Old 06-05-2012, 05:18 PM   #29
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Replying to my self here, but even of the caliper offset was off, they could have machined the rotor or ran a spacer between the rotor and hub to make it functional if not correct.
mines13 is offline   Reply With Quote
Old 06-05-2012, 07:59 PM   #30
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
those calipers look like they could be tapped on the other side to ensure the proper piston is on the leading edge, and the bleeder was still on top...
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 06-06-2012, 12:48 AM   #31
RavSpec
Drives: Rx7
Wondering if GRB Spec C are the 6 piston brembo ??
RavSpec is offline   Reply With Quote
Old 06-06-2012, 04:20 PM   #32
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
4 pot according to text.
cyde01 is offline   Reply With Quote
Old 06-06-2012, 04:23 PM   #33
OrbitalEllipses
Drives: Attitude
R205 I think. Yep, just searched to confirm, the 6pot Brembos are from the R205.
Old 06-06-2012, 04:44 PM   #34
Hanakuso
Looks like HKS Kansai put on some GVB brakes for the BRZ
Hanakuso is offline   Reply With Quote
Old 06-06-2012, 04:52 PM   #35
Racecomp Engineering
that looks to be the case for those with the ability to do that.
- Andrew
Old 06-07-2012, 03:45 AM   #36
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
From the picture, and what other pictures I could find, it looks like they are already tapped. The caliper appears to be merely plugged on the non-bleeder side. Might be as easy as simply swapping the bleeder and plug.
FrX is offline   Reply With Quote
Old 06-07-2012, 09:57 AM   #37
Matt Andrews
Drives: race cars
Even if it's not drilling an tapping a hole is not hard work. Granted u will want to make sure it is done right considering its your brakes. But pressurize air and some grease on the bit should keep metal shavings out of the caliper.
Old 06-07-2012, 02:33 PM   #38
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Spending that much money on a brake upgrade is a bit much, but then again it covers the front and rear?
I did a Brembo conversion on my sentra. Cost was about $1000 total. Calipers on the front were $200/side. The rears were cheaper. Then rotors were $30/side, and pads are $200 a set from the dealer. I got some cheaper ones, in a factory grade for $35-40. Spending $5k on a brake system is ludicrous.
The STI Brembos may not be that great on the STI, but take away 500lbs and they should be more than sufficient for the lightweight BRZ/FRS. I'm running generic pads/rotors on this 400hp sentra and track days are not an issue, though I only drive about 7/10.
I'm not a cheap bastard by any means, but it seems like their kit is overpriced by about $3000 at least!
Coheed is offline   Reply With Quote
Old 06-07-2012, 05:22 PM   #39
OrbitalEllipses
Drives: Attitude
Originally Posted by Racecomp Engineering View Post
When you swap sides to fix the bleeder location, the differentially bored pistons are now backwards. So in short, you can't just slap OEM STI brembos on.
- Andrew
Been saying this for TOO long with no one listening.
Guff (06-13-2012)
Old 06-10-2012, 02:41 AM   #40
AzFranz
Az to Nm to Az
AzFranz's Avatar
Auto Produce out of Osaka. Been around for years. 441,000Y at an exchange rate of 79.48 Yen to the USD = $5548.56 That's just outrageous for this car and plain unnecessary.
AzFranz is offline   Reply With Quote
Old 06-10-2012, 02:52 PM   #41
Don@Accelerated
Don@Accelerated's Avatar
Don't want to intrude on the discussion guys but I have a 6 piston Wilwood setup sitting at the shop to fit
Originally Posted by WingsofWar View Post
http://www.apa3.jp/index.htm
swaping sides might fix the upside down bleed issue, but for the price of late generation OEM brembos id rather get properly sized wilwoods.
Don@Accelerated is offline   Reply With Quote
Old 06-10-2012, 03:26 PM   #42
Turbowned
Turbowned's Avatar
At least on the pic of the GReddy car it looks like there's a pipe plug on the opposite side of the bleeder screw. It looks like they're swappable, and if not, it's already been mentioned that they wouldn't be that hard to drill/tap for one. I just get worried seeing the pic of that one red 86 in Japan with a big rusted groove in the rotor; either they installed them incorrectly or the setup just plain doesn't work. I tried contacting GReddy directly to get more info but they never replied.
Won't be a swap that I'll be considering any time soon! The stock brakes in the FR-S/BRZ are fantastic, I found out yesterday!
Brembo BBKs Announced oneday Suspension | Chassis | Brakes -- Sponsored by 949 Racing 82 06-11-2014 10:51 PM
Stock caliper model? skoodge Cosmetic Modification (Interior/Exterior/Lighting) 4 05-31-2012 08:41 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
