Old 08-27-2014, 08:30 AM   #29
s2d4
s2d4's Avatar
FA20club turbo kit and tune.
Old 08-27-2014, 10:11 AM   #30
djmm
djmm's Avatar
Drives: toyota
I'm more conservative in terms of modifying cars.
But say I won a prize for being able to modify my car for up to $5K total, I'd probably get:
- Sound deadening door panels
- New Satnav head unit
- New set of wheels
djmm is offline   Reply With Quote
Old 08-27-2014, 10:23 AM   #31
ZionsWrath
Thanks
ZionsWrath's Avatar
I hate to look over what I spent on my car but I guess I've spent 5k on it now lol
AP sprint kit with Stainless brake lines, Track and street pads
Track wheels/tires
Alignment gear (Racesang Cascams front/SPL rear LCA)
Although expensive up front I consider these kind of bang for buck mods. Hear me out
Track brake kit will reduce wear cost because 1 track only pads, 2 BBK make track pads wear less, 3 if i ran a street pad at track it would wear real fast
Wheels/tires, kind of same as brakes, don't have to compromise and run a tire I may overheat and chunk or something, plus if I get a flat on the street it won't ruin my track day
Alignment, I guess self explanatory. Alignment is a very key aspect in tracking even more so than buying coilovers IMO
But I guess I typed all this assuming you want to track your car. If not then I wasted my time ^_^
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
litemup (08-27-2014), Shark_Bait88 (08-27-2014)
Old 08-27-2014, 10:37 AM   #32
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
SACHS Coilovers [$2k normally, but quite a bit more affordable when you work for them ]
17x9 RPF1s w/ good rubber for track days [another $2k]
Project MU Club Racer pads for track days [$400]
Berk single exit track pipe [$135, or around $80 used]
and spend the rest on track time.
(This is pretty much my plan anyways lol)
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 08-27-2014, 11:10 AM   #33
tennisfreak
Drives: 2018 BMW M240i
Supercharger.
Since it would be my only mod to start with, the boost and tune would be mild only putting around 250hp to the wheels.
Then as funds come in add more mods.
Old 08-27-2014, 11:26 AM   #34
DarkSunrise
DarkSunrise's Avatar
Budget $5k build:
$1600 - TC105N 17x8
$400 - Federal 595RSR 235/40/17
$100 - camber bolts + rear diff inserts
$300 - Ferodo ds2500 pads + ATE200 fluid
$900 - JDL UEL header
$500 - OP + FP
$600 - Perrin oil cooler
$500 - OFT
$4900
Then track days.
2022 BRZ Build
2013 FR-S Build
Old 08-27-2014, 11:58 AM   #35
I'd seriously consider putting it towards a supercharger on the FR-S but more than likely I'd put it in my C7 Corvette fund for when I buy the FR-S a garage buddy.
Old 08-27-2014, 12:06 PM   #36
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by Shutter View Post
Fixed:
drugs, hookers W/ just the tip, muffler delete
that order
.Add condom .50c
Old 08-27-2014, 01:03 PM   #37
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Originally Posted by wbradley View Post
.Add condom .50c
lmfao...probably a good investment
Old 08-27-2014, 02:03 PM   #38
Frisco86
Frisco86's Avatar
Drives: 14 scion frs whiteout, 07 civic si
Best investment ever lmao
Frisco86 is offline   Reply With Quote
The Following User Says Thank You to Frisco86 For This Useful Post:
continuecrushing (08-27-2014)
Old 08-27-2014, 05:06 PM   #39
raven1231
option 1:
SPD turbo kit'
Oil Cooler
OFT
Full exhaust
Tires
Option 2:
Phantom ESC
1.5 dump conversion
full exhaust
intake
OFT
Tires
Old 08-27-2014, 10:49 PM   #40
radroach
Drives: car
If you gave me 5k right now, I'd get a Stage 1 tune, new clutch and brakes, and 4 new sets of oem tires.
Also been eyeing a tomei 60s.
Also I'd replace my windshield glass which is chipped up.
Old 08-28-2014, 12:10 AM   #41
Havsie
Havsie's Avatar
Drives: 13 FR-S Whiteout 6MT
I'd leave my car alone and buy 5000 dollars worth of hamburgers
Havsie is offline   Reply With Quote
Old 08-28-2014, 12:57 AM   #42
extrashaky
Drives: 2014 BRZ Limited
I'm given $5K and a stock FR-S? I'd buy:
Rubicon Express 5.5" lift kit
Rubicon Express monotube shocks
Slip yoke eliminator
Drive shaft
One ton steering kit
The Following User Says Thank You to extrashaky For This Useful Post:
litemup (08-29-2014)
WTB: Stock MAP Sensor, Stock Frontpipe, Stock Midpipe. Sterz Engine, Exhaust, Bolt-Ons 4 07-02-2014 10:22 PM
Stock FRS Wheels and 215/45/17 Stock Bridgestone Turanza Separated 12k miles VuDism Wheels and Tires 8 03-23-2014 09:01 PM
TYC Colin Smoked Tail Lights | Stock FRS Tails | Stock FRS Reverse Bar BumpersFRS Exterior Parts (Aero, Lighting, Etc.) 1 01-11-2014 04:42 AM
WTS: Airaid Intake System, Stock Exhaust, Stock Radiator Hoses Sony Engine, Exhaust, Bolt-Ons 0 11-21-2012 12:10 AM
