Old 03-20-2015, 06:23 PM   #29
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by Koa View Post
You know one other caveat that swings in your favor is the dirt cheap price of stock struts right now.. I have two sets in my garage- one I got for free from a member when I bought my springs (he couldn't figure out how to remove the top hats without a pass through and hex), and now one additional set from my switch to Bilsteins..
So there's that, one could pick up a set for $150-200 and be set for a LONG time
Sounds like what I would love to pay or even a bit more.
SUB-FT86 is offline   Reply With Quote
Old 03-21-2015, 03:21 PM   #30
Crazypinoy9
Drives: FR-S TRD RS1#1488
Ok so I mounted the rims/tires. Ended up going with 235/40/18.
Again, this is on stock suspension consisting of just TRD springs. I plan to add camber bolts and will most likely pick up my ST coilovers within the next couple months.
So far no rubbing of any kind but that's with normal driving. I'll try driving hard another time and update you. I normally don't drive hard anyway so I don't forsee any issues. I wanna get the ST's only because my OCD is killing me seeing the poke in the front and the slight poke in the rear. The pics make it look way worse than it really is.
Front (slight turn in the wheel but still gives you an idea)
Rear
This is the front but it was raised on the lift so it's a little deceiving. doesn't poke out this much. I'll take better pics later cuz it's damn hot outside lol
Doesn't look too bad on the TRD springs...I definitely want the front to be lower but I'll probably just stick to the TRD springs for now since I'm not having any rubbing issues
Crazypinoy9 is offline   Reply With Quote
The Following 2 Users Say Thank You to Crazypinoy9 For This Useful Post:
Koa (03-22-2015), sprintertrueno86 (03-28-2015)
Old 03-22-2015, 01:15 PM   #31
Koa
Looks amazing! DAYMN. ^
EDIT: @Crazypinoy9, Get some LCAs, and some whiteline camber bolts and a good alignment. Then re-evaluate if you really need coilovers.
The Following User Says Thank You to Koa For This Useful Post:
Crazypinoy9 (03-22-2015)
Old 03-23-2015, 12:35 AM   #32
Crazypinoy9
I actually ordered some whiteline camber bolts yesterday and I do plan to get an alignment soon. In regards, to LCAs, which do you recommend?
Old 03-23-2015, 12:45 AM   #33
Koa
Do you track much? If so, the SPL lca's are second to none because they have the most adjustability for sways.. Personally, I love the Racer-X fab line and their LCAs are pure gold. I highly recommend them. They're also just releasing their Version 3 LCA's which will have multiple sway mounting locations
Crazypinoy9 (03-23-2015)
Old 03-23-2015, 01:02 AM   #34
Crazypinoy9
I honestly won't be putting much track time in. At least not with this car. This is my DD so I'll probably just keep it at that. Although I have been eyeing the SPL lca's because I've heard many great things.
Old 03-26-2015, 07:24 PM   #35
thien
Drives: Scion FRS
Rear
How much of a drop do the trd springs have? no fender work done either? Roll or pull?
thien is offline   Reply With Quote
Old 03-27-2015, 12:18 AM   #36
dito
Drives: SWP BRZ
how do you like the ST coils? I have the Enza Vatore wheels, same size and fitment as your Vordovens on stock height and would like to lower the car and fix the front bc its poking out too much for my taste. Was either looking at ST or BC coils.
dito is offline   Reply With Quote
Old 03-28-2015, 01:48 AM   #37
Crazypinoy9
No fender work was done. Although, even though I don't have any issues with rubbing I still plan to have the fenders rolled and pulled in the near future to make the poke much more minimal. TBH i really don't remember the exact drop on the TRD springs. it's about an inch or so.
Old 03-28-2015, 03:15 AM   #38
swarb
Are you happy with the setup? Are you glad you didn't try to shave them down? or still thinking about it? What brand tires did you end up with? Looks good!
Old 03-28-2015, 08:41 PM   #39
Crazypinoy9
I'm pretty happy with the setup so far but will be installing my whiteline camber bolts soon. Am I glad I didn't shave them? well, I really wish the fronts didn't poke out as much as they do. I was hoping to have them tucked without having to use coilovers. But I'm sure the camber bolts will be good enough.
In regards to tires, I got Nitto Motivos. Mainly because I plan to do ZERO track time which means it's only a daily so I didn't need any performance tires. Why spend the extra money if I really didn't need to ya know? FWIW Im very happy with the Motivos right now. super quiet, 60k tread warranty... not bad for $120/tire
The Following User Says Thank You to Crazypinoy9 For This Useful Post:
swarb (03-28-2015)
Old 04-09-2015, 10:46 PM   #40
ZZT86
ZZT86's Avatar
Drives: BR86
Firstly the OP first pic is absolute GOLD, looks the goods but it has way too much poke & negative camber for me, especially as a DD that sees much freeway.
Curious about the weight on them 18x9.5" Kiwami ripoffs ? Silver still looks great on a car.
. . . and it's funny that you think your stock struts are going to last you 80k with those springs..
My old gen7 celica had springs not unlike the sportline that were 1.5" drop on stock oem struts that lasted 95K miles before I insisted they be re-built, although again my car sees much freeway travel so an easy life you could say.
ZZT86 is offline   Reply With Quote
The Following User Says Thank You to ZZT86 For This Useful Post:
Koa (04-10-2015)
Old 05-11-2015, 02:54 PM   #41
keonigt
Drives: 2022 BRZ
Sorry man been laggin on this....
I picked up the rims on Tuesday but haven't had the time to pick up tires yet. Plus I'm debating shaving off 2-3mm on these to give 245/40 a better fit. The sales mgr at Vordoven said 3mm is the max but I'm still a little weary of losing strength in the lug seating. If anyone has any feedback on this please let me know.
Do these rims need to be shaved? So if you don't shave it, it wont fit the 245/40?
keonigt is offline   Reply With Quote
Old 05-11-2015, 03:48 PM   #42
chiefshayan
chiefshayan's Avatar
Drives: 2013 AT Firestorm FRS
Any idea on how much these weigh?
chiefshayan is offline   Reply With Quote
Wheel Directory: Volk Racing TE37 18x9.0 +45 Front / 18x9.5 +40 OmegaKnight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-03-2016 08:09 AM
*** VORDOVEN Forme 9 Wheels - Special Pre-Order Pricing! Only @ Sonic Motor! *** Sonic Motor Wheels and Tires 41 01-07-2015 09:13 PM
Varrstoen ES 1 18x9.5 et34 Fl4t fun Wheels and Tires 9 01-05-2014 08:39 PM
18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) Funky Fresh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-07-2013 09:52 AM
Wheel Directory: Volk Racing TE37 18x9.0 +45 / 18x9.5 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-04-2012 12:25 PM
