Old 04-28-2015, 09:56 PM   #29
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
Works great. I have it wrapped around the steering column and the switch sits flush on the left side. Not a permanent location, but it'll do for now. The flash makes it look scratched to hell, it's been cleaned up since the picture and no rub marks.
cameronjones239 is offline   Reply With Quote
Old 05-04-2015, 05:20 AM   #30
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
I received mine and it doesn't work at all.
Old 05-04-2015, 11:39 PM   #31
Wayno
Wayno's Avatar
Originally Posted by Shiv@Openflash View Post
It works!
The vendor is saying it only passes through 8 pins, not 16, and that's why it's not working. How many pins does OFT actually use?
Old 05-05-2015, 12:06 AM   #32
steve99
Couple of guys using it no problem although I would not write with it
you wont need all 16 pins test lead for continuity if you dont get connectivity on 8 pins its stuffed
assume oft powers up just wont connect
Old 05-05-2015, 12:14 AM   #33
Wayno
Wayno's Avatar
No power
Old 05-05-2015, 01:02 AM   #34
steve99
d
No power
Ok pin 16 is +12v power and pins 4/5 should be earth
If oft works without extension then obd fuse not blown
probe pin 16 and see if 12v suspect inline switch is stuffed. Or test continuity of pin16 end to end its should be switched by inline switch
obd pinouts
http://en.m.wikipedia.org/wiki/On-board_diagnostics
Old 06-03-2015, 09:02 PM   #35
Wayno
Wayno's Avatar
Received replacement which works fine. Used it for a few days and flashed via the switched cable, which also worked fine.
Old 06-05-2015, 09:42 PM   #36
LS1M
Drives: 2015 BRZ
Which pins are used for comm? Canbus + and -?
LS1M is offline   Reply With Quote
Old 09-04-2015, 04:50 PM   #37
mabviper
Drives: WRB BRZ
I just want to say that with our cars, the OBD2 port does support power during ignition. It's located at pin 8. It's only on when the car is on. What you can do is to buy an OBD2 extender and reroute its pin 8 (from the car) to pin 16 (connected to the OFT or any other OBD2 device).
Hope that helps.
mabviper is offline   Reply With Quote
The Following User Says Thank You to mabviper For This Useful Post:
steve99 (09-05-2015)
Old 08-14-2017, 07:52 PM   #38
eurominican
Bringing Hachiroku Back
eurominican's Avatar
Drives: 2013 Firestorm FR-S
Is this still the best cable for that price? https://www.amazon.com/dp/B00UR5XBMW..._LEJKzbNV67VXA
eurominican e u r o m i n i c a n
eurominican is offline   Reply With Quote
Old 08-14-2017, 08:19 PM   #39
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
@eurominican
I was gonna buy this one, which looks like the same thing, is a buck cheaper, and also has good reviews: http://amzn.to/2vyG7Ho
TofuJoe is offline   Reply With Quote
The Following User Says Thank You to TofuJoe For This Useful Post:
eurominican (08-14-2017)
Old 08-14-2017, 08:29 PM   #40
Teseo
Drives: frs
Yes
Old 08-16-2017, 04:01 PM   #41
eurominican
Originally Posted by TofuJoe View Post
@eurominican
I got it. Thanks!
How do you guys have yours? Like, where in the car and how are you tucking the cable?
Old 08-16-2017, 04:05 PM   #42
TofuJoe
Ohne Titel
TofuJoe's Avatar
@eurominican - I used a velcro strap to secure the cable to some other wiring under the steering wheel area.
eurominican (08-17-2017)
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 01:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
How to replace turn signals with switch backs and its relay switch. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 1 05-30-2013 11:42 PM
FRS/BRZ BRUSHED SATIN POWER WINDOW SWITCH TRIM zetaproducts.net Interior Parts (Incl. Lighting) 28 05-14-2013 09:32 AM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
