Old 12-26-2014, 02:28 PM   #29
Tromatic
All of you get much better mileage than I do, even when I try to drive like a Prius owner.
Tromatic is offline   Reply With Quote
Old 12-26-2014, 02:51 PM   #30
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Someone mentioned that I am studying engineering, he is right. I never said I got my fuel economy off my car. On the car, my average rating is 10 km/L
Using my calculation... I calculated 8 km/L. That is 37.5 L of gas while I traveled 300 KM. That makes it 8 km/L. I know very well that the car displays the L / 100 KM and the smaller number the better. It was a little insulting the someone assumed I was reading off this and made the rest believe.
Testing this:
1. Less idle time
2. Slight quicker acceleration
3. Shifting at 3500-4000 rpm
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 12-26-2014, 03:03 PM   #31
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
I don't drive on the highway usually and I get 19 mpg in the USA. I accelerate to the 6k (sometimes 7.4k) mark in 1st gear typically, then shift to 2nd and eventually to 5th. The area I live in is very hilly, and stop signs are every 1/2 mile on average, so it's really fun. I don't mind my mpg, with the 91 octane gas I have.
My parents' Highlander gets 15 when it's supposed to get 20. In my area, mpg, no matter how you drive a car, will only have a max variance of about 10%. I used to floor the Highlander, and the mpg only changed by 0.5 miles/gallon over the course of several tanks.
When I used to shift at ~3k and drive the BRZ as a typical automatic would, I only achieved 20 mpg. Driving 10/10ths, I still achieve 19 mpg; this difference might even be exaggerated because of the winter gas mix.
carma143 is offline   Reply With Quote
Old 12-26-2014, 03:37 PM   #32
gzpermadi
gzpermadi's Avatar
Drives: Toyota 86 Silver
8 KM/L is normal for short city driving, thats' what I get every day, between 8-9 KM/L.
Even in my previous non-sporty 4 doors car with 2L engine I got the same number.
The number will be closer to 9 if I shift below 2000-2500 RPM as indicated by shifting point at the dash but the car feels so slow with that.
As long as I get 10 days with a full tank I am happy with that.
On the highway cruising with a sixth gear you should be getting 12-14 KM/L.
gzpermadi is offline   Reply With Quote
Old 12-26-2014, 03:38 PM   #33
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Originally Posted by Mikeez View Post
8 km/L = 19 MPG
12 km/L = 28 MPG
Okay, so I don't know what I am doing wrong... Most FRS Driver get 12 km/L... I get 8 km/L
FIRST TEST:
1st gear shift to second @ 2000 rpm
Other gear shifting to next gear @ 3000-3500 rpm
SECOND TEST:
1st gear to second @ 2000 rpm
Other gear @ 2500 rpm
Am I doing something wrong, every on the car is main component. I am thinking if Toyota or Subaru can reflash the OEM tune.
Perhaps I am wrong, but shifting at a lower RPM does not necessarily translate to better MPG's.
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 12-26-2014, 04:02 PM   #34
carma143
carma143's Avatar
This is what I have found with the BRZ and it's instant mpg mode on the display. Going 35 mi/h in 6th gear will grant my about 60 mpg if I barely let my foot touch the gas pedal on flat terrain. If I press the gas pedal about 3/4ths, I hardly accelerate at all, but my mpg goes down to nearly 7 mpg. The gear and rpms don't dictate how much gas you use at a given time. How far down the gas pedal is dictates fuel consumption.
So, what I have found it that consuming more gas will push the engine into higher rpms, which gives the imitation that rpms are what dictate fuel consumption.
Accelerating at higher rpms provides a quicker acceleration, so the gas pedal is not pushed down for nearly as long.
The Following User Says Thank You to carma143 For This Useful Post:
themajesticone (12-27-2014)
Old 12-26-2014, 04:48 PM   #35
Tromatic
Just filled up. 18.7 MPG on the last tank of Chevron 92 octane. 20% freeway, 20% city, 60% fun roads. The freeway and city driving is mostly to get to the fun roads. AT almost always in manual mode, "pedal dance" on fun roads, if that matters. Imagine how low I could get my MPG with a manual trans.
ETA: Your mileage (generally) is totally dependent on your right foot. If you want to be driven insane and be in genuine fear for your life, go for a ride with a Prius owner who's main goal is the greatest MPG he or she can get. Absolutely unwilling to drive with any sort of urgency when needed. You start to wonder if it will be the oncoming truck or some dude with a gun who will do you in.
Boring, but I've always assumed people knew how this works. Most of them are "No shit, Sherlock?" Top 20 Driving Tips to Improve MPG
Oddly enough, I use some of the techniques listed above, the main one being having a fucking clue and planning ahead. I realize there are perfectly valid reasons (the new me, do you like it?) to be seeking the best MPG, but this is really the wrong car for that.
The Following 2 Users Say Thank You to Tromatic For This Useful Post:
navanodd (12-27-2014), strat61caster (12-26-2014)
Old 12-26-2014, 04:53 PM   #36
Dude, How???????
Old 12-26-2014, 05:44 PM   #37
synchromesh
synchromesh's Avatar
Drives: Ultramarine Blue
When I first got my car, the government Energy Guide rated the vehicle as ~10km/L. I was getting a little better than that until I lent my car to two people when I was out of town for a couple months. In fact, a long highway trip that inaugural summer was way better than advertised! Last time I checked, the Scion website/Energy Guide advertises ~9km/L. I've been get EPA numbers for a year and a half now.
It is likely winter gas. Another possibility is 2 or 3 weeks ago, my low fuel light went on, I immediately drove maybe half a kilometer to fill-up and the pump said 42.5L after filling up. I could never recall the light going on and being more or less than half a liter from 40L to fill. Strangely enough I couldnt remember when I paid so little for gas.
synchromesh is offline   Reply With Quote
Old 12-26-2014, 05:59 PM   #38
steve99
When my wife drives either car BRZ or Corolla she gets about 20% worse economy than me driving round city.
I can get better economy driving much harder
She generally drives like a nun , but she holds gears too long both our cars are manual 6 speed
When im just crusing i will be in 5th or 6th light throttle where wife will still be in 4th maybe 5th
driving style makes huge difference
check out your Open loop fuel table example below, when your crusing arround you need to be trying to keep in the areas with highest afr. ir low load low rpm light throttle.
http://i.imgur.com/6W3B1GH.png
Old 12-26-2014, 06:33 PM   #39
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Cold temperatures and short trips increase gas usage significantly.
If you only go 10 kilos and shut it off for 4 hours of class all the time, the ECU will be using a cold engine map and more fuel.
Best mileage will only happen while the whole system is up to nominal operating temp.
Old 12-26-2014, 06:38 PM   #40
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Ouch....... Im on E85 with the supercharger and still get 19 average, 20-21 if i baby it, and 17-18 if i want to go have some fun.. less then 15 if im out driving like i shouldn't be.. But daily commuting is right in the 19's.. on 91 im in the low 22-23's having fun and 27 or so babying it. before any mods i was in the 35's
-Thomas
86SPEED is offline   Reply With Quote
Old 12-26-2014, 09:16 PM   #41
wbradley
Sarcastic SOB
wbradley's Avatar
For clarification, fuel economy is measured in l/100 km, not km/l.
My twin currently is at 8.7 using Petro Ultra 94 with ethanol. Using OFT tune and definitely not light on the throttle.
My WRX with FA20T is currently averaging 9.7 l/100km. Not bad for 68 more HP/ 105 more ft/lb torque.
Old 12-26-2014, 09:23 PM   #42
Zozr
Drives: White
You are so clueless if you thought it was measured in km/L.
That shit is funny
Zozr is offline   Reply With Quote
these stock pads suck... Roadcone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 06-03-2014 01:38 PM
Stock lights suck? Solutions not any better. Help!! BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 21 06-17-2013 11:32 PM
All my LED's installed, they suck. Yruyur Cosmetic Modification (Interior/Exterior/Lighting) 26 04-14-2013 08:23 PM
well this may suck. Mikes86 Scion FR-S / Toyota 86 GT86 General Forum 33 12-29-2012 03:35 PM
Why do all fourm mods suck (except these ones) LexusFman Off-Topic Lounge [WARNING: NO POLITICS] 15 02-15-2012 10:30 AM
