#29 |
FA20club turbo kit and tune.
#30 |
Drives: toyota
I'm more conservative in terms of modifying cars.
But say I won a prize for being able to modify my car for up to $5K total, I'd probably get: - Sound deadening door panels - New Satnav head unit - New set of wheels |
#31 |
Thanks
I hate to look over what I spent on my car but I guess I've spent 5k on it now lol
AP sprint kit with Stainless brake lines, Track and street pads Track wheels/tires Alignment gear (Racesang Cascams front/SPL rear LCA) Although expensive up front I consider these kind of bang for buck mods. Hear me out Track brake kit will reduce wear cost because 1 track only pads, 2 BBK make track pads wear less, 3 if i ran a street pad at track it would wear real fast Wheels/tires, kind of same as brakes, don't have to compromise and run a tire I may overheat and chunk or something, plus if I get a flat on the street it won't ruin my track day Alignment, I guess self explanatory. Alignment is a very key aspect in tracking even more so than buying coilovers IMO But I guess I typed all this assuming you want to track your car. If not then I wasted my time ^_^
| The Following 2 Users Say Thank You to ZionsWrath For This Useful Post: | litemup (08-27-2014), Shark_Bait88 (08-27-2014) |
#32 |
Drives: 2013 Firestorm FR-S
SACHS Coilovers [$2k normally, but quite a bit more affordable when you work for them
]17x9 RPF1s w/ good rubber for track days [another $2k] Project MU Club Racer pads for track days [$400] Berk single exit track pipe [$135, or around $80 used] and spend the rest on track time. ![]() (This is pretty much my plan anyways lol)
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#33 |
Drives: 2018 BMW M240i
Supercharger.
Since it would be my only mod to start with, the boost and tune would be mild only putting around 250hp to the wheels. Then as funds come in add more mods. |
#34 |
Budget $5k build:
$1600 - TC105N 17x8 $400 - Federal 595RSR 235/40/17 $100 - camber bolts + rear diff inserts $300 - Ferodo ds2500 pads + ATE200 fluid $900 - JDL UEL header $500 - OP + FP $600 - Perrin oil cooler $500 - OFT ------- $4900 Then track days.
2022 BRZ Build 2013 FR-S Build |
#35 |
I'd seriously consider putting it towards a supercharger on the FR-S but more than likely I'd put it in my C7 Corvette fund for when I buy the FR-S a garage buddy.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#36 |
Sarcastic SOB
.Add condom .50c
#37 |
Drives: 2013 Firestorm FRS
#38 |
Drives: 14 scion frs whiteout, 07 civic si
| The Following User Says Thank You to Frisco86 For This Useful Post: | continuecrushing (08-27-2014) |
#39 |
option 1:
SPD turbo kit' Oil Cooler OFT Full exhaust Tires Option 2: Phantom ESC 1.5 dump conversion full exhaust intake OFT Tires
#40 |
Drives: car
If you gave me 5k right now, I'd get a Stage 1 tune, new clutch and brakes, and 4 new sets of oem tires.
Also been eyeing a tomei 60s. Also I'd replace my windshield glass which is chipped up. |
#41 |
Drives: 13 FR-S Whiteout 6MT
I'd leave my car alone and buy 5000 dollars worth of hamburgers
#42 |
Drives: 2014 BRZ Limited
I'm given $5K and a stock FR-S? I'd buy:
Rubicon Express 5.5" lift kit Rubicon Express monotube shocks Slip yoke eliminator Drive shaft One ton steering kit |
| The Following User Says Thank You to extrashaky For This Useful Post: | litemup (08-29-2014) |
| WTB: Stock MAP Sensor, Stock Frontpipe, Stock Midpipe. | Sterz | Engine, Exhaust, Bolt-Ons | 4 | 07-02-2014 10:22 PM |
| Stock FRS Wheels and 215/45/17 Stock Bridgestone Turanza Separated 12k miles | VuDism | Wheels and Tires | 8 | 03-23-2014 09:01 PM |
| TYC Colin Smoked Tail Lights | Stock FRS Tails | Stock FRS Reverse Bar | BumpersFRS | Exterior Parts (Aero, Lighting, Etc.) | 1 | 01-11-2014 04:42 AM |
| WTS: Airaid Intake System, Stock Exhaust, Stock Radiator Hoses | Sony | Engine, Exhaust, Bolt-Ons | 0 | 11-21-2012 12:10 AM |
