Old 10-26-2019, 10:46 PM   #29
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Originally Posted by Grady View Post
Adding a cooler does not change where the full mark should be. Unless somehow you cooler is mounted high and drains back into the sump.
But how bad is overfilled a bit on a long term? Especially on a boxer.
I tried ing about the topic isn't really something ppl talk about..
Old 10-30-2019, 10:26 AM   #30
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Oil Consumption for DD after 63k miles is roughly 3-4 tablespoons nothing more between 6,500mi oil changes. Honestly think the 3-4 tablespoons is just variations in where the oil is in the pan.
Regardless of engine type (Boxer 4, Inline 6, V8) overfilling is generally more dangerous than slightly less.
Again to make this clear, slightly MORE is worst than slightly LESS oil. So, that should help your Google rabbit hole.
Make sure you're measuring it right, measure it warm, manual suggest during gas pumping which I think everyone says is a little too quick and not the greatest. Maybe it's due to most gas stations being nearly 100% flat.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
The Following User Says Thank You to SmartedPanda For This Useful Post:
chaoskaze (10-30-2019)
Old 10-30-2019, 10:50 AM   #31
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
I haven't seen any measurable oil consumption between oil changes. In fact this oil remains extremely clean as well. In previous cars I've had engine oil look black at 3k miles. This car's oil still looks like honey at 5k. I'm at 30k miles so far in total.
NWFRS is offline   Reply With Quote
Old 10-30-2019, 05:02 PM   #32
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Wait So I should measure when the oil is kind hot?
I always measure oil when it's completely cold. Let me get back with updated result.
* Ok looks like i'm tiny bit over on the 2nd dot.... So my engines is definitely leaking a bit of oil... =___=
Old 10-31-2019, 10:17 AM   #33
SmartedPanda
This sounds insulting but that's simply because it's over text - not the intention. Please read your manual, and watch a few maintenance videos about general car maintenance (not just Boxer engines) generally all oils are measured warm with cold being the exceptions.
Manual link
Page 293
chaoskaze (10-31-2019)
Just hit 1000 Miles vinh359 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-16-2014 05:48 PM
Almost at 1000 miles. Oil change when? TheGuyWithTheFireStorm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 08-08-2013 12:31 PM
1000+ miles jarviz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 02-02-2013 12:23 AM
Coming up on 1000 miles... jm1681 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 08-30-2012 02:09 PM
1000 miles jarviz Scion FR-S / Toyota 86 GT86 General Forum 8 06-29-2012 02:42 PM
