#29 | |
Drives: '15 BRZ RA
#30 |
Member of the year - 2016
Drives: Scion FRS
So let me get this straight.
If i have a 1.4L I4 engine that produces 130HP and 105 ft/lbs factory and someone tunes it to squeeze out 143HP and 109 ft/lbs. The factory tune is safe and has proven no long term damage to meet emissions, etc etc. You're telling me that this tuned engine, which is now doing more work and producing more energy/heat is essentially going to last longer than the engine with a stock tune?
#31 | |
Drives: Silver Subaru BRZ
#32 | |
#33 |
Buy a mod that will enable you to log vital stats on your engine so you can see what's going on. If you really want to ensure engine longevity:
1. Monitor oil temps on cold start and don't push your engine if temps are below ~180 F. 2. If you see oil temps rise above ~240 F during hard driving, back off until it cools off. 3. Make sure you're getting the right oil pressure for your RPM, both cold and hot. 4. If you log any detonation, switch to a better fuel if possible. Or a better tune.
2022 BRZ Build 2013 FR-S Build |
#34 | |
Drives: 2013 BRZ Limited
However, if the tuner tunes to make the engine flow properly (AFR), the result can, and usually is, more power and less detonation and knock correction. I can post dyno pics of a 2 tuner comparison from my WRX if you need to see them.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
#35 | ||
Drives: 2015 FR-S (Halo)
Many of the manufacturers of pulleys, if I remember correctly, have addressed this topic and said pulleys don't always perform this function and the 86's pulley is one of those that doesn't. It's also worth noting that one of the main things that necessitates dampening is the mass of the pulley, which the manufacturer doesn't make incredibly lightweight because it's a massive waste of money since they can just cast a billion pulleys rather than individually machine them. I'm in a (boring) meeting right now but when I have a minute I'll go pull some quotes. Even if they DO still cause some wear on certain parts of the engine, I'd be interested in an actual look at whether the reduced wear from a lighter pulley offsets it. EDIT: However, it is worth noting that many people, including Crawford on this forum, note that the actual benefits from a lightweight pulley that isn't smaller are super marginal. There's probably better life-gain to be had in a better radiator and an oil cooler. Sent from my HTC One_M8 using Tapatalk
#36 | |
Drives: 2013 GBS BRZ Limited
There has been endless debate about the factory's decision to use a harmonic dampener on the crank pulley. The debate is over about whether the stock pulley is a dampener or not - IT IS a "text book example" of a dampener. Whether the factory chose to use it because the engine needed one, or "because we had a big box of them already" is the only part of the discussion still in question. The latest thread (that I recall) explain that a prominent engine builder refuses to put a light weight crank pulley on an engine with a lightened flywheel because (in his experience) it causes premature bearing failure. |
#37 | |
Drives: 2014 WRB BRZ Limited
![]() ![]() There are only a few ways to blow up your engine under 100k miles: 1. Manufacturer defect 2. FI 3. Mechanically over revving 4. A long-term combination of: low octane + non-synthetic oil + beating on cold engine 5. Staying near/at redline for extended period of time (think +45 minutes) As far as the tune goes, the only difference between a factory tune and an aftermarket tune is that the factory tune is made to work on thousands of engines instead of just one. Since tolerances stack and there are many parts, a tune that works well on one car may not be well suited to another. Therefore, getting a tune specifically for your car, regardless of what it does to power, is going to improve longevity. A bad tune that makes very little power is much worse for an engine than a good tune that makes a lot.
#38 | |
Drives: '15 BRZ RA
The difference is that serious companies admit this. For example, öhlins admits that their suspension will not last so long as an OEM suspension. This is how things work. You have to balance some things. You gain somewhere and you lose somewhere else. |
#39 |
Drives: GT-86
#40 |
Drives: 2005 Toyota Camry
| No longer available | funx | Canada Classifieds | 3 | 10-29-2013 09:10 AM |
| Engine Cover mods? | Thongpocket | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 09-18-2013 02:48 PM |
| Engine Mods and CELs | Captain Snooze | Engine, Exhaust, Transmission | 2 | 04-08-2013 10:13 PM |
| NA engine mods for turbo money? | subatoy | Engine, Exhaust, Transmission | 62 | 11-28-2012 04:32 PM |
| check engine/CEL/DTC/MIL code list | arghx7 | Engine, Exhaust, Transmission | 3 | 07-04-2012 10:37 PM |
