Old 12-08-2014, 07:32 AM   #29
shif7i7down
Erected Member
Drives: frs
Sorry, try the g one i meant. Hope it works for you, if not i hope the guys at oft can help you out, sorry to hear about your issues.
shif7i7down is offline   Reply With Quote
The Following User Says Thank You to shif7i7down For This Useful Post:
Wise (12-08-2014)
Old 12-08-2014, 03:58 PM   #30
steve99
Originally Posted by Wise View Post
Thanks for your help mate.
I've unzipped them using rar. The files inside the C and G Bins appear on my comp as VLC files.
When I try to add them into Modified 1 or Modified 2 or so on. I get the message below.
From this sceenshot your calid is A00G so the oft willonly let you load A00G tune files
the tune files you need will be under G series then stage 1 if your stock then the A00G file. the files should have .bin extensions.
Shiv@Openflash (12-08-2014)
Old 12-08-2014, 07:26 PM   #31
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Thanks mate. I'll give that a shot when i get home form work.
I'm waiting on my UEL header to arrive and will be installing that in the next two weeks.
I'm guessing in this case, to chang emy tune I'd just select G Folder, then Stage 2 UEL, then the AODG tune?
Wise is offline   Reply With Quote
Old 12-08-2014, 10:42 PM   #32
steve99
I'm guessing in this case, to chang emy tune I'd just select G Folder, then Stage 2 UEL, then the AO0G tune?
Yes for uel header Stage 2 UEL, then the AOOG tune unless you going to run E85 fuel then Stage 2 UEL E85, AODG tune
Old 12-08-2014, 11:25 PM   #33
Wise
Circle Work Clerk
Thanks for the help mate. I'll let you know how I go.
Old 12-09-2014, 12:47 AM   #34
steve99
if your in oz have a read here
http://www.ft86club.com/forums/showthread.php?t=61820
our 98 ron is pretty crap and you can benefit from pulling a bit of base timing out of the map.
Wise (12-09-2014)
Old 12-09-2014, 05:04 AM   #35
Wise
Circle Work Clerk
Cheers Steve I'll give it a read. I did what you said and it worked fine. Had no issues writing the map onto the ECU.
The Following User Says Thank You to Wise For This Useful Post:
steve99 (12-09-2014)
Possibility of Live Tuning brn12345 Software Tuning 17 03-30-2020 04:39 PM
climate control swap possibility Mrqb22 Cosmetic Modification (Interior/Exterior/Lighting) 143 03-14-2019 11:46 PM
Possibility of ripping paint off from debadging? Pandanoid Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 10-23-2014 08:31 AM
Sorta related... Skurj Tracking / Autocross / HPDE / Drifting 2 06-03-2014 09:46 PM
Possibility of Scion Sedan? KidWonder Other Vehicles & General Automotive Discussions 6 12-16-2011 05:53 PM
