:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 02:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 04:48 PM
